Old 30th March 2012, 00:57   #46
parrys's Avatar
Thanked: 8,180 Times
Re: The Yamaha R15 2.0 Ownership Report at 4000 kms
Cleaning my LS2 Celtic (air-pump) Helmet: A pictorial guide!
Clean the upper surface of the helmet with a moist cloth. (Not wet with water dripping)
How To: Clean your motorcycle helmet-1-wipe.jpg
Take out each of the detachable pieces carefully.
How To: Clean your motorcycle helmet-2-remove-carefully.jpg
Wash and rinse it with water, and then with very little detergent - wash it in the washing machine if you wish to.
How To: Clean your motorcycle helmet-3-machine.jpg
Inside the LS2 Celtic
How To: Clean your motorcycle helmet-4-inside.jpg
The air-pump button and the reset (air-release button)
How To: Clean your motorcycle helmet-5-pump.jpg
The red piece which is screwed on (not the press buttons) has a hole if you notice. This is where the air is pumped into in the cheek / side pads.
How To: Clean your motorcycle helmet-6-air-pump-blow-tube.jpg
The cheek / side pads with the air pump tube which goes inside the hole as shown above. (The tube is not seen clearly in the pic)
How To: Clean your motorcycle helmet-side-cheek-pads-air-pump-tubes.jpg
Wind deflector for the nose. Notice that it does not have holes in the center to avoid dust entering you nostrils.
How To: Clean your motorcycle helmet-nose-wind-deflector.jpg
Check our the 3 mount points for the wind deflector. My earlier LS2 Dragon did not have this. I had to play around pushing the fibre ends so that it fit in properly.
How To: Clean your motorcycle helmet-nose-wind-deflector-mount-points.jpg
Front air-in vents
How To: Clean your motorcycle helmet-7-airin-vents.jpg
Rear air-out vents
How To: Clean your motorcycle helmet-8-airout-vents.jpg
The reflector which is very essential during long rides. Believe me, a friend of mine has the same helmet and this reflector does its job very well in bad light conditions. Very visible due to the High / Low beam of the following vehicle / bike.
How To: Clean your motorcycle helmet-reflector-very-essential-night.jpg
Fitting it back. This is the most time consuming part of the cleaning process. When you fix the side pads, make sure you start from the rear end - this will help you because the rear reflector piece will have pressure marks which give you the exact position for the pads to be placed in. Then insert the air pump tube perfectly in the hole and lock the press buttons.
How To: Clean your motorcycle helmet-fixed-back.jpg
After you are done with that, clean it again with a moist cloth.
How To: Clean your motorcycle helmet-last-1.jpg
How To: Clean your motorcycle helmet-last-2.jpg
How To: Clean your motorcycle helmet-last-3.jpg
How To: Clean your motorcycle helmet-last-4.jpg
Pack it in the LS2 bag, and you are done.
How To: Clean your motorcycle helmet-packed.jpg
Last edited by GTO : 1st April 2012 at 10:46. Reason: Copied this post to another thread
parrys is offline   (6) Thanks
Old 2nd April 2012, 07:05   #47
madhkris's Avatar
Thanked: 83 Times
Re: How To: Clean your motorcycle helmet
Very nice pictorial guide Parrrys. Really helpful too. I was wondering how to clean my Cross helmet and here it is! I have yet to see if my helmet has all the details that the LS2 has though. Along with this, I have a Studds Downtown open face helmet too. Any tips on cleaning it? I guess we cannot detach the padding in it.
madhkris is offline
Old 30th March 2024, 12:58   #48
Thanked: 2,652 Times
Infractions: 0/1 (5)
Helmet Visor Cleaner
I use this cleaner liquid to clean off bugs and other debris from the visor of my helmet. This is actually used to clean spectacle lemses and even contact lenses. This is very high quality and does not damage the visor. I use a microfiber cloth to clean the surface after spraying liquid on the surface.
I purchased this on Flipkart.
How To: Clean your motorcycle helmet-img_20240330_065356.jpg
rajeevsulu is offline   (1) Thanks
Old 30th March 2024, 16:44   #49
Sebring's Avatar
Thanked: 11,798 Times
Good idea. I'm also using optical grade on the visor
Originally Posted by rajeevsulu View Post
This is actually used to clean spectacle lenses. This is very high quality and does not damage the visor. I use a microfiber cloth to clean the surface after spraying liquid on the surface.
How To: Clean your motorcycle helmet-img_8252.jpg
Sebring is offline   (1) Thanks
