Sorry again for my "disappearing act" but things have been going at a relatively slower pace this time, plus problems with my net at home has kept me cut-off for quite a while!
Anyways, update on MDS 4713: Scoot was washed for I think the first time since being restored and driven by the mech. back to his home in Secunderabad. To be reassembled and then bought back to the painters' for rubbing and polishing.
Meanwhile, proceeded with getting the engine sorted- on Saurabh (SA7VA5)'s kind advice, have proceeded with getting the cyl. head and bore faced at the places where they both come into contact with the packings. It was decided thus as an unfaced head and/or bore is often the reason for air to leak out! And come to think of it, my engine has gone to 2 different persons, including the present guy, for rebuilding and NEITHER of them ever suggested getting the head and bore squared!!
Incidentally, I was told that most mechanics, especially nowadays, would avoid doing this, as its a rather time-consuming and slightly strenuous job, but it sure is worth it!
Just FYI for those who may not know yet, this is how you face the head/bore if you'd have to DIY, as I've had to. 'hope it's found useful.
-First, take a FLAT, clean pieace of squarish glass, preferably around 1*1 ft. Either float or toughened. But make sure it's something you wouldn't need again.
-Then take some LAPPING COMPOUND, a.ka. Valve-grinding compound, as it is used commonly for engine-valve grinding for cars, but also keep adding kerosene in it, as it is known to be quite sticky and pasty. They come in coarse and fine variety, I was recommended to use the coarse type.
-Smear the kerosene all over the glass. Then smear the lapping compound all over it. Try to spread it evenly, but the layer should be relatively thick.
-Then place the head/bore sans the packing/gasket etc. with the gasket-side down onto the lapping compound covered glass and move it SLOWLY in circular motions, either in '0' or figure '8' shape, whatever convenient, clockwise or anti. Also hold the head/bore in the SAME position throughout, avoid turning/twisting it around while moving it, it does to tend to turn. Keep doing this for 1/2 an hour atleast. Then lift up the head/bore and you'll see parts of it appear scraped/dull compared to the original shinier parts. The dull parts indicate the area where it has been faced.
Also remove the excess lapping compound sticking onto it and smear it back onto the glass.
-Now complete the job so as to give the new appearance to the entire gasket area throughout. You may have to do it twice, or even thrice, depending on the outcomes. This will take another 1/2 hr atleast. Better to switch directions, ie. anti-clockwise or otherwise as opposed to your previous round, but maintain uniform SLOW speed throughout.
-Once done, lift the head/bore up again, you should find a thorough and 99% uniform facing done by now.
Here are pics. of my engine head, before, after 1st round of facing, and then the 2nd stage, then finally the last and final one completing the facing. The difference can be seen easily. Saurabh has certified that this will do and now to proceed with facing the bore similarly.
