Re: Bangalore - Pune - Mumbai : Route updates & Eateries Thanks to the admins for approving my account, this is my first post on the forum so kindly excuse me if there are any rookie mistakes in the post.
I recently did Pune -Bangalore - Pune journey using both the route Options (Onward via Kolhapur/Belgaon and return via Vijaypura/Solapur).
I travelled from Pune to Bangalore on 23rd December. Started the from Hadapsar, Pune at 5:30 am but encountered a significant traffic all the way due to holiday rush. The Journey from Karad to Belgaon as everyone pointed out was very painful with many diversions and it slows you down significantly. The Road after Belgaon till Tumkuru is still pretty smooth (except for Hubballi-Dharwad bypass). Overall the drive time was 14 hours and breaks of almost 3 hours.
I returned from Bangalore to Pune on 7th January. For the return journey I was in dilemma whether to stick to the regular route or try the new route via Solapur. My preference was to have a peace of mind in the journey considering the horrible time I had while coming via Belgaon, and since we were carrying food I thought of taking the plunge and took the route via Hospete-Solapur. We had started from Bangalore at 5 am and managed to cover the distance till Chitradurga till 8:30 am where I had to decide which route to go for. Overall as many people have mentioned the eatery options are less on this route, the road is 4 lanes throughout till Pune (except for a couple of bypasses which are 6 laned). The road condition is pretty good and the less traffic on this route till Solapur helps you not miss the 6 laned road on the existing highway till Belgaon. Probably the best road on this route option. You just cruise through the road with absolutely no issues regarding the road surface while enjoying the nice scenery and large number of wind mills on both side of the road. The Bypass for Hospete is 6 lanes, though not the smoothest surface but still you can cruise just around 3 digit speed. Again a 4 laned road, however there are speed bumps at many intersections, the worst part; A few of these speed bumps are absolutely unmarked and would take you by surprise. Though you can still cruise on this section, but you need to be watchful of these speed bumps appearing suddenly. I observed that the road section near these Speed bumps is relatively darker than rest of the road so that kind of helped predict the approaching speed-bumps and slow down the vehicle. Last section where you can cruise through without much of an issue due to low traffic. The road is in better condition and the Speed bumps are gone so you are not caught off guard because of that in this section. This road needs to be expanded to 6 lanes. The current road though pretty smooth cannot take the huge volume of traffic. The drive from Mohol all the way till Pune is bit painful as the entire stretch is full of reckless drivers which would give you tough times and to make matter even worse, there are few diversions due to ongoing bridge work which leads to congestion. Overall this stretch you can compare with Tumkuru-Nelamangala section albeit for more than double the distance though!
Overall the drive time was 12:30 hours and 3 hours of stops. Personally I would prefer to use the Solapur road for any journey to Bangalore till the time Option 1 gets to the better condition as it was around an year ago! Note:- Option 2 is suitable only if you intend to go to any eastern part of the Pune, otherwise you may need to traverse through entire Pune city.
- Limited food options available throughout the route between Chitradurga-Solapur.
- Though there are ample number of Petrol Pumps on this stretch throughout, if you are looking for any specific branded fuel (XP95, SPEED, POWER) then there availability is sparse on this route. I couldn't find XP95 on any of the Indian Oil fuel pumps, including an IOCL COCO right outside the IOCL Depot!
