Team-BHP > What Car? > Sedans
Old 8th May 2007, 00:35   #1
Civic (MT) Maintenance - worth buy?
Hi Fellows; can you tell me your experience in maintaining your beauty. How much average service cost at Honda. How much budget I should have to maintain the car. Mileage of Civic (MT)....any other pros n cons of buying this car.....would appreciate replies from Civic (MT) owners.
Should I buy Honda City Zx (vtec) or should I go for Honda Civic (MT). worth buy...Civic???
Team BHPian...your suggestion also needed......
Thanks Team BHP!
autoxxx is offline
Old 8th May 2007, 02:22   #2
manikjeet's Avatar
Thanked: 295 Times
man if you can go in for a civic nothing beats it and about the maintenance honda cars are not to heavy on the pocket
and only con about this car is the GC you have to be carefull over the bumps
manikjeet is offline
Old 8th May 2007, 02:29   #3
Awaiting Email Confirmation
nitroxx's Avatar
Thanked: 31 Times
theres no question it has to be a civic bro.
nitroxx is offline
Old 8th May 2007, 02:39   #4
Fuelled's Avatar
Expect the Civic to give 10km or so in Delhi driving.
Yes the spares + service will be more than the NHC, but still not obscenely so.
If u have the budget for a Civic, then go for it for sure. Its in a different class alltogether and is a better car.
Fuelled is offline
Old 8th May 2007, 09:15   #5
Thanked: 307,336 Times
But of course, the Civic. Since you considered the NHC, you might also want to check out the SX4. Appears to offer superb value!
GTO is offline
Old 8th May 2007, 09:38   #6
esteem_lover's Avatar
Thanked: 506 Times
Civic, it is. Maintenance is relatively easy & not much is required on a new car. Yes, you could look at the SX4 also, but the civic stands out, IMO.
esteem_lover is offline
Old 8th May 2007, 11:45   #7
CHIP's Avatar
Hey guys yes true words the civic stands out a very low maintainence car
i am driving myself i don't know much about that issue of the ground
clearence but according to me it ain't that big problem i have been
through more than 1000 of speed breakers till now i did'nt got any scratch on belly
CHIP is offline
Old 8th May 2007, 17:41   #8
Compare CIVIC with SX4
Civic tech-specs from -> Honda Car India: Civic - Technology
DIMENSIONS & WEIGHTS
Manual (MT)
Automatic (AT)
Overall Length
4,545 mm
Overall Width
1,750 mm
Overall Height
1,450 mm
Wheelbase
2,700 mm
Min. Ground Clearance
170 mm
Fuel Tank Capacity
50 L
Kerb Weight
1,210 kg
1,240 kg
ENGINEEngine Type
i-VTEC, 1.8L
Configuration / Cylinder
4-Cylinder, In-line
Valves / Fuel
16 Valves, Petrol
Fuel System
PGM-Fi
Displacement
1799 cc
PERFORMANCEMax. Power
132 PS @ 6,300 rpm
Max. Torque
17.5 Kg-m @ 4,300 rpm
TRANSMISSIONType
Synchromesh 5 forward,1 reverse
5-speed AT with Paddle Shift, Grade Logic Control & Shift Lock
SUSPENSIONFront Suspension
McPherson, Coil Spring with Torsion Bar
Rear Suspension
Double- wishbone, Coil spring with Torsion Bar
STEERINGSteering Type
Collapsible, Power Assisted
Min. Turning Radius
5.4 m
BRAKESFront Brakes
Ventilated Discs
Rear Brakes
Discs
TYRES & WHEELS Wheel Type
Alloy
Wheel Rim Size
15 x 6J
Tyres
195/65 R15 (Tubeless)
Manual (MT)
Automatic (AT)
Overall Length
4,545 mm
Overall Width
1,750 mm
Overall Height
1,450 mm
Wheelbase
2,700 mm
170 mm
Fuel Tank Capacity
50 L
Kerb Weight
1,210 kg
1,240 kg
ENGINEEngine Type
i-VTEC, 1.8L
4-Cylinder, In-line
Valves / Fuel
16 Valves, Petrol
Fuel System
PGM-Fi
Displacement
1799 cc
132 PS @ 6,300 rpm
Max. Torque
TRANSMISSIONType
Rear Suspension
Min. Turning Radius
5.4 m
BRAKESFront Brakes
Ventilated Discs
Rear Brakes
Discs
Alloy
Wheel Rim Size
15 x 6J
Tyres
SX4 tech specs from -> Maruti SX4 - E Brouchure
students is offline
Old 9th May 2007, 12:53   #9
HSV
HSV's Avatar
Hey Students, whats the point of comparing the Civic with the Sx4? They are both from different segments. It would make more sense comparing apples with apples.
HSV is offline
Old 9th May 2007, 12:54   #10
Thanked: 3,326 Times
When I test drove Civic MT, I found it a bit slow to take off. A little disappointing. Being a Honda fan and admiror of Civic looks, I walked away blaming it on Deccan Honda, hoping against the hope that thye may have abussed the test drive car so much so that pick up has dropped considerably.
Can this be true? or is Civic really slow?
The pick up did not definately fell worth 12 lacks.
anandpadhye is offline
Old 9th May 2007, 17:30   #11
Thanked: 39 Times
Civic pickup was slow? The car revs to redlines without any problems and pickup is like mad. the low end grunt is missing if that's what you are looking at. If you have slotted to the 5th by 50kmph then you are going to have sluggish pickup.
csentil is offline
Old 9th May 2007, 17:39   #12
Thanked: 39 Times
By the way, I've been getting the argument from morning that the SX4 is better than the Civic. :-)
You are comparing across segments. Its like saying a Swift ZXi is better than a NHC Vtec because it comes loaded with a lot more features than the Vtec.
Ground clearance is 170mm the same as a Corolla, if my memory is right. But the wheelbase is longer, so it tends to scrape speedbreakers when under heavy load. I have a couple of bumps near my house. I don't scrape them when I'm alone or with my wife. But when there are 5 people or 4 people with luggage in the boot, it does scrape. Go lightly over the bump and you will make it without a problem.
Civic is in a different league compared to the NHC Vtec.
Mileage should be around 9 kmpl. I own an AT and I get 8 kmpl. Expect higher fuel bills as I'm sure you can't keep a light foot on the gas pedal !!
Honda has traditionally been low maintenance. But since its a higher segment car, the prices are bound to be higher.
csentil is offline
Old 9th May 2007, 23:19   #13
Jaggu's Avatar
Thanked: 16,204 Times
am not sure but i guess the civics will have a similar bill compared to that of Crv, they are from similar platform and are CBU if am not wrong?
Crv regular service ranges between 2-3 k Rs every 5000 km here in bangalore, good part is the cost is uniform and hasnt varied too much irrespective of kms, finished 30 k till now.
Again body parts/spares are exorbitant egs side rear view mirror cost 12k Rs, most parts are imported and at times delay in availability of the same
Jaggu is offline
Old 9th May 2007, 23:55   #14
iraghava's Avatar
Thanked: 272 Times
They are both based on the same platform yes but the Civic is not a CBU. It's assembled in Honda's Greater Noida plant.
iraghava is offline
Old 10th May 2007, 00:09   #15
Thanks guys.... this helps a lot
autoxxx is offline
