Old 24th November 2009, 13:48   #1
Thanked: 154 Times
My BSA C12 1957 - Restoration
HI All,
While working on my Dad's Lambretta - I had mentioned that I will embark on my BSA C12 restoration and infact I have started on it.
I am posting the pics of my bike as is and will soon start posting the developments.
It may not be the same level of "Madness" as on my Dad's Series 2 but it will be close.
I need help on parts for this bike and am requesting all the BSA Guru's to help and contribute. You will be suitably rewarded / compesated.
Cheers!
Saurabh
SA7VA5 is offline
Old 24th November 2009, 14:52   #2
SamuraiJack's Avatar
Thanked: 145 Times
All the best bro! All eyes on this one
SamuraiJack is offline
Old 24th November 2009, 15:30   #3
suren181's Avatar
Thanked: 11 Times
Though it may not be of great help, methinks you should grab this:
BSA SPARES LIST C10L,C11G,C12 1954 - 1957 on eBay (end time 28-Nov-09 19:05:25 GMT)
suren181 is offline
Old 24th November 2009, 15:43   #4
beejay's Avatar
Thanked: 219 Times
Get going Saurabh. Maybe your thread will be a motivation for me to restore a BSA Falcon GT50.
Looking forward to it a long time now. Availability of spares, time involved and other things just don't let me get started.
beejay is offline
Old 24th November 2009, 18:14   #5
Thanked: 154 Times
Come on beejay - lets start you on your Falcon and I on my C12 - lets do it together!
I am sure we will be able to help each other on the way.
Suren - I grabbed a soft and hard copy of all the spares lists available across the globe already.
I have bought a full set of Service Sheets for BSA - ALL MODELS! Ihave invested a packet on this one already.
Who said BSA is going to be an easy restoration!
I have found a guy who will cut gear plates, temper them and install the right size bushes on the gears so that the wear on shafts can be accounted for.
Have sourced old style handle bar levers.
Am in the process of sourcing the horn button, mag/air lever etc.
Have ordered specially made 19" WM2 wheels - high quality steel with MIND BLOWING quality chrome - plus stainless steel spokes plus brass nipples with high quality chrome.
Have bought a pair of tailights - the correct design - Found that MInda was exporting it. Have bought the original tail light and number plate plastic beading
Have ordered a stainless steel set of fasteners
Have ordered Speedmaster Mark II tires from England - 3.25 upgrade - Classic style
Have sourced Tank Pad rubbers
Have bought all 6 volt Lucas New Coils that I could find in the local market for now and for future use and for other fellow enthusiasts
Have bought an enfield seat base and modification to make it suit the BSA is on
Am on the look out for whole load of parts. Dont want the bike restoration to stop due to lack of availability of parts
Most importantly have found a mech and hired him at my father in law's workshop to do the job
Have found & bought the original old style petrol tank cap in chrome
Have bought the side oil tank BSA Piled Arm Stickers (High Quality 3M material)
Am in the process of procuring an original AMAL Carb from UK
Have found out the sources in UK for most of the parts. Still hunting for more.
Have bought a full engine gasket set
Wow - didnt realise I had sooo much already!
Cheers!
Saurabh
SA7VA5 is offline
Old 24th November 2009, 18:27   #6
beejay's Avatar
Thanked: 219 Times
SAV, lets see how much hair you loose and then let me think about it.
Again all the best with the restoration. You managed to source quite a lot of things. Good.
beejay is offline
Old 22nd December 2009, 18:23   #7
Thanked: 154 Times
OK Another update.
Just managed to source the original AMAL Carb brand new freshly built and assembled from AMAL Carb UK.
So parts collection is on the way.
Cheers!
SV
SA7VA5 is offline
Old 15th January 2010, 13:14   #8
Thanked: 154 Times
Hi
The Fuel tank has been removed from the bike and it has been sent for tinkering and clean up from inside.
There is some rust build up and that now needs to be cleared.
Once it is in shape we will then get it chromed.
More parts are now in inlcuding the tappet cover gaskets and cylinder head gasket.
So while the process is fairly slow it will be a thorough one.
Wait for pics - will upload shortly.
Cheers!
Saurabh
SA7VA5 is offline
Old 16th January 2010, 00:15   #9
chanu's Avatar
Thanked: 150 Times
Now that's what I call RAPID. You have got a load of spares and few yet to come. No doubt another master piece is on its way
Good luck Saurav
chanu is offline
Old 22nd January 2010, 01:59   #10
Congratulations...
Kudos on your latest restoration project.
With regard to your list of spares procured from the UK, why don't you get them from India itself? The BSA C11 and the C12 250s share a whole load of parts and they aren't rare at all in the country. With regard to the parts in the UK, a lot of cosmetic parts are manufactured in India itself. Badges, caps, tinware - it's all made here or other Asian countries. So unless it's something you absolutely don't get here, it doesn't make sense importing it.
With regard to the bushes of the gears on the shafts in the gearbox, any competent machinist can do the job.
This bike isn't the least difficult to restore, unless you try very hard to complicate things. Let me know if you need anything...
Kyle
kylohere is offline
Old 28th January 2010, 17:39   #11
Thanked: 154 Times
Hi Kylohere
I would need the following parts if you can help:
D Shaped Smiths Speedo
Petrol tank - to be chrome plated and not painted therefore either new or in very good condition
Clutch Plates Set
Exhaust Bend Pipe - New
Silencer Muffler New
Seat Base Plate
Petrol Tank Knee Pad Mounting Plates
Piston, gudgeon pin, lock and 3 rings set - if available I can let you know the oversize required
Steering Head Race & Bearing Set - do you know which Bike I can replace it with - I need a new set
Rear Shockers- Girling 10.9"
Please let me know if you can help.
Saurabh
SA7VA5 is offline
Old 29th January 2010, 01:20   #12
chanu's Avatar
Thanked: 150 Times
Spotted this beauty along with an unfamiliar BSA hand gear at my garage which has come for restoration, this blue bird seems to be failrly original except that of rear seat, tank badges.
I am sorry if this post is irrelavant or deviating the topic.
chanu is offline
Old 1st February 2010, 14:40   #13
Hi!
Here's the list of parts that you had mentioned and their availability.
D Shaped Smiths Speedo - AVAILABLE, but used
Petrol tank - New tank is virtually impossible. Good condition maybe. But your tank doesn't look too bad so I don't get the need for a new one.
Clutch Plates Set - Just the friction plates alone or with the pressure plates? If so, AVAILABLE (friction plates) - replica
Exhaust Bend Pipe - AVAILABLE but replica
Silencer Muffler - AVAILABLE but replica
Seat Base Plate - HAVEN'T CHECKED
Petrol Tank Knee Pad Mounting Plates - CAN BE MADE BY ANY COMPETENT DENTER
Piston, gudgeon pin, lock and 3 rings set - AVAILABLE BUT NOT IN ALL SIZES so you might have to bore/sleeve accordingly
Steering Head Race & Bearing Set - I mixed and matched so I don't know which bikes they came off. But if you could help me out with the measurements, I can perhaps get a set for you
Rear Shockers - AVAILABLE but used Girling 10.9"
kylohere is offline
Old 5th February 2010, 13:57   #14
Thanked: 154 Times
Hi
Hi There! Can you also tell me the prices of these parts so that we can decide if we go in for these items or not.
Thanks a bunch.
Is the D SMith working or not?
Cheers!
Sv
SA7VA5 is offline
Old 27th April 2010, 12:25   #15
Thanked: 154 Times
Ok the update on C 12
The Engine has been completely restored with new bearings, new piston, recon crank and con rod, polished tappets, new valves, a sand blasted head duly painted with high temperature paint, all aluminium is now buffed and polished, stainless steel nuts and balance chromed, a new tappet cover, new gasket set, overhauled oil pump, all shims in place (some were missing when I opened it up), new oil seals of the correct size.
I will post pics soon enough.
The Gear box is ready for assembly after all parts have been cleaned and inspected for wear. All bushes have been replaced with new ones of the correct metal spec and size, new clutch plate in place and all new bearings. Its been on the back burner but its now going to witness added speed.
Body work is being repaired right now and tinkering is on.
All parts that required Chrome are done.
New Wheel rims in place and have got Stainless Steel Spokes made to order to EXACT OE SPECS!
New Silencer fabricated and at home awaiting fitment trial before it goes for high quality chrome.
Smiths D Shaped speedometer sourced and at home in stock - in fact now 3 in stock.
Petrol tank dented and repaired. Requires surface preparation prior to high quality chrome plating.
Brake shoes re-ligned.
Original Gold Paladium spark plugs on way to my home from London.
Original Tail Light and Front light sourced and in stock.
All body fitting nut and bolts in stainless steel sourced and in stock.
So as soon as the body work is over and painting is finished assembly will be completed in 2 weeks!
Cheers!
SA7VA5 is offline
