Search this Thread | 34,238 views |
14th December 2021, 09:41 | #31 | |
BHPian Join Date: Mar 2019 Location: Mumbai
Thanked: 80 Times
| Re: Ecosport toppled multiple times with none of the 6 airbags deployed I agree here with Sagar Watch this video - only the passenger side airbag selectively opens and not the driver airbag Ford must be commended for having built best in class & solid products, and I own an endeavour and feel pretty safe inside I am sorry you had to go through this incident, and fully empathise with you on the doubts you may be having regarding your car; do write to Ford officials in charge of design / engineering for their word But all said and done, we must count our blessings for coming out unhurt, not everyone in any car can claim to walk out post so many rollovers, physics is same for all - and this car clearly absorbed a good amount of energy and retained the outer shell integrity for passenger safety. For me, that’s all that counts and credit must be given where it is due Quote:
(1) Thanks |
The following BHPian Thanks sudhirdamo for this useful post: | Lobogris |
16th December 2021, 12:46 | #32 |
BHPian Join Date: Jul 2020 Location: Cambridge
Thanked: 114 Times
| Re: Ecosport toppled multiple times with none of the 6 airbags deployed My cousin recently crashed his Ecospsort into a brick wall he walked out without any scratches. Hew was alone in the car and front driver air bag deployed. Both the front of the car and brick wall were destroyed. Our entirely family is thankful of Fords insane build quality. |
(1) Thanks |
The following BHPian Thanks mathewspaul for this useful post: | Lobogris |
16th December 2021, 13:08 | #33 |
BHPian Join Date: Dec 2021 Location: India
Thanked: 93 Times
| Re: Ecosport toppled multiple times with none of the 6 airbags deployed Airbag sensors are placed behind the front bumper and between opposite doors. They are supposed to respond to a force or sudden de-acceleration. In your case the doors were not intruded upon by an external force and your friend didnt apply emergency brakes. I didnt buy Ecosport because when it was tested by IIHS , they found a higher rollover risk. This is also true for all hatchbacks which have been raised up from the ground and labelled as compact SUV. |
(1) Thanks |
The following BHPian Thanks Turbojet for this useful post: | adisan |
26th December 2021, 16:08 | #34 | |
BHPian Join Date: Feb 2021 Location: Bangalore
Thanked: 1,707 Times
| Re: Ecosport toppled multiple times with none of the 6 airbags deployed Quote:
Concluding that a car with airbags is as good as Maruti 800 is dangerous and I hope no one takes it seriously, 25 thanks at the time of reply is worrying. No, a car without airbags is NEVER as safe as one with airbags which are much much safer. The primary sensor an airbag uses is deceleration, how fast a car comes to stop (say 2g/3g). If sensor reading is below that, airbag is not activated. That's usually why airbags deploy in head on collisions or if a vehicle hits from sideways which again shows up as extremely fast deceleration. At lower speeds( say 40kmph or whatever) a conscious decision is made by manufacturers to NOT to deploy airbags because airbags can cause burns themselves and it is a trade-off. Hence, in cases where there is no head-on collision or even a hard bone-T hit by other car, airbags will not deploy. The six airbags are usually two front (for head on, in dashboard)and four sideways (two front seats and two back ones). In such a case, the car would have lost some speed and sensors correctly do not detect massive deceleration. Not trivializing the accident or the agony of the same, the fact that occupants survived means no sudden head-on or sideways collision. I have been involved in an accident myself where driver hit the median barrier sideways tangentially on a winding road and no airbag deployed cause it was neither head-on nor complete sideways. The car was totalled though. No one was injured seriously. For heaven's sake, don't trivialize the importance of airbags. This is a case of toppling which SUVs are prone too. Last edited by OffRoadFun : 26th December 2021 at 16:13. | |
(4) Thanks |
The following 4 BHPians Thank OffRoadFun for this useful post: | dennisjs, Lone Ranger, ron178, Turbojet |
26th December 2021, 17:57 | #35 |
Senior - BHPian Join Date: Apr 2011 Location: Pune
Thanked: 1,994 Times
| Re: Ecosport toppled multiple times with none of the 6 airbags deployed Happy for you to have survived this crash. Neither of the following is the case:
The limitations of technology apply equally across the car brands and models. On this forum itself, we have seen cases of non deployment of the airbags. Even with these limitations, it is still better to have the airbags. And as the fellow members have said, these are the secondary restraint system, not the primary. So my suggestion will be not to file any case against Ford. In my opinion, they aren't at fault. Some lawyer may be confident that he can present the case properly. It is their profession and I understand if they want you to fight the case. Some lawyers may even offer to fight free of cost in return for a percentage in the compensation. But simply the fact remains that Ford isn't at fault for limitations of the technology used. They have declared the limitations clearly and in spite of limitations the technology is useful for safety and does work in many situations. If the 407 that caused this crash is known, a third party liability case can be made. In case you still choose to file a case, the court will also ask for a proof of preventive maintenance done on the car from time to time. If the services / inspections have been skipped, it will weaken your case. Last edited by Rahul Bhalgat : 26th December 2021 at 18:01. |
() Thanks |
27th December 2021, 12:16 | #36 | |
BHPian Join Date: Nov 2021 Location: Hyderabad
Hoped the incident will trigger introspection and recall by Ford but our systems may not force their hands. Thank God once again for your safety! | |
() Thanks |
