Old 26th February 2014, 14:32   #166
pramodkumar's Avatar
Thanked: 2,246 Times
re: Home Construction / Makeover / Maintenance Thread
Thanks Aroy
Originally Posted by RaguHolla View Post
Axis bank has this option.
Your post was the most useful because i am getting the loan from axis bank. can you tell me what i need to consider when availing this loan?
Pramod
pramodkumar is offline
Old 26th February 2014, 15:23   #167
tckanth's Avatar
Thanked: 27 Times
I am taking a home loan, just wanted to know if the first instalment for building the house comes after the completion of stage 1 or before? I would definitly ask the bank however though of doing some homework.
Another question is, does the EMI start after complition or after the loan is approved? please throw some light
Pramod
Hi Pramod,
I am using a simple EMI calculator
EMI CALCULATOR.xls
This really helps me in understanding
1. How much is the EMI,
2. What portion of the EMI is the interest amount and the principal amount
3. If I make a prepayment, how would that impact my tenure
4. If I decide to pay a fixed amount (more than the slated EMI) how soon can I finish the loan.
Please feel free to PM me in case of any queries.
Chaitanya.
tckanth is offline
Old 10th March 2014, 14:54   #168
driverace's Avatar
Thanked: 173 Times
Home Construction/Modification suggestions - Pullup bar & Music room
Guys,
Have been offline for quite some time.
Looked around Pune & booked a flat in my hibernation period
My 'booked' flat is under construction & is supposed to finish by October 2013.
Currently the flat brickwork is done. Some grill work is done.
The "whitewash-putty work" has just started.
Long way to go - tiling, painting, doors, kitchen stuff, bath internals, fittings etc - ALL still to be done.
Here is what I have on my wishlist:
1. Pull-up bar to be fitted on wall / ceiling (in one of the bedrooms)
But, the concrete work being done - I feel only option now is to put it with fasteners or something like HILTI bolts.
2. Somethings to "put/install" on walls before painting gets done to make a room sound proof / music friendly.
( Intention is to make it a music/recreation room. We have a couple of instruments & plan to setup a music system in one of the bedrooms. )
One query:
1. I will decide on 2 places where I would most likely put my TV in the hall. (One place is already in place in design), Should I get the wiring done at the other "place" too? is that possible? Is that advisable?
Any suggestions to look at / some "must" holes to drill / some places to keep fixed for some stuff or some pointers in a "under-construction" flat are welcome!
Thanks,
Ace.
driverace is offline
Old 12th March 2014, 20:21   #169
Any reviews of German kitchens in India?
Hi friends, I am doing up my kitchen and am exploring the imported modular kitchens. I am good cook and having a nice, practical snazzy kitchen has been my dream. Has anyone got any experiences with these type of kitchens? I have looked at Alnomaritime, Hacker and Poggenpohl and would appreciate some reviews. Thanks.
Last edited by aah78 : 12th March 2014 at 21:31. Reason: Thread merged with existing renovation thread.
Ricxx is offline
Old 14th March 2014, 11:35   #170
Thanked: 2,888 Times
Re: Any reviews of German kitchens in India?
I have seen a lot of imported modular kitchens. Unless you want to pay through your nose you are better off getting it custom made.
In imported kitchens the following come from abroad
- Pre-laminated panels. These are either MDF or high quality resin bonded plywood. The down side is that they come in fixed sizes. That means you have to tailor the civil work to the cabinets rather than cabinets to the kitchen.
- Kitchen hardware. These are available in various qualities. Some are quite expensive. Search the net for various brands available in India.
In some of the less expensive modular kitchens the pre-laminated panels are made in India. Unless they are fabricated using high pressure presses they are not as sturdy as the imported ones, nor as fancy as those made at home.
What we do is to
. fabricate the cabinets from marine grade plywood (moisture, pest and fungus retardant).
. Impregnate with anti termite paint for added safety.
. Clad the exterior surfaces with client chosen laminates/veneer. This is done under pressure so that the laminate is bonded perfectly and does not peal off in future.
. Use Imported hardware. The price varies from brand to brand. The least expensive imported stuff is normally twice as expensive and the higher end at least ten times as much as Indian hardware. Higher price gets you heavier sections, better finish and longer life.
An indicative cost for a 100 square foot kitchen
- Custom made by a carpenter : 1L to 2L
- Lower end Indian Modular Kitchens : 4L to 8L
- Higher end fully imported modular kitchens : 6L to 15L
- In some Farm hoses in Delhi, the owners have spend upwards of 50L for a 250 square foot kitchen.
These costs do not include appliances - Gas/Electric hob, Oven, Sink, Taps, Trash processor, Chimney etc. These can easily add up another 5L-15L depending on the number and brand chosen.
Aroy is online now
Old 18th March 2014, 00:06   #171
Thanks a lot for the vast information you have given. I am actually aware of these facts and was wanting some reviews of modular kitchens which people have been using.
What we do is to
Ricxx is offline
Old 18th March 2014, 09:38   #172
Unless the kitchen has been in use for ten years you will only get good reviews. Even shoddy carpentry jobs do not show their true colours before three or four years have passed. That is why builders will show off buildings a couple of years old.
A well made wood work lasts at least 20+ years, and furniture 50+. So that is the time line you should be looking for.
What ever you install, make sure of the following
. Check the walls for seepage. If it is there get a specialist to inject water proof compound at 1m spacing on all the walls. This is especially relevant for old houses.
. If possible do a rigorous termite treatment on the walls and floor before the walls are painted.
. Ensure that the drains are clean. In new construction at times a lot of debris accumulates in the drains, which creates problem later - leading to over flowing drains and seepage on the walls.
Aroy is online now
Old 18th March 2014, 12:33   #173
Thanks for the advice Aroy. My house is currently under construction. How much is this water proof compound treatment for? Someone told me this new waterproof treatment is for Rs 500 per sqft. This is an extremely expensive prospect. Is there any other waterproof treatments which are economical?
Ricxx is offline
Old 18th March 2014, 13:45   #174
DieselFan's Avatar
Thanked: 259 Times
has anyone used Robo Sand instead of River Sand for construction. Robo sand is Granite powder as per the Manufacturer's website it is better than river sand and cheaper cost as compared to River Sand.
http://www.robo.co.in/home.htm
DieselFan is offline
Old 18th March 2014, 22:21   #175
one-77's Avatar
Thanked: 709 Times
M-sand as it's called is now commonly in use over here as river sand has become too expensive. We used it while extending our house. No problems of any kind. Been three years. No cracks/ peels/ dampness or anything.
one-77 is offline
Old 20th March 2014, 14:36   #176
This seems to be excessive. Please search the net for "water proofing contractors" and contact the ones in your city. They will come to you, study the site and give you a quote.
Less expensive treatments are an eyewash as they are short term measures - cement plaster, spraying water proof compound etc. What lasts a life time is special compound injected under high pressure in a grid. The chemical permeates and seals all micro cracks in concrete.
Aroy is online now
Old 20th March 2014, 17:02   #177
Turbanator's Avatar
Thanked: 30,048 Times
It can't be .. maximum Rs 15 per sqft might have gone to Rs 20 or so , check FixIt Products - they have different products for treatment of roof's , toilets & kitchen & pool
http://www.doctor-fixit.com/contactus.aspx
I recollect there are couple of dealers in Sector 26 / 7 on MadhyaMarg
Turbanator is online now
Old 24th March 2014, 00:41   #178
Ketan's Avatar
Thanked: 449 Times
Hi, I'm starting a thought process on construction. Not sure if this (summer) is a good time, but it seems I may take sometime to decide on a plan, approvals, funding etc. So, guessing it may take a quarter or so (hope it doesn't and I can start soon!)
To start with, I'm going to compare the eco-friendly construction v/s the usual way in terms of cost/benefits. If anyone of you have any ideas around this, please share your views.
2000sqft plot is going to be used, we are 3 of us for now (5 in case if parents join us later). I have read a bit about the eco-friendly construction ways, rain water harvesting, solar project good ventilation and climate control etc as the benefits of this style of construction, thought it would be useful while this part of Bangalore loosing water rapidly.
However, I don't know about the cost involved with this style of construction, may see Biome solutions folks to find out more details here, if its bit too expensive compared to the usual way, I may have to give it a miss but will still be interesting in major things like rain water harvesting/solar etc.
I'm looking forward to keep good amount of open space, small little garden and a good sitting area to sip an evening tea etc. If someone can help me point good architects around Bangalore it'll be of great help, I can then compare them with eco-friendly style in terms of cost/benefit.
Thank you.
Ketan is offline
Old 24th March 2014, 12:32   #179
Thank you.
Building multi storey buildings the "green way" is more expensive than conventional method. The trade offs are in lesser use of energy for lighting, cooling and heating.
It is best to plan for rain harvesting now, as collection points and storage for water has to be integrated with the building.
Make provision on the terrace for a solar heater for hot water and a solar panel for electricity. You may also have to install 2 dedicated pipe lines from the terrace one for normal water from the over head tanks and another insulated line for hot water from the solar heater.
My house is on a 233 square yard plot, with less than 40% area covered. The rear portion has a 30 x 24 foot garden and the front a 30 x 15 foot open space. If I had built it today, I would have had the building pushed back so that the front had a single large open space.
Aroy is online now
Old 5th June 2014, 19:20   #180
fine69's Avatar
Thanked: 1,467 Times
I'm planning to get a glass door entrance to our shop, any idea what kind of expense I should be looking at? Also, any particular shop (or area) in Delhi that is recommeded for this kind of work?
The entrance is about 6.5-7 ft wide and 7 ft high. I currently have a wooden door (with top half of glass) and rest of the frame is wooden too with a 1.5x1.5 ft glass window.
fine69 is offline
