Old 27th June 2017, 13:03   #10621
Thanked: 248 Times
Re: All Roads to Kerala
Did a Bangalore - Edappally (23rd) - Bangalore (26th) trip recently via the Salem - Walayar - Kuthiran route. A few observations:
Salem flyover construction is making good progress but still a long way from completion. However the service roads are holding up fine. Traffic flow was also smooth.
L&T bypass Coimbatore - Getting to be more painful. Figured there are 10 pain points and I mentally cross each one out to ease the pain - 6 toll booths, 2 signals and 2 bridges.
Exit to Coimbatore at Neelambur via the flyover is completed and functional now. However on my return they had blocked the main highway after the last toll booth at Neelambur and traffic was diverted via the service road from Coimbatore side. The service road goes for a fair distance before you can enter the highway. This can be a bottleneck if they keep the main highway blocked. But it must be a very short term issue and they should open it up soon.
Madukkarai - Walayar section has made decent progress. No more diversions. Most of the flyover and culvert joints are smooth now.
Walayar - Vadakkunchery section is becoming a pain with a lot of signals and more waiting to be added.
Vadakkunchery - Mannuthy section has good surfaces where work has been completed but otherwise has started developing small craters which you can avoid by watching out for them early. Kuthiran tunnels should be done soon and then it will be a welcome relief. Surprisingly I didn't face much hold up at Kuthiran this trip.
Aluva - Edappally section is now smooth. Metro work is over. Traffic flow is patchy with right turns taking up the right lane, bus stops and random slow vehicles blocking up the left leaving you to zig zag a bit to keep moving.
Faced the full monsoon fury for my entire drive back on 26th from Aluva all the way till the border but it was an amazing drive.
This was also my first trip with my newly acquired Fast Tag. It worked for me at all tolls (except of course NICE road and L&T bypass). Only in 2 or 3 places the lane itself was not managed well but otherwise it was smooth sailing.
Mnjdnght is offline   (2) Thanks
Old 28th June 2017, 08:06   #10622
Thanked: 6,084 Times
Now there are no diversions on Madukkarai - Walayar section. The entire carriageway is open for traffic.
There are no diversions on Walayar - Madukkarai either. So here's the status:
  • The carriageway and flyovers are complete till (but excluding) the Coimbatore exit at Madukkarai.
  • The Coimbatore exit which is a flyover on the main NH carriageway and a junction underneath is only about 40-50% constructed.
  • There is construction debris on certain lanes that you need to watch out for.
  • The planting of trees on median is probably yet to start (there are grass patches though).
  • In some places the median itself needs some mason attention.
  • Lane marking are not done at all. If they plan to install cat's eyes then that is also pending.
  • There are no signages on the road.
Originally Posted by guruji View Post
Originally Posted by A350XWB View Post
Reached Coimbatore and there was a medium sized queue at the by-pass toll.
Exactly! Is there a way to bypass this road??
Is it just me who is struck by the irony of this situation (that we now feel the need for a bypass for a bypass)?
If you are coming from Ernakulam side then you could consider Vadakkanchery (or Alathur) > Kollengode > Pollachi > Palladam and joining the NH 544 somewhere (I prefer Palladam > Kangayam > Perundurai but YMMV). The KL side of this route is a bit narrow at places and can be a hassle during regular traffic hours but the TN side is all brilliant.
The Trichy Road (NH 81 it seems) junction is particularly nasty; with a 90-second red / 20-second green cycle for the bypass. Yesterday it took me 4 cycles to pass through the junction. Granted that the radial traffic is much higher than the bypass traffic; but at the very least isn't it time to think about a few interchanges or flyovers on this bypass?
Btw, there are many more unsignalled junctions that are even worse pain-points. But mentally crossing off them is a good idea to ease the pain; will try that next time. :-)
binand is offline   (2) Thanks
Old 28th June 2017, 10:13   #10623
pramodpk's Avatar
Thanked: 630 Times
Drove Bangalore - Trivandrum and back.
Started at 5:00 AM on 23rd from Whitefield and reached Kesavadasapuram at 4:30 PM. Took the NH7 route and reached Kaval Kinar at 1:50 PM after breakfast, lunch and 2 fuel breaks. From Kaval Kinar, took the Boothapandi, Vellarada -Kattakkada - Peyad - Sastamangalam - Vellayambalam route.
This route has less traffic and is very peaceful. The stretch between Boothapand i and Vellarada is broken at many places. This will slow you down. The route is also twisty. Total distance - 757 KMs. Drive time 10 hours 15 mins
Started at 5:30 AM on 26th from Kesavadasapuram and reached HSR layout at 4:30 PM. Took the NH47 to Kaval kinar. Reached Kaval Kinar at 7:50 AM. There is a long detour to avoid Marthandam which increases the distance by 8 - 10 KMs. Reached Salem at 1:00 PM. Total distance to HSR 747 KMs. Drive time 10 hours.
pramodpk is offline   (1) Thanks
Old 28th June 2017, 14:47   #10624
silversteed's Avatar
Thanked: 2,235 Times
A little birdie tells me that there are around 20 speed cameras going to be installed between Walayar and Vadakkencherry. Since this is not yet official, take it with a pinch of salt.
By the way, Vadakkencherry (വടക്കഞ്ചേരി) is the place that NH47/NH544 passes through. The other one, on the Thrissur-Shornur road, is Wadakkanchery (വടക്കാഞ്ചേരി). The former has a KSRTC Operating Centre (Code: VDK) but no railway station, while the latter has a Railway station (Code: WKI).
Vadackumchery is the surname of an author who specialises in Criminology, Police and Judiciary - Dr. James Vadackumchery
That junction is always a nightmare. One must always be wary of cross traffic even when the signal is green for the traffic on the bypass. My SOP is to stay behind a large truck at the signal - size is the only thing that deters signal jumpers; smaller vehicles can be and will be intimidated by blaring horns, by the buses.
silversteed is offline   (1) Thanks
Old 29th June 2017, 10:19   #10625
Thanked: 637 Times
I know this response may not be of much help since you completed your trip already, But some answers nevertheless, may be of use in future.
Anyone's taken the Bangalore-Dimbam-Coimbatore-Palakkad route recently? I have three questions:
1. What is the best route to take between Malavally-T. Narasipur since I want to avoid Kollegal? Google Maps is showing a road closure on Kirugavalu-Sosale, so I guess I should take either Bannur-Sosale or Purigali-Sosale to get to T. Narasipur and then onwards to Ch. Nagar. I don't want to go into Talakadu.
The best route as of now is Malavalli-Kirugavalu-Sosale-T.Narsipur (the one that Google shows as closed). The road is very much open - I reported this to Google Maps at least 3 times, but looks like their response time for reopening roads reported as closed is quite poor.
2. What is the correct route to go through Bhavanisagar if one doesn't want to go to Satyamangalam? Google is showing this:
Attachment 1650853
Is that correct?
Yes, that's correct, but after a few trips through those roads I've shifted back to the route via Sathy. There are some bottlenecks on that Bhavanisagar route where the road is quite narrow and you could get stuck when there are buses going in both directions. (Especially the narrow road just before the T junction at Mudukkandurai - very near the last point you've marked - where there is a bus stop where buses stop for a long time causing frequent jams ). Even though passing Sathy town is bit painful, you hardly ever encounter traffic jams there.
3. Is it OK to drive Annur-Coimbatore-Madukkarai-Palakkad, given that I'm driving through here on a Sunday? Or will I get stuck in Coimbatore's traffic?
Haven't tried that for a long time, so not sure. Nowadays I take the Kurumbapalayam-Coimbatore airport road via Kalapatti which is quite decent in terms of traffic density at most times. But that won't help you "bypass" Coimbatore bypass if that was your intention
kala is offline   (2) Thanks
Old 29th June 2017, 10:40   #10626
Yep, thanks. I went the GQ route eventually because of predicted rains, Id-related increase in traffic / footfall on roads and certain other considerations that made it unviable for me to be on road for about 12 hours.
Nowadays I take the Kurumbapalayam-Coimbatore airport road via Kalapatti which is quite decent in terms of traffic density at most times. But that won't help you "bypass" Coimbatore bypass if that was your intention.
Yeah, doesn't really help. What do you do after the airport? Backtrack along Avinashi road to Neelambur junction?
binand is offline
Old 29th June 2017, 15:27   #10627
Thanked: 108 Times
We are planning to take punalur - shenkottai- madurai route on the way back. Any idea on the road conditions on this route? Has anyone recently travelled via punalur - shenkottai - madurai route?
Roads are all good all the way till madurai, except in Rajapalayam town which is a mess due to road works in progress. FasTag didn't work at two tool booths :
kappallur NAHAI toll
kodai road NAHAI toll plaza
guruji is offline
Old 1st July 2017, 15:46   #10628
Thanked: 637 Times
Yes, you do have to backtrack 1 to 1.5 km towards Avinashi to reach a road connecting to the bypass (About 1 km before you reach Neelambur junction). That way you can also avoid one toll gate stop on the bypass - the entry one (you need to pay for the toll at the Trichy road exit).
Old 10th July 2017, 10:02   #10629
pramodpk's Avatar
Thanked: 630 Times
Kuthiran tunnel will not be open till year end. See the news below.
http://english.mathrubhumi.com/news/...ture-1.2073772
pramodpk is offline   (2) Thanks
Old 10th July 2017, 11:41   #10630
NPV
NPV's Avatar
Thanked: 11,168 Times
This was definitely expected. Even during my last trip in January on this stretch, I thought there was too much work remaining to be competed by June/July this year, even outside the tunnel (with the bridge that leads in to the tunnel). With monsoons, it becomes a challenge to progress on work outside the tunnel, hopefully end of the year it will become a reality.
NPV is offline   (1) Thanks
Old 10th July 2017, 14:53   #10631
Pequod's Avatar
Thanked: 789 Times
Planning Kochi-Goa second week of August. Is it better to go via Bangalore Hubli, or Mangalore Karwar? Any update on latest road conditions in the North Kerala-Mangalore area?
Pequod is online now
Old 10th July 2017, 16:56   #10632
Jaggu's Avatar
Thanked: 17,278 Times
BLR route would be any day better since you will have four lane road from cochin to hubli. On the other hand via kerala and mangalore you are restricted to two lane roads most of the way till goa.
Jaggu is offline   (1) Thanks
Old 10th July 2017, 17:09   #10633
Thanked: 321 Times
The traffic density on the Cochin-Mangalore route is very high and progress is really slow. In addition, the private buses on this route are very dangerous. You will be better off taking the Bangalore Hubli route.
SajiNSalin is offline   (1) Thanks
Old 20th July 2017, 19:16   #10634
procrj's Avatar
Thanked: 5,727 Times
Perumapady bridge on Thalsaserry Iritty road damaged
Source & Pic credits - https://www.facebook.com/photo.php?f...type=3&theater
procrj is online now   (2) Thanks
Old 21st July 2017, 12:27   #10635
pramodpk's Avatar
Thanked: 630 Times
Read a report in Mathrubhumi that one side of flyover will be opened to ease the traffic congestion between Thenidukku and Vadakkencherry on NH 47.
For those who can read Malayalam, here is the link.
http://www.mathrubhumi.com/palakkad/...heri-1.2103042
