Old 7th October 2010, 12:09   #16
ampere's Avatar
Thanked: 13,288 Times
Google Maps show ECR as NH45A beyond Pondicherry and it gets over at Nagapattinam.
Is that correct?
ampere is offline
Old 7th October 2010, 12:12   #17
hvkumar's Avatar
Thanked: 3,463 Times
ampere, forget GM. I tested its knowledge, it has broken links between Kizhakarai and Sayalgudi via Eravadi! Hence, despite my dragging onto the correct route of ECR, it could not draw the route map.
Anyway, NH45A is only part of the ECR, which runs from Madras to Kanyakumari on teh following route:
Madras-Mahabalipuram-Pondicherry-Cuddalore-Chidambaram-Karaikal-Nagapattinam-Thiruthuraipoondi-Muthupettai-Mimisal-Tondi-Ramanathapuram-Kizhakarai-Sikkal-Sayalkudi-Tuticorin-Tiruchendur-Koodankulam-Kanyakumari
hvkumar is offline
Old 7th October 2010, 17:25   #18
Thanked: 310 Times
Kreddy: I am not sure if this is going to be late for your to change your plans. Let me give you an alternate plan which would mean you visiting a couple of more temples in the bargain.
Day 1 : Start around 5 AM from Bangalore - Reach Tiruvannamalai around 10 continue onwards to Tirukoilur after darshan at Tiruvannamalai visit Tirukoilur temple then continue onwards to Kumbakonam via Panrutti - Sethiathoppu. You should be able to reach Kumbakonam around 2 PM. Finish Lunch and then have one round of temple seeing in the evening in and around Kumbakonam. Stay overnight at Kumbakonam.
Day 2: Morning finish one more round of temples around Kumbakonam continue onwards to Tanjore, finish Tanjore Peria Koil on your way to Srirangam. Evening you can have a relaxed Darshan at Srirangam without any time pressure. May be make a visit to Rock Fort as well.
Day 3 You could reach Rameswaram via Pudukottai as per your original plan. You could also include Thirupullani which is on the way to Kilakkarai from Rameswaram. You could actually enjoy beach as well at Thirupullani.
pypkmsrikanth is offline
Old 7th October 2010, 23:03   #19
Thanked: 36 Times
Thanks everyone.
pypkmsrikanth: Thanks for your suggestion. I am planning to visit Tiruvannamalai & Pondicherry some other time. I will check on Thirupallani beach though.
ravib: I want to visit Palani on the way back. I will take deviation from Dindugal and rejoin NH7 at the same place while returning.
Harshavarthan: If I travel on ECR what would be normal driving time from Thanjavur to Rameswaram ( I will by pass Ramanathpuram as suggested)
kreddy is offline
Old 8th October 2010, 10:22   #20
Harshavarthan's Avatar
Thanked: 154 Times
@kreddy
Thirupallani beach is actually called Sethukarai and is a diversion from Ramanathapuram Kilakarai road. Approximately 15-20 minutes drive from Ramanathapuram by-pass. Plan it on your next day when going to kanyakumari.
Tanjore to Rameswaram on ECR might take 4 to 5 hrs depending on how fast or how slow you drive. Even if you maintain a steady 80 km/h speed (which is slow for ECR), you can reach within 5 hrs. And don't enter Ramanathapuram unless you plan for a meal.
Harshavarthan is offline
Old 29th December 2010, 16:16   #21
sbkumar's Avatar
Thanked: 162 Times
Re: Guidance required on Tamil Nadu Tour
Guys, Any update on Tiruchendur-Kanyakumari ECR condition? Any recent trip updates would be really useful. I am planning to do this route tomorrow and could not get enough information on the road conditions.
sbkumar is offline
Old 29th December 2010, 16:34   #22
hvkumar's Avatar
Lots of potholes, has taken a beating in the recent rains. Slower speeds.
Update from 2 days ago.
hvkumar is offline
Old 29th December 2010, 16:57   #23
sbkumar's Avatar
Thanked: 162 Times
Thanks a lot Sir! That was really fast. Would you recommend any alternate routes? Would be starting from Nagercoil.
sbkumar is offline
Old 29th December 2010, 17:00   #24
hvkumar's Avatar
Alternative route would be to go from KK onto NH7 and turning off at either Valliyoor or Tirunelveli, but that will be much longer.
If you are a patient driver - and driving by day - the ECR itself is not a bad idea despite its slightly bad condition.
hvkumar is offline
Old 29th December 2010, 17:14   #25
sbkumar's Avatar
Thanked: 162 Times
okay, then ECR it is. I would be starting early morning and hence would be a good time to do this I guess.Thanks a lot again. Will update with my experience tomorrow.
sbkumar is offline
Old 29th December 2010, 20:09   #26
Thanked: 154 Times
Why not drive via ECR till thuthukudi and then to kanyakumari via tirunelveli? I believe ECR till thuthukudi might not have been affected by rain.
Old 29th December 2010, 22:03   #27
sbkumar's Avatar
Thanked: 162 Times
Harsha, my drive is only from KK/NGL to Tiruchendur tomorrow.
sbkumar is offline
Old 29th December 2010, 23:28   #28
hvkumar's Avatar
ECR from Ramanthapuram to Tuticorin is in immaculate condition, as fast as ever, no impact of rains.
hvkumar is offline
Old 31st December 2010, 11:07   #29
sbkumar's Avatar
Thanked: 162 Times
Update on my trip:
Since the start got delayed, decided to go through valliyoor so that we can have breakfast there.
Route - NGL-Valliyoor-Mannarpuram-Sathankulam-Megnanapuram-Paramankurichi-Tiruchendur.
Upto Valliyoor on NH-47.
Get into the Valliyoor town and from the first signal, need to take a right onto the Radhapuram road and around 5kms from this point, need to take a left onto the Tiruchendur road.
Valliyoor-Tiruchendur on this route is around 66kms.
The roads are pretty good two lanes though a little narrow. First 20kms and last 20kms are really good and middle 20kms are with a little bit of rough patches especially within the towns, but nothing to worry about. There are around 7-8 humps which are marked with sign boards which were visible in the day but difficult to find in the night. Travel time 1 hr 45 mins with relaxed driving around 70/80 for most of the time.
The only problem I saw was that though we can just follow the signboards and reach Tiruchendur once we take the Radhapuram road from Valliyoor, the signboards are in Tamil in most places so people who can't read Tamil will have a difficult time following them. Else it was a pretty straight forward drive.
sbkumar is offline
Old 20th September 2012, 17:00   #30
Thanked: 1,855 Times
Folks,
Bumping up this old thread, as i couldn't find more related thread elsewhere.
How is the road conditions from Kumbakonam-Mannargudi-Pattukkottai-Aranthangi-Karaikudi.
Though i can take Kumbakonam-Tanjore-Pudukkottai-Karaikudi, would like to try this route so that i can see Mannargudi Rajagopalaswamy temple and Aavudayar Koil near aranthangi enroute from Kumbakonam to Karaikudi.
Anyone traveled in this sector recently and can provide a road condition update?
-Ravi
ravib is offline
