Old 25th September 2016, 23:19   #9811
cooljai's Avatar
Thanked: 28 Times
Re: All Roads to Kerala
Plan to drive from Bangalore to Kerala (Chengannur) this week, either Thursday or Friday, with wife and two kids.
In light of the recent events, which route is preferred?
If we take Salem- Coimbatore route, which are all the places that are generally affected by Kaveri agitations the most?
Does it make sense to start early morning (4 Am) or would you suggest later in the day (after 12 Pm)?
cooljai is offline
Old 26th September 2016, 10:13   #9812
pramodpk's Avatar
Thanked: 630 Times
I plan to drive from Bangalore to Vaikom on October 1st. Want to avoid Tamil Nadu and hence will go via Mysore.
Route Planned is
Whitefield - Mysore - Sultan Bathery - Kunnamkulam - N Paravur - Vaikom
Google maps shows 2 options to go from Kalpetta to Kunnankulam.
Option 1 - Kalpetta - Areacode - Perinthalmanna - Pulamanthol - Pattambi
https://goo.gl/maps/Qfa2g9rgf6M2
Thanks in advance
Option 2 - Kozhikode (by pass) - Kottakkal
https://goo.gl/maps/djGGqHsqCoR2
Which one would be better? Any other option?
pramodpk is offline
Old 26th September 2016, 12:39   #9813
silversteed's Avatar
Thanked: 2,235 Times
I drove to Kerala (Palakkad, to be specific) via Salem over the weekend. Left Bangalore at 10pm, and reached our place by 4am. Sparse traffic all along NH-7 / NH-47. Since my car was neither KA nor TN registered, both KA and TN cops had waved me off at the respective border checkposts at Attibele.
On the return, we started at 6 o'clock in the evening and was in Bangalore by midnight. Again, same story. Sparse traffic. I felt it was a good idea to have started by 6, so that we reached Attibele at around 11:30pm. Else there would've been a longer queue of vehicles, as TN vehicles were not allowed into KA, and vice versa - trucks need a lot more time than smaller vehicles to make a full U-turn, hence the hold-up.
Except for the sparse traffic, everything else seemed quite normal to me. There was an incident in Coimbatore city when an activist was killed and his supporters resorted to some violence on friday evening, but that did not seem to have any effect on the bypass or the highway
silversteed is offline   (1) Thanks
Old 26th September 2016, 13:00   #9814
cooljai's Avatar
Thanked: 28 Times
Thanks, my drive is KA registered, and that's my worry! Is TN police not allowing KA vehicles into Attibele?
cooljai is offline
Old 26th September 2016, 13:01   #9815
Rajeevraj's Avatar
Thanked: 19,118 Times
Thanks in advance
Stick to option 2 via Kozhikode Bypass. The first one may be slightly less on traffic, but will take the same or more time. The first route is pretty much made up of smaller roads and although the road conditions should be good, will not give you any real benefit.
Can also look at Kottakkal-Kuttipuram-Chamravattom-Chavakkad-N.Paravur route (to Vaikom)
Rajeevraj is offline   (1) Thanks
Old 26th September 2016, 13:43   #9816
Your best bet is the Mysore route. At Attibele, KA cops were seen asking KA registered vehicles to turn around and go back, while TN cops were doing the same to TN registered vehicles across the border.
Old 26th September 2016, 14:16   #9817
cooljai's Avatar
Thanked: 28 Times
Thanks, so it seems the only option left for me is through Mysore- Wayanad. How much time would it take to reach Trichur, if we go in for a 4 Am start from Kammanahalli?
cooljai is offline
Old 26th September 2016, 15:10   #9818
Rajeevraj's Avatar
Roughly between 7 and 8 hours driving time to Calicut and ~3.5 hours from Calicut to Thrissur. So total around 11-11.5 hours. May be currently a little bit more since I assume there will be lot of vehicles trying to take this route to Kerala to avoid TN.
Old 26th September 2016, 15:11   #9819
Thanked: 1,482 Times
The last time I made this trip (which was the day after the bandh & bus burning incident at Bangalore) it took me 13 hours to reach Trichur. I started off from EC are by around 1200hrs, and did reach Vythiri (Wayanad dt.) by around 1815Hrs. This was with a 45 min lunch break. I went via Kanakapura. What did me in was the infamous Thamarasseri churam (ghat road) where I got stuck for 3 hours. It was only by 2115Hrs I was out of this area, then had to break for 30 mins for dinner. Reached Thrissur by around 0100Hrs.
sachinpk is offline   (1) Thanks
Old 26th September 2016, 15:35   #9820
cooljai's Avatar
Thanked: 28 Times
So 12-13 hours seems to be a fair assumption. Considering Kerala traffic, does it make sense to start a bit late from Bangalore, so as to hit Kerala during the night?
Is it safe to drive through those roads after nightfall, or would you suggest an early morning start?
cooljai is offline
Old 26th September 2016, 15:54   #9821
arun_josie's Avatar
Thanked: 14,871 Times
Originally Posted by arun_josie View Post
Has anyone done Mysore - Wayanad - Guruvayur - Cochin - Trivandrum recently? If so, how is the route condition and how much time does it take? Google Map says 14 hours. I may take this route to avoid TN route due to the current issues.
I see one more KL route from Bangalore/Mysore to Trivandrum. Which one would be better in terms of road conditions? Google timing/distance is similar for both the routes.
Route 1:
Route 2:
arun_josie is offline
Old 26th September 2016, 15:56   #9822
pramodpk's Avatar
Thanked: 630 Times
Route 2:
Please note that both routes pass through TN - Gudalur - Nilambur.
Route 1 would be slightly better I guess as road work is happening in route 2 between Kottayam & Chengannur.
If you want to avoid entering TN, go via Sulthan Bathery - Kalpetta.
pramodpk is offline   (1) Thanks
Old 26th September 2016, 16:02   #9823
I always prefer an early morning start (at around 0400Hrs), and avoid driving after night fall. When we started from Thamarassery town at around 2200Hrs, the roads were getting empty. Yes, I could increase the speed a bit but with wife and a small baby, it was not a very relaxed drive. From Kozhikode byepass till Perumpilavu, there were some vehicles (and police patrols) which were moving. After Perumpilavu when we moved through Kunnamkulam etc. there was not a soul out there on the roads. It worried me a bit, if my vehicle got broken down.
Old 26th September 2016, 16:57   #9824
arun_josie's Avatar
Thanks pramodpk. So, via Kalpetta means, I think Route 1 is better.
Old 26th September 2016, 17:02   #9825
pramodpk's Avatar
Thanked: 630 Times
Route 1 should be better. Expect to take around 19 - 20 hours to reach Trivandrum if you start by 5:00 AM from Bangalore.
pramodpk is offline   (2) Thanks
