Team-BHP > Vintage Cars & Classics in India > Pre-War
Old 27th July 2014, 14:17   #1
Thanked: 1,006 Times
Swami & friends, the story continues - Our 1933 Austin Seven
Hi friends! First, let me apologise for nearly four years of silence. It has been a time of great ferment in my life, all happy of course, involving a change of lifestyle and occupation. The cars were stashed away, for a time when I could work on them. There is a thread that I have to revive, where I was to describe the restoration story of Dev, my MG TC. But more of that elsewhere. Here is a new thread where I will describe the half-restoration of Swamy, our 1933 Austin seven.
The story of Swamy was described in a Travelogue that I posted on this forum a few years back (https://www.team-bhp.com/forum/trave...by-austin.html (Swami and friends, Travels in a baby Austin)). It ended on a sad note; I intended to drive him back from Delhi to Bangalore in early 2009, but the petrol tank fell off due to extensive rust on the floor. After boxing him to Bangalore, I drove him not often, till brake problems forced me to stop driving him; it was becoming dangerous.
After three years of being stashed away, I am once again working on Swami; to put him back into good mechanical and cosmetic shape, fettling him to fulfill a long standing ambition; to undertake the mother of all travels in this wonderful little car. But more of that later! Here goes, the pictures of Swami being readied for hitting the road again!
Last edited by karlosdeville : 27th July 2014 at 16:09. Reason: Adding link to travelogue
tonrag is offline   (19) Thanks
Old 27th July 2014, 14:21   #2
re: Swami & friends, the story continues - Our 1933 Austin Seven
Swami in happier times, at Vijay Chowk. There is evidence of the work ahead of us. The headlights had a tendency to work free and point in different directions, because the key that keeps them focused straight ahead had worn through. Unseen to the viewer, the bonnet lacks bonnet catches and so they slap around when one hits a bump. And then, the springs on the left side are sagging, giving Swami a slight limp. But Swami has a robust engine and drove well, then.
Last edited by aah78 : 28th October 2019 at 19:23. Reason: Picture inserted in-line.
Old 27th July 2014, 14:49   #3
We started with removing the right rear wing and cutting away the bubbling metal. It had been generously covered with filler, hiding the extensive rust that had eaten away the metal from underneath. We also discovered another horror story as we cut away the metal. This is always the case with restorations. They become much bigger actions than originally thought.
The metal cut away from the body revealed that over time, sheets of fresh metal had been welded over the rusted body, creating a series of disjointed layers of metal. Water had seeped into the whole irregular sandwich and it had rusted from within, creating something that resembles a Kerala parota; flaky layers of rust peeling apart.
Last edited by aah78 : 28th October 2019 at 19:23. Reason: Pictures inserted in-line.
tonrag is offline   (16) Thanks
Old 27th July 2014, 14:53   #4
New, fresh metal was carefully shaped and gas-welded back. We did this in sections, working first on the outer body tub and then the inner wheel arch. Note the evidence of earlier repairs on the right hand side. Those repairs date back to the sixties, I am sure, because the filler material used is lead. In the early days, before the advent of body filler, lead was melted and applied over the body metal and buffed back, in order to get a smooth finish. It was only later that the harmful effects of lead poisoning was discovered.
Last edited by aah78 : 28th October 2019 at 19:24. Reason: Pictures inserted in-line.
tonrag is offline   (17) Thanks
Old 27th July 2014, 14:56   #5
The inner arch of the wheel, showing the 'Kerala parota' style of welding metal sheet over rusted metal sheet. While cutting this away and replacing it, we had to be very careful to get the position of the nuts welded into the metal, exactly right. These nuts are where the outer wings are bolted on, and any distortion would spoil the lines of the wings completely.
Last edited by aah78 : 28th October 2019 at 19:25. Reason: Pictures inserted in-line.
tonrag is offline   (14) Thanks
Old 27th July 2014, 14:58   #6
On the left side, we tried a different approach, cutting away all the rusted metal and replacing it at one go.
tonrag is offline   (18) Thanks
Old 27th July 2014, 14:59   #7
The final job. New metal, good, 3M body filler applied and sanded down and covered with primer to face the paint job.
Last edited by aah78 : 28th October 2019 at 19:26. Reason: Picture inserted in-line.
tonrag is offline   (23) Thanks
Old 28th July 2014, 19:00   #8
Thanked: 34 Times
Re: Swami & friends, the story continues - Our 1933 Austin Seven
Great move ton rag, hope to see the old beauty alive and kicking again. Please keep updating this thread!
thebfg is offline
Old 28th July 2014, 22:14   #9
amartyasg's Avatar
Thanked: 81 Times
I would love to see your car in person once its complete! I have a thing for Austin Seven convertibles. My great-grandfather had one, though I've never seen it myself. They are such beautiful and simple cars! It was kind of like Britain's Model T. Also, if I'm not wrong, the first BMW car was a rebadged Austin Seven. Haven't spotted any in Bangalore yet.
amartyasg is offline   (1) Thanks
Old 29th July 2014, 00:36   #10
Thanked: 1,284 Times
I feel so envious. We had an Austin 7 - unfortunately sold off by a relative to a scrap dealer. I would have loved to get it back in shape. Good job. Best of luck with it.
invidious is offline   (1) Thanks
Old 29th July 2014, 09:54   #11
Thanked: 79,071 Times
Wonderful car tonrag. Would love to see Swami after the restoration work is complete. Please keep updating this thread with new pictures from time to time.
The Austin 7 is a true legend, forming the base for the first cars from companies like BMW and Nissan.
Aditya is offline   (1) Thanks
Old 29th July 2014, 22:53   #12
Twinn's Avatar
Thanked: 285 Times
Originally Posted by tonrag View Post
The story of Swamy
My heartfelt appreciation to you Sir! Your travelogue was one of the best I have ever read. The way you have narrated and the simplicity of the post was something that was like "wish I was there to experience it".
I really hope you restore Swami to his glory and give us all a ride someday. Please can you post a picture of all the Golden beauties that you have stacked up in your garage.
Twinn is offline
Old 30th July 2014, 07:22   #13
Thebat's Avatar
Thanked: 647 Times
What a beauty. I would love to see Swamy happily running in the streets of Bangalore soon. Such cars bring out a sense of happiness in me , I know I am probably mad.
Thebat is offline
Old 26th October 2019, 23:26   #14
I know this is an unpardonable crime, to appear on this site once in five years. But my restoration of Swami faltered yet once again, till last year. Petrolheads will understand that; while most of us are disorganised, some like me make that into an art form.
Swami was cleaned every now and then. Every Ayudha Puja, I would give him the once over, and resolve to restore him that year. Yet, for four years, Swami languished in a corner of my workshop, dusty and ignored. I was busy professionally and with a punishing travel schedule, had little time for cars. Whatever time I could spare was devoted to restoring another vehicle. Every year, Swami looked a little more forlorn, as I guiltily avoided looking at him.
Last edited by aah78 : 28th October 2019 at 19:27. Reason: Pictures inserted in-line.
tonrag is offline   (12) Thanks
Old 26th October 2019, 23:38   #15
Much as I hated to admit it, Swami's fate was uncertain. I thought I could restore him, but not before another vehicle that was taking up precious space in my garage could be moved up.
Fate however smiles on the virtuous, particularly when the virtuous harbour thoughts of restoring Austin Sevens. So it happened that in mid October 2017, I met Sai Krishna, an expert on restoration of classic Fiats.
I knew Krishna's father, Mr. Murthy, and his grandfather, Mr. Loganathan, well, decades back. They ran Pioneer Garage, a venerable institution started in 1908, and tended to old automotive iron much before it acquired the classic aura. Mr. Murthy had tended to my first car, a 1950 Vauxhall Wyvern, when Krishna was but a toddler.
I saw hope in Krishna. Would he be able to breathe life into the agonising, stalled restoration of the car that was blocking up space in my garage? He agreed readily and delivered on his promise. By March 2018, the car was restored, and delivered. I had room and time, to attend to Swami.
tonrag is offline   (5) Thanks
