Having used the Nolan N86 helmet for 11,900 kms in what is a week short of 2 years, now is as good a time as any to post my ownership review of what has been a surprisingly good helmet.
Date of purchase : Early May 2015. I had bought if from AutoQueen in Cochin which has been my go to shop for riding gear over the last 9 years. They had just recieved a consignment of Nolan helmets and I was coming off a fall which had put my HJC CL17 into the retirement home.
Why the Nolan N86 : The reviews that I could find were favourable. My first choice was the HJC RPHA 10 but I couldnt find it in stock anywhere. I was also looking at the super light XLite X802R that I could have picked up on a foreign trip but when I heard about the Nolans (
incidentally they are also the manufacturers of XLite helmets) I decided to take the plunge.
Initial Impressions : My distinct first impression was that it was definitely not as comfortable as my HJC CL 17. Dont get me wrong, Im not talking about pressure points or folded ears when I talk about comfort. Its just that the CL 17 seemed to be a much more natural fit for my head shape from day 1 whereas the N86 took some time to break in and for me to get fully comfortable with it.
Oh and it certainly was noisy even with all the vents closed. On the plus side, it had an internal sun visor that I initially thought was gimmicky. Oh how wrong that proved to be. It also came with a pin lock visor that has ensured no fogging up which is something that I faced with the CL 17.
Usage : Its seen nearly 12,000 kms of the best and worst of our weather and has been used for commuting, weekend highway rides, track days etc.
Current Impressions : I'll break this down into separate parts
a. Drop down sun visor - This is an extremely useful feature to have in your motorcycle helmet as it completely eliminates the need to carry around a bag with your tinted visor so that you can swap it out during the day. The drop down visor is controlled by a lever on the left side that is large enough that it can easily be moved with one hand without looking and quality wise it still moves with the same fluidity as day 1.
I do wish that the sun visor was a few millimetres longer so that I could have the visor cover my view when I looked down at the bike's gauges though but that's just me nitpicking.
b. Pin lock shield - This is a huge difference maker especially when you are using your helmet during Indian monsoons. My CL 17 used to fog up even before I used to take my bike out of the parking lot in the monsoons!
That said, it hasnt really stood the test of time. Ive noticed small spots appearing on the main visor over the last few months. This was from air bubbles being formed between the pin lock shield and the visor because the glue that was holding the pin lock shield has started to lose its strength.
c. Ventilation - If you are in Bangalore's atrocious city commute with the vents closed, you can start to feel your scalp sweating after a while.
Top Vents - Open and Closed
Chin Vents - Open and Closed
Open up the vents and you can notice the difference. On highway rides, I usually keep them closed.
Rear vents It also comes with rear vents that I guess help in extracting air from the helmet.
d. Noise - So you want ventilation but dont want to noise? Cant have one without the other. I agree but that said this is one noisy helmet. In my case, my Continental GT has a Givi windscreen which deflects air to the upper part of my chest and the helmet and on highway rides I find that the noise is really annoying. I use air plugs but still it isnt as quiet as I would like it to be.
e. Fit and finish - No complaints whatsoever with the paint finish and quality on the outside. Ive washed the cheekpads several times but I cant seem to get them to look clean. However I have noticed small gaps appearing between the removable cheek liner and the inner liner which I suspect is letting in air and causing more noise that what others would experience.
If I try placing my finger at that spot on either side, I find the noise levels going down. For now, Ive plugged in some tissue paper so you can see what Im talking about.
f. Weight : At 1460 gms, it is lighter than my earlier helmets.
g. Chinstrap : Ive been using the double D ring system for several years and the one problem with it is that you cant put on your helmet if you have your gloves on.
The N86 comes with a slide in toothed system that makes it easy to lock in the helmet even if you have gloves. Also if it is too loose or tight, its easy slide in and out as compared to the double D ring system.
How much did it cost : Rs 20,000 which all said and done is a fair price for what has been a good helmet so far.
Overall rating : A solid 8.5 out of 10 stars.
Final thoughts : Compared to the HJC CL 17 which cost less than half of it did, the N86 is a lighter, easier to use helmet that came with a drop down visor and is DOT approved, meets ECE standards and has a 4 star SHARP rating. The N86 has now been replaced by the N87 and reviews once again seem to very positive. How positive? For starters it won both the Motorcycle News (MCN) product of the year and RiDE magazine "Best Buy" awards in 2016. Web bike world (
which is a website I trust for its depth of reviews) says "The new Nolan N87 beats every other helmet in its price range. In fact, you'd be hard-pressed to spend twice as much and still get as much." Sure, a Nolan N87 doesnt have the flash value of the AGV K3 or K5 series and price wise sits between them in India at Rs 22,000 and if it is available in your city it is certainly worth taking a long hard look at it.
