Old 29th May 2017, 11:50   #316
inder's Avatar
Thanked: 101 Times
Re: Hyderabad to Nagpur : Route Queries
Just saw your post. Yes I did travel, but by now you too must have travelled. Anyway for other members here is the update. The road near Pandharkawda has a lot of diversions and undulations. Whereas the stretch between wadki-wadner is smooth tarmac although 2 lanes and couple of diversions.The railway crossing in Hinganghat is still a bottleneck,though it might get completed in a month or two. Did Gachibowli to Nagpur Airport in 6 hrs. No eateries as expected.
inder is offline
Old 30th May 2017, 11:26   #317
Thanked: 48 Times
Yes, travelled to Nagpur on 27th and returned on 28th. There is marked improvement in the two stretches in Maharashtra since I travelled last in May 2016. There are no potholes and the roads are drivable. The toll booths have also increased. Now Hyderabad to Nagpur can be comfortably done in 6 hrs with 2 short breaks.
envyravi is offline
Old 4th June 2017, 04:44   #318
agd19682's Avatar
Thanked: 31 Times
I travelled from Bangalore to Jabalpur via Hyderabad during Jan-Feb, 2017. While coming back from Jabalpur, I jotted down the names of each of the toll plazas along the way. While coming back, I travelled via the Narsingpur-Chinddwara route because the forest area between Seoni and Nagpur had a lot of diversions and the road condition was pathetic.
Hope this helps those who might be planning to travel along this route...
JBP-BLR Trip Sheet.xlsx
agd19682 is offline   (1) Thanks
Old 4th June 2017, 05:06   #319
Thanked: 498 Times
Thanks for the update.
Is the Narsingpur - Chindwara - Nagpur is tolled?
gajadonga is offline
Old 4th June 2017, 07:56   #320
J.Ravi
Posts: n/a
Yes, 3 toll plazas, IIRC; perhaps, serial-numbered 2,3 and 4 of the attached Excel sheet of post number 318.
Old 4th June 2017, 12:45   #321
agd19682's Avatar
Thanked: 31 Times
Yep, this stretch is tolled, but the road conditions are very good. You can easily cruise at 90+ speeds.
That is correct. The initial 3 booths are for the same stretch.
agd19682 is offline
Old 20th August 2017, 17:24   #322
baahubali's Avatar
Thanked: 18 Times
How is the stretch between Adilabad and Buti Bori now? It was pathetic last year around October. Have they completed the road construction?
baahubali is offline
Old 21st August 2017, 10:57   #323
inder's Avatar
Thanked: 101 Times
Adilabad -Butibori is better now ,although not complete. Its not 4-lane but the surface has improved a lot. Road work is going on at some places.
inder is offline
Old 22nd August 2017, 12:17   #324
baahubali's Avatar
Thanked: 18 Times
Thanks Inder.
6hrs from Gachibowli to Nagpur Airport is too good. Which vehicle were you driving? Also, what time of the day were you traveling in?
Old 23rd August 2017, 10:03   #325
inder's Avatar
Thanked: 101 Times
Was driving an XUV. I started at about 6 in the morning both ways.
inder is offline   (1) Thanks
Old 24th September 2017, 13:42   #326
Vipin Kumar's Avatar
Thanked: 717 Times
Any further updates on the Pandharkhwada stretches? Can anyone let me know?
Vipin Kumar is offline
Old 24th September 2017, 22:18   #327
Thanked: 48 Times
I traveled from Hyderabad to Nagpur and back on 14th and 16th, there is no change in the road conditions from what I had seen in May/June 2017. Works are still going on at a leisurely pace.
envyravi is offline
Old 1st October 2017, 11:07   #328
ethanhunt123's Avatar
Thanked: 1,035 Times
I traveled on this route a couple of days back - there is still some 100km stretch which is bad with diversions, potholes etc. Construction seems to be happening in a few areas including the Rail overbridge at Hinghanghat. Also - very few toll booths seem to accept Fastag :(
ethanhunt123 is offline
Old 2nd October 2017, 10:13   #329
inder's Avatar
Thanked: 101 Times
Just read in the newspapers that the Flyover near Borkhedi (closer to Nagpur) is now opem both ways. And the Railway Overbridge at Hinganghat will be open for traffic this month.
inder is offline
Old 3rd October 2017, 22:00   #330
agspins's Avatar
Thanked: 532 Times
Just came from a trip to Hyderabad, yes the Borkhedi Flyover is opened for both ways. AFA Hinganghat Over bridge goes, still plenty of work left on the section above railway lines. 75 Kms between Hinganghat and Pandharkawda will take another year or more, and is painful when compared to whole route (Ngp-Hyd). Also some stretch between Hinganghat and Pandharkawda is under litigation from Villagers.
agspins is offline
