Team-BHP > What Car? > Sedans
Old 24th March 2008, 08:38   #1
XETA or IndigoCS?
Hi guys,
Now that I've decided to go for a petrol vehicle, I am in two minds between the TATA Indica XETA GLG and the all-new TATA IndigoCS GLS.
The XETA seems more VFM; the Indigo does not come equipped with Central Locking and PW (Front and Rear), and I do not intend having aftermarket PWs fitted, since they invariably tend to conk out eventually.
On the other hand, with the Indigo, I'd have almost 400 litres of boot space and wider tyres.
I am about to bore you guys just a bit, with the differences between the two:
1. Engine Description
Indigo: 1.2L 64bhp MPFI petrol engine w/ 32-Bit Microprocessor
XETA: 1.2L 65bhp 4 cyl. In-line w/ 32-bit microprocessor
2. Maximum Power
Indigo: 65 @ 5,200 (PS@rpm)
XETA: 65.3@5,000-5,200 (PS@rpm)
3. Maximum Torque
Indigo: 10.7 @ 2,600 (kgm@rpm)
XETA: 10.2@2,600 (kgm@rpm)
4. Front Suspension
Indigo: Independent McPherson strut with Anti-roll Bar
XETA: Independent, Wish Bone type, with McPherson strut, Anti-roll Bar
5. Rear Suspension
Indigo: Independent 3- link Mc-Pherson strut with Anti-roll Bar
XETA: Independent, Semi trailing arm with coil spring
6. Turning Radius (Wheel base)
Indigo: 5.0 m
XETA: 4.9 m
7. Fuel Tank Capacity
Indigo: 42 litres
XETA: 37 litres
8. Tyre Size
Indigo: 175/65 R 14
XETA: 165/65 R13
9. Exterior Dimensions
a. Length
Indigo: 3,988 mm
XETA: 3,675 mm
b. Width
Indigo: 1,620 mm
XETA: 1,665 mm
C. Height
Indigo: 1,540 mm
XETA: 1,485 mm
d. Ground Clearance
Indigo: 165 mm
XETA: 170 mm
e. Wheelbase
Indigo: 2,450 mm
XETA: 2,400 mm
f. Kerb Weight
Indigo: 1,065 kg
XETA: 995 kg
10. No. of doors
Indigo: 4
XETA: 5
11. Cargo Volume
Indigo: 380 litres
XETA: 217 litres
12. Features
a. Fog Lights- Rear
Indigo: Standard
XETA: Not Available
b. Rear Window Defogger
Indigo: Not Available
XETA: Standard
c. Wheel Covers
Indigo: Standard
XETA: Not Available
d. Integrated Antenna
XETA: Standard
e. Tinted Glass
XETA: Standard
Here, the TATA guys, via email, confirmed that Tinted Windshield comes as a standard fitment even in the IndigoCS, but nothing is mentioned on the site.
f. Rear Spoiler
XETA: Standard
g. Tachometer
XETA: Standard
h. Electronic Multi-Tripmeter
XETA: Standard
Here again, the TATA guys confirmed that the Indigo comes equipped with a digital odometer with 2 trip meters, but says nothing on the site.
i. Cigarette Lighter
XETA: Standard
j. PW- Front
XETA: Standard
k. Accessory Power Outlet
XETA: Standard
l. Trunk Light
XETA: Standard
m. Central Locking
XETA: Standard
The TATA guys said the Central Locking would cost Rs. 5400
n. Day & Night Rear View Mirror/Front Impact Beams
Indigo: Standard
XETA: Not Available
o. Front Impact Beams
Indigo: Standard
XETA: Not Available
I have a budget of about 5L OTR.
It's gotta be a Petrol, and it's gotta be between these 2 vehicles.
Looking for ride comfort, space and VFM.
Fire away guys!
luvjascha is offline
Old 24th March 2008, 09:12   #2
JayD's Avatar
Thanked: 2,572 Times
At 5L OTR, if u are not fixed on tata, u can look at other options too!!
JayD is offline
Old 24th March 2008, 09:29   #3
Like I said, it's gotta be between the two vehicles.
I forgot to mention, there's almost a 65K price difference.
Will the FE be almost the same with the two?
Old 24th March 2008, 09:37   #4
karanraheja's Avatar
Thanked: 436 Times
If you are specific about these two vehicles i would still go for Indigo CS.
Inspite of all this i would be crazy if i would not recommend you a Swift Dzire.
Give it a look and then decide.
karanraheja is offline
Old 24th March 2008, 09:52   #5
Would you be aware of the launch date, technical specifications and features of this vehicle?
From the pictures posted on another thread, the front resembles the Swift. Besides, they plan on pricing the base petrol version at around 4.5L, a neat 65K higher than the Indigo. I don't think I'd be too interested.
Old 24th March 2008, 10:18   #6
Thanked: 436 Times
I heard about 26th March Launch in New Delhi. The interior trim quality will be better in the Dzire than the Indigo CS/ Xeta. Have a look at the Dzire if it doesnt suit your needs then go for the Tata.
Old 24th March 2008, 12:19   #7
ram_hyundai's Avatar
Thanked: 53 Times
There is already a thread discussing the launch and plus and minus points of the Dzire.I would sugest you to take a look before you decide.26th would be the launch in delhi,27th in respective states.
ram
ram_hyundai is offline
Old 24th March 2008, 14:32   #8
ashutoshb's Avatar
Thanked: 5,038 Times
After taking a look at the features list, it looks like you will have to sacrifice a lot for a boot and slightly bigger tyres.
But, in my opinion, except for a tachometer and power windows, there is nothing that you'll miss on a daily basis.
Its for you to decide if you can live with the things you'll not get in the CS.
ashutoshb is offline
Old 24th March 2008, 14:50   #9
Hemanth's Avatar
I suggest you to go for Indigo CS since anyways a Sedan will always be better and wanted to be driven. In the due course you feel that you should have gone for Indigo instead of Xeta.
Hemanth is offline
Old 24th March 2008, 14:56   #10
tsk1979's Avatar
Thanked: 23,060 Times
If you don't need the boot, get the hatch, its always more fun to drive a hatch.
Moreover from my experience, the indica handles better, esp on twisty mountain roads.
the Indigo(non CS) has rear independent suspension which is amazing for ride, but is no great shakes for handling.
Don't know how will the CS handle though.
On a more practical front, in the city its easy to whip around the indica, but in case of indigo, you have to watch that boot.
tsk1979 is offline
Old 24th March 2008, 15:22   #11
Thanked: 32 Times
I'd go for the Indigo CS if I were you.
hrag is offline
Old 24th March 2008, 15:45   #12
svsantosh's Avatar
Thanked: 7,339 Times
Actually No... In my TD I felt at ease with the CS's small Boot extension. with respect to a regular Indigo yes, I agree with u, the CS is a bit diff in that respect. its hardly 10-12 Centimeter's more than a U-VA or other such long hatchbacks.
svsantosh is online now
Old 24th March 2008, 15:49   #13
dhaval's Avatar
For daily driving, the Xeta should be just fine. IMO, the Indigo CS just has the advantage of having a larger boot if at all you plan a outing with family etc; and besides that you can always have the option of upsizing the rims and the tires on the Xeta with the money thus saved.
dhaval is offline
Old 24th March 2008, 15:50   #14
tsk1979's Avatar
The only thing CS is giving you extra is a boot and better rear seat ride.
If these are important buy CS, otherwise go for the Xeta, simple!
tsk1979 is offline
Old 24th March 2008, 15:50   #15
svsantosh's Avatar
Luv-- I agree with you on the pricing, the CS starts at 3.66L and the GLS petrol is 3.85, Vs the 4.5L Rumored dZire, its a steal. But as a maruti owner I can say the build quality of TATA is lot less than a Maturi. Not that It wont work...But if u can live with it, Its great VFM. Let me know once you make the purchase. I am waiting till Diwali/dushera for some price cuts from TATA to buy the CS.
