Team-BHP > Vintage Cars & Classics in India > Pre-War
Old 25th December 2015, 11:50   #46
KartikeyaL's Avatar
Thanked: 15,781 Times
re: My Morris Minor 1930 OHC Tourer
This shot of my almost 86 year old Morris minor , just won the picture of the year contest on the Pre-war Minor Network, www.prewarminor.com
My Morris Minor 1930 OHC Tourer-577659_10153796311294134_1233152118283504897_n.jpg
KartikeyaL is offline   (9) Thanks
Old 3rd May 2016, 14:23   #47
KartikeyaL's Avatar
A few pictures from the Jaipur rally 2016
KartikeyaL is offline   (4) Thanks
Old 5th September 2016, 12:08   #48
KartikeyaL's Avatar
Had been facing starting issues when using the starter motor, so have taken off the engine for inspection.
upon inspection it was found that the flywheel teeth are badly damaged due to years of use/abuse , so now I am looking for a replacement and in the meanwhile will get this one repaired to get the car back on road.
the entire flywheel is one piece, I thought earlier that would be able to remove the flywheel ring and replace, but that doesn't seems like a easy solution.
Old 8th September 2016, 16:37   #49
KartikeyaL's Avatar
After discussions on the Pre war minor forum, I decided to get the flywheel repaired locally, by using a hard weld and grinding.
Hope it works
KartikeyaL is offline   (2) Thanks
Old 17th October 2016, 18:29   #50
KartikeyaL's Avatar
The engine is back in the car and took her out for a small drive yesterday
KartikeyaL is offline   (5) Thanks
Old 28th December 2016, 08:47   #51
Thanked: 8,573 Times
Photo ca 1932
travancore is offline   (3) Thanks
Old 28th December 2016, 11:26   #52
ariesonu's Avatar
Thanked: 2,421 Times
Hope it works
HARD WELD is ok but I think you should have chosen to get it MILLED rather than grinding. Uneven grinding will result in more damage, once the FW is put to use.
EDIT: Oops. I realized, I am too late for suggestion
Regards.
ariesonu is offline   (1) Thanks
Old 28th December 2016, 12:39   #53
KartikeyaL's Avatar
Originally Posted by travancore View Post
Attachment 1589060
Photo ca 1932
Many thanks for this I had posted this picture from Autocar earlier, but it was not as clear.
The finish was very even , I think they used very fine grinding or maybe milling tools.
Old 18th August 2018, 11:56   #54
KartikeyaL's Avatar
The little Morris minor got featured on the website of Pre war Minor network, UK.
www.Prewarminor.com
India gained its independence from the United Kingdom on 15th August 1947. Kartik Lunia celebrated this recent 71st anniversary by taking his 1930 Minor Tourer USJ 1795 around the streets of Jaipur while flying the Indian tricolour from the back seat.
Name:  Front page star.png
Old 8th December 2018, 08:14   #55
KPS
KPS's Avatar
Thanked: 11,627 Times
Kartik, here is a surprise for you!
Morris Minor in a very interesting body style. The car in a van body style, however does not sport the original grill and radiator. Still this is an very interesting car.
These cars are more like a museum piece! Must be very bouncy and difficult to drive!
KPS
KPS is offline   (3) Thanks
Old 8th December 2018, 15:21   #56
KartikeyaL's Avatar
KPS
Thank you for sharing these picture, this looks like a 1932 model.
KartikeyaL is offline   (1) Thanks
Old 19th February 2019, 08:12   #57
KartikeyaL's Avatar
Post #2000, dedicated to my favourite car !
Old 19th February 2019, 10:23   #58
Thanked: 1,193 Times
All the best for Cartier, car seems to be in good shape and with a refurbishment can only look better.
Glad to see regular posts showing the car being used, that is how it should be.
Bulldogji is offline   (1) Thanks
Old 19th February 2019, 21:00   #59
KartikeyaL's Avatar
Thank you so much Sir, I have taken this oppurtunity to fix all that I could to bring it to a better condition, will post the details of work done in due course.
Kartik
Old 1st March 2019, 15:42   #60
KartikeyaL's Avatar
Re: My Morris Minor 1930 OHC Tourer
My Morris had been restored in 2011-2012 and had some areas which needed improvement/correction, once the car got selected for the Cartier show happening in Jaipur, I decided to take the opportunity to refurbish/correct whatever I could to bring it as close to as it left the Cowley factory in 1930.
The doors and the bonnet did not shut well, the cowl was a bit rounded then how it should be, the hood frame was not repaired earlier and the wooden floor needed work among other work.
