Search Forums |
Advanced Search |
Go to Page... |
View Poll Results: What would you choose? | |||
Car with a lower safety rating, but more than just the mandatory safety features | 39 | 12.46% | |
Car with a higher safety rating, but only the mandatory safety features | 274 | 87.54% | |
Voters: 313. You may not vote on this poll |
Search this Thread | 30,450 views |
18th July 2022, 15:45 | #31 | ||||||||||
Senior - BHPian Join Date: Nov 2019 Location: India
Thanked: 6,444 Times
| Re: Choose car with many safety features & lower safety rating or vice versa? Quote:
2017 Ford Ka (Brazil) (also see: 2016 Peugeot 208) 2017 Chevrolet Aveo (Mexico) Also worth noting that the XUV700's excellent side impact structure is possibly because it will be exported to Australia and has been developed for Australasian NCAP tests (=Euro NCAP) which use a much heavier (1300kg vs 950) barrier and higher speed (60km/h). Not to take anything away from Mahindra, it's commendable that they're not stripping down the car in the first place. Quote:
(4) Thanks |
The following 4 BHPians Thank ron178 for this useful post: | Duckdoc, Rohan265, RubberGuru1113, The Rationalist |
18th July 2022, 17:17 | #32 | |
Senior - BHPian Join Date: Mar 2019 Location: Kerala
Thanked: 6,618 Times
A car with 6 airbags but an unstable body-structure is just a felted coffin. No airbag can protect you from the steering column/A-pillar/door/console going through your face/chest/legs as your car folds into you. ESP and all are useful on luxury barges and sports cars with enough power to spin its wheels out easily but useless in the usually underpowered FWD cars sold here. At most, it will interfere with your driving and annoy you. Last edited by Cresterk : 18th July 2022 at 17:19. | |
(3) Thanks |
The following 3 BHPians Thank Cresterk for this useful post: | akannath, The Rationalist, tirumalavoleti |
18th July 2022, 17:32 | #33 |
BHPian Join Date: Oct 2021 Location: Kochi
Thanked: 624 Times
| Re: Choose car with many safety features & lower safety rating or vice versa? Voted for car with higher safety rating. We have seen how the cars with 6 airbag as standard with cost cutting all over shell, fared during crash tests. Even the A pillar crumbled. The safety features may not help much with an unstable shell. |
() Thanks |
18th July 2022, 18:01 | #34 | ||||||||
BHPian | Re: Choose car with many safety features & lower safety rating or vice versa? Quote:
"The protection offered to the driver head was poor due to the hard contact with the steering wheel and for this reason the star capping was applied." That, combined with this excerpt from the assessment protocol: "Exceeding a capping limit generally indicates unacceptable high risk at injury. In all cases, this leads to loss of all points related to the tests." So yes, I shouldn't have oversimplified this circuit. My bad. My point however being that not having airbags as standard was the primary cause of Polo essentially failing with a zero star rating. So any car without front airbags can expect similar results. Quote:
a) The car changes. b) The test criteria changes. Does either of them suddenly make the car unsafe? No. It has still been certified using a set standard, which measures a set amount of force and impact parameters. Does this mean that once GNCAP criteria changes this year, it suddenly renders all Tata and Mahindra 5 star scoring cars unsafe? No. They would simply move from being a 5 star of the current era to maybe a 4 star of the next era. If tomorrow they say that any car without side airbags gets a zero, fine. But these results of the structural integrity results still hold true. Even the definitions for "meter" and "second" have changes over the years. Hardly renders them obsolete. This is exactly what SS-Travellers comment completely undermines. That a new standard or a new variant doesn't suddenly make the old one garbage. Quote:
Which is why I did say that I hate using anecdotes. These cars should certainly be put through more comprehensive tests like Euro NCAP or IIHS. No doubt. But the point here was that structural integrity demonstrated by these tests WILL have a real world application. A car cannot score so high on structural integrity tests unless it has indeed been designed that strong all around. I'll rephrase: There is a very high correlation between cars being strongly built and cars scoring high on GNCAP tests. Agreed? And cars with strongly built bodies will tend to fair better in terms of occupant survivability in most accidents except for some incredibly corner cases. So by extension, one can posit that there is indeed a correlation between good GNCAP scores and people surviving accidents? Quote:
(2) Thanks |
The following 2 BHPians Thank ashishk29 for this useful post: | Gennex, ron178 |
18th July 2022, 19:41 | #35 | ||
BHPian Join Date: Feb 2022 Location: UK/Ottapalam
Thanked: 200 Times
As I mentioned earlier, Marazzo is a perfect example with a 4* rating but no ESP, not even in the top variants. A more recent example is Scorpio N where Z4 manual does not have ESP although it is likely to have a 4/5* rating when eventually tested. ESP starts with the Auto variant of Z4 and then all models upwards, but the Z4 AT may command a Rs.1.5L premium over the MT version. And this is where a buyer on a strict budget (aka me) starts to feel the pinch and is forced to pick and choose and compromise on various safety features. As you can see, my predicament is to do with 7 seater options under Rs.15L ex, and sadly one will have to compromise on some safety related aspects to buy the vehicle. Scorpio N Z6 @ 14.99L will fit the bill, but only if one manages to be in the first 25K bookings. It just exposes a big gaping hole in the market offerings at the moment: a safe (4/5* rated) 7 seater with minimum 2/4 airbags (not even asking for 6) plus ESP/ESC with just basic features/gizmos - all under Rs.15L. It doesn't exist. Why cant Mahindra add ESP to M6+ Marazzo? Am I asking for too much - I don't think so. Or maybe I am!! | ||
(2) Thanks |
The following 2 BHPians Thank akannath for this useful post: | ron178, TechnoBloop |
18th July 2022, 19:51 | #36 |
BHPian Join Date: Apr 2012 Location: Delhi
Thanked: 2,374 Times
| Re: Choose car with many safety features & lower safety rating or vice versa? Very good thread. Has really brought the safety aspects to the forefront and compelled us to think about it. My take is, that we should go for maximum safety option, preferably with a good rating, esp, max airbags etc as the key. It may be a couple of lakhs higher than the target budget, but I would try to cut budget elsewhere (on bells n whistles or non car budget) or wait a bit longer, to save a bit more. I would compromise on other things but not safety. The price that you may end up paying by compromising on safety, could be something that cannot be measured in terms of money. But, we must remember that having the highest safety features does not imply that we should lower our guard on good driving, We should still keep defensive driving our priority. Last edited by ajayc123 : 18th July 2022 at 19:57. |
(1) Thanks |
The following BHPian Thanks ajayc123 for this useful post: | The Rationalist |
18th July 2022, 19:56 | #37 |
BHPian Join Date: Jul 2021 Location: Bengaluru
Thanked: 863 Times
| Re: Choose car with many safety features & lower safety rating or vice versa? Purpose of Safety features is to keep you safe and safety benchmarks are safety ratings It is like Quad core Micromax phone vs iphone 6 dual core processor, success of engineered products are defined by how it delivers You can also explore XL6/ Ertiga - 2 Airbag version of Ertiga has similar crash test performance as 6 air bag Carens - Top end has 4 airbags (I guess it will be better) - Carens body shell is unstable you can see A pillar bending in crash test video |
() Thanks |
18th July 2022, 20:07 | #38 | ||||||||
The basis on which the speed, offset and barrier for the test were chosen is that in a crash study by the UK transport research laboratory in 1996, 50% of all serious frontal car-to-car crashes occurred under 55km/h. The EU adopted 56km/h for the frontal impact directive (now a global UN regulation applied even in India) but Euro NCAP chose 64km/h for consumer-testing because it was found to approximately simulate both cars travelling at 55km/h, although they maintain there's no direct correlation. (Source) The test became accepted as the industry standard and that's the reason other NCAPs started using it, not that they did any original research suggesting statistics would be similar in other geographies. Quote:
The structure-related criteria in the test are structural performance (intrusion measurements of the A-pillar, steering column and pedals) and structural integrity (stability of the passenger compartment and rupture of the footwell) which concerns repeatability of the structural performance. The test evaluates performance and not design, the manufacturer is free to use whatever they want to achieve the following: low intrusion measurements in the test and no symptoms of poor repeatability of those intrusion measurements, and that's all the test asks for. Nowhere will you find the test specifying what materials the car should be built with or that it should have good structural developments all-round, etc. Quote:
There exists nothing of the sort. Crashworthiness comes from designing cars to prevent intrusion in certain crashes, and while that does require the use of stronger materials, it doesn't mean that it would inherently perform better in other crashes unless designed for them. Quote:
I meant to use the Aveo's result to demonstrate that this need not be true: Quote:
GM and Nissan that I know of. I'm sorry, could you please be more specific? I didn't quite understand which part was speculative. Quote:
(Off-topic: The language in the Polo's report is somewhat incorrect because hard contact only means that the HIC values will be interpolated to generate a score rather than awarding maximum points. Excessive HIC values then lead to zero stars) My bad. Please see 3.2.1.3 Removal of Knee Modifiers in the assessment protocols. Last edited by ron178 : 18th July 2022 at 20:17. Reason: more bad grammar | ||||||||
(3) Thanks |
The following 3 BHPians Thank ron178 for this useful post: | ashishk29, karanddd, RubberGuru1113 |
18th July 2022, 20:07 | #39 |
Senior - BHPian Join Date: May 2012 Location: BLR/PTR
Thanked: 9,927 Times
| Re: Choose car with many safety features & lower safety rating or vice versa? Safety is important factor but safer rating and safety features are just two aspects. There are much more that goes into buying a car- Engine/Gearbox, space on offer, intended use, price, manufacturer preference, design etc. Only a small percentage of buyers would have bought Marazzo for just 4 star safety or Carens for standard safety features. |
() Thanks |
18th July 2022, 21:12 | #40 | |
BHPian Join Date: Dec 2021 Location: BLR/COORG
Thanked: 183 Times
() Thanks |
18th July 2022, 22:05 | #41 |
BHPian Join Date: Apr 2022 Location: Chennai
Thanked: 294 Times
| Re: Choose car with many safety features & lower safety rating or vice versa? Car manufactures coin the term 'Safety' in their advertisement with different meaning to confuse the buyer. Some use this term as build quality, some use it as reliability, while others use it as a feature to satisfy the customer's need which is quite diverse. Consider my case: I own Tata Altroz Diesel because I was impressed about the 5 star GNCAP rating and its performance. It ticks most of the boxes in the safety column. However, the ownership of this car taught me a big lesson that the reliability is the most important factor to measure the safety of the car. With that lesson, I have added Maruti Suzuki Ignis to my garage. There is no doubt about the reliability of its engine and other mechanical components even though it got just 3 star in GNCAP. Similarly, features like rear fog lamp, ISOFIX etc. also add extra points to the overall safety. In nutshell, every manufacture conveniently distorts the term 'Safety' to fool us due to various reasons. It may be engineering, geographical or economics. Every member in this forum wants a safe car, unfortunately we are forced to make some compromises due to the constraints we have. We know this. Despite of this, why do we need to classify the safety into two classes? Aren't we trying to stand with our car here as we love them? Who will be the benefiting if we stand divided on safety? Last edited by On4Wheels : 18th July 2022 at 22:22. Reason: typo, added a sentence |
(1) Thanks |
The following BHPian Thanks On4Wheels for this useful post: | Arun Varma |
18th July 2022, 22:37 | #42 | |
Distinguished - BHPian | Re: Choose car with many safety features & lower safety rating or vice versa? Quote:
(1) Thanks |
The following BHPian Thanks SS-Traveller for this useful post: | ron178 |
18th July 2022, 23:04 | #43 | |
Lap pretensioners have a role in knee mapping tests (optional manufacturer data) whose protocols are available here (see 2.2) (Global NCAP references this document in 3.2.1.3 'Removal of Knee Modifiers'). Indian legislative side impact requirements are here. The GNCAP's updated July 2022 protocols can be found here: adult and child. Last edited by ron178 : 18th July 2022 at 23:10. | |
(2) Thanks |
The following 2 BHPians Thank ron178 for this useful post: | RubberGuru1113, SS-Traveller |
19th July 2022, 06:07 | #44 | |||||||
I can agree that Mahindra did Marazzo dirty. They completely discontinued the top M8 variants which I believe had all these features. Maybe in the near future we will see these features percolate. As of right now, personally, I would pick safety rating over ESP. But that's just me. Quote:
"Percentage*distribution*of*917*cars*by*impact*loc ation: The*impact*location*was*analysed*by*considering*th e*third*character*of*the*CDC*[5]. The*third*character*denotes*the*General*Area*of*Da mage*(or*direct*impact*location)*for*the*impact,*a nd*64%*of*the*cars*analysed*had*their*impact*locat ion*as*“F‐Front”." So even this study agrees that 64% of all crashes were frontal impacts of some variant. However it also says that "The*probability*of*a*car*impacting*a*truck/bus,*a*motorised*two-wheeler*or*a*fixed*object*is*far*greater*in*India* than*the*probability*of*a*car*impacting*another*ca r." This has since changed. If you check my original post for the MoRTH stats from 2019, to quote myself, "16% of all accidents involve cars/taxis/lmv, and of that 43% are caused by another car/taxis/lmv." The percentage has changed vastly since then. About half of the accidents are now cars impacting other cars. So this finding from the 2017 study does not hold entirely true. But can a car perform without being designed well? These two are also directly correlated. Cars that are well designed/designed with better materials will perform better. Quote:
(Mildly off-topic) Also I see a discrepancy(?) with the report on the Aveo: The comments highlight that the footwell and the body shell both were rated unstable. Yet the overall summary above says bodyshell integrity as stable? How? Quote:
(1) Thanks |
The following BHPian Thanks ashishk29 for this useful post: | ron178 |
19th July 2022, 08:41 | #45 | |||||||
In fact, there seems to be a mistake in the 2017 Ka too: the report reads 'yes' against 'side impact protection (structural)' but the text reads: Quote:
(1) Thanks |
The following BHPian Thanks ron178 for this useful post: | ashishk29 |
