Immaculate Austin 7 - A reference to collectors I was surprised to see a neatly maintained Austin 7 with all possible orginal parts.
Few of my observations about this magnificent piece of art on wheels.
1:- Lucas King of the road head lamps (Harry Lucas designed a hub lamp for use in a high bicycle in 1879 and named the oil lamp "King of the Road". This name would come to be associated with the manufactured products of Lucas Companies, into the present day. However, Lucas did not use the "King of the Road" epithet for every lamp manufactured. They used this name on only their most prestigious and usually highest priced lamps and goods. This naming format would last until the 1920s when the "King of the Road" wording was pressed into the outer edge of the small "lion and torch" button motifs that frequently decorated the tops of both bicycle and motor-car lamps)
2:- Bowden brakes
3:- Zenith carburetor
4:- Austin foundry marks on head and engine block
5:- Coil (Presto lite)
6:- Working steering controls i.e., the retard and advance for ignition and the yesteryear cruise control
7:- The running board is still having the rubber mat with Austin emblem on it
8:- The gas tank lid hangs on itself on a tiny cable from inside the tank
9:-Storage compartment under the driver seat
10:- Original Joseph Lucas gauges with the Smiths speedometer
11:- suspension 3 spring plates
12:- All wheel nuts are made of copper
13:- original parts number plate on the dash board
14:- 4 speed gear box
15:- original paint ?
16:- still a running 6Volt car with original wiring and all electrical
17:- Crank start working like a dream
18:- Car No :- B6 XXXX
19:- Chasis 162XXX
Detailed snaps to follow soon.
Thought of documenting this car as it can be used as a reference later.
About the steering controls , There are 2 controls one for IGN and the other for GAS. IGN is having 2 options A for Advance and R for Retard. If we move the knob on either directions you can see the coil adjusting itself under the hood. The other option GAS is the great grandfather of the Cruise Control system.
Reason: adding photos
