Old 4th August 2012, 10:44   #511
arun_josie's Avatar
Thanked: 14,237 Times
Re: Bangalore to Coimbatore round trip - Update
I am driving to Coimbatore from Bangalore, the destination in Coimbatore is Saravanampatti. So, will be taking Bangalore-Salem-Avinashi-Annur-Saravanampatti route. Taking this route(annur) for the first time so would like to know the following,
Is it easy to find the right to Annur after crossing Avinashi and again the left from Annur?
How is the road condition and how much time(approx) will it take from Annur to Saravanampatti?
arun_josie is online now
Old 4th August 2012, 11:52   #512
Thanked: 469 Times
Avanashi bypass is open if you take that road you have to take a U turn and come back to reach the road to Annur.
If you passby the Avanashi town then after crossing the town the signboards
are well marked so it should not be a problem.
Travelling in the day then you might take about 5-10mins to cross Annur sometimes.
It might take 45mins-1hour to reach Saravanampatti.
Hope this helps.
gajadonga is offline   (1) Thanks
Old 4th August 2012, 21:28   #513
arun_josie's Avatar
Thanks gajadonga, any toll collection in the Avinashi bypass? If so, I will avoid this bypass.
Old 4th August 2012, 22:38   #514
coolclouds's Avatar
Thanked: 519 Times
No tolls as of now at Avinashi.
coolclouds is offline   (1) Thanks
Old 6th August 2012, 15:30   #515
Thanked: 67 Times
I am planning to drive to Cochin this weekend. Is there any good place for overnight stay (with family) near Avinashi (so that i can start from Bangalore on Fri itself)? Something like Anamalais in Udumulpet?
Jeep is offline
Old 6th August 2012, 15:53   #516
pramodpk's Avatar
Thanked: 630 Times
Check out this thread.
http://www.team-bhp.com/forum/route-...ngalore-4.html
You can try.
1. Hotel Chennis -Perundurai
2. Hotel Rithanns -Before Coimbatore bypass
3. Hotel Saravana Bhavan - Sankari
Hotel Saravana Bhavan would be the best of the lot followed by Chennis.
pramodpk is offline   (1) Thanks
Old 7th August 2012, 09:56   #517
arun_josie's Avatar
Couple of days back I drove to Coimbatore and came back, while going I totally missed Avinashi entry point. I didn't know where the bypass road for Avinashi started, realized it only after reaching Karumathampatti. Hence drove till Coimbatore airport, then took the Kalapatti main road to reach Saravanampatti.
While returning I took the Annur route and the road was excellent with no potholes and took only 40 minutes to reach Avinashi. Traffic was very less and hence I was able to maintain 80-90. After joining the highway I looked if there are any signboards indicating the entry point for Avinashi before the bypass(While coming from Coimbatore) but couldn't find any. So if any one wants to enter Avinashi then you will have to be very careful not to miss the entry for Avinashi.
Also, in all the new fly-overs after Avinashi the center point of the flyover is very uneven which will make you to brake. So, beware of this when you are crossing this stretch.
Old 13th August 2012, 11:21   #518
AltoHoncho's Avatar
I am travelling to Kottayam on Aug 15th but would be starting on Aug 14th late afternoon for coimbatore, planning a halt there and then the next morning to Kumarakom for two days and then to Munnar for the next 3 days.
I have booked the night accomodation at Hotel KK Residency in Coimbatore @ Sstri Road, so in order to reach there, which route is advisable post Avinashi? Any inputs about the hotel mentioned above would also help.
AltoHoncho is offline
Old 13th August 2012, 11:35   #519
ranjitp1's Avatar
Thanked: 1,930 Times
Take the NH47 and just before the L&T Bypass road at the signal,take a right and go towards CBE airport.Straight at the signal would take you to the L&T bypass.Keep on the Avinashi road and go beyond the airport.Here is the GM link to the hotel.Nothing great about the hotel,usual budget place.Havent stayed there.
https://maps.google.co.in/maps?q=Avi...t=m&z=17&via=1
ranjitp1 is offline
Old 13th August 2012, 11:43   #520
ampere's Avatar
Thanked: 13,383 Times
I would say best is go to Annur and take the NH209 (Kanakpura road). From Google maps, I see the hotel to be very close to Central Bus stand off the NH209.
Hence suggesting to take the Annur option.
ampere is offline
Old 13th August 2012, 11:48   #521
AltoHoncho's Avatar
Thanks Ampere, but I would start from Bangalore at about 3PM tomorrow with family, do you still suggest I should take the kanakapura route? or Is it advisable to take the GQ route?
Old 13th August 2012, 11:52   #522
ampere's Avatar
Sorry I did not mean suggesting Kanakpura road. I meant take GQ till Avinashi.
At Avanshi divert to Annur and then come to CBE via NH209.
Hope that clears it !
Here is what I was referring to :
Route Link
ampere is offline
Old 13th August 2012, 13:37   #523
Arun.K's Avatar
Thanked: 48 Times
Route Link
ampere, a small last stretch of Gokhale street is a No Entry, while coming from Cross-cut road.
AltoHoncho, except for a small deviation, you can follow ampere's route link. You have to take the previous left from Cross-cut road to reach Sastri road. Here is the link. In case, if you need an alternate accommodation, you can try Hotel Sri Lakshmi, inside Lakshmi Complex on the Cross-cut road.
Arun.K is offline   (1) Thanks
Old 13th August 2012, 17:34   #524
AltoHoncho's Avatar
... I meant take GQ till Avinashi.
Route Link
Originally Posted by Arun.K View Post
...You have to take the previous left from Cross-cut road to reach Sastri road. Here is the link. In case, if you need an alternate accommodation, you can try Hotel Sri Lakshmi, inside Lakshmi Complex on the Cross-cut road.
Thanks guys, Ampere/Arun, if I could get your contact numbers just in case required.
For the hotel, I had done the booking from makemytrip so as of now I'll go by that, lets see if any changes to this come up on the day. Its just a night-hold that I need, and then morning I would be moving to kumarakom. Any suggestions on that would be welcoming. Thanks again.
Old 13th August 2012, 18:23   #525
Arun.K's Avatar
Thanked: 48 Times
...then morning I would be moving to kumarakom. Any suggestions on that would be welcoming.
Avoid Palakkad-Alathur-Vadakkenchery-Thrissur, it's just only pot-holes in most part of this stretch. Instead take Palakkad-Kulapully-Shoranur-Wadakkanchery-Thrissur.
Arun.K is offline
