Originally Posted by CYRUS43 they do no make the same pcd and offset wheels as the original fiat wheels are...we have been trying to find one set since ages... |
The wheels on my car are 98 pcd and a offset of 40/41, ensures that the wheel outer line is in the same place with the rim and tyre being wider than the stock 132. Although I got mine direct from Hindalco, as my Dad worked on one of their projects and this particular rim was suggested by their engineer. Who was known to be mechanically very sound in his knowledge. He also warned us that anything else will affect the wheel bearings moreover he was also instrumental in suggesting the specific tyre size.
See if you can procure that design, but highly unlikely, because they designed this specially for Padmini's (otherwise which other car has 98 pcd!) and later on seeing the lack of demand, stopped it. Even I doubt if I would have been able to procure it from outside.
One thing, have you tried the Palio Alloy rims. I guess the offset will be different and the central hole will foul with the grease cap.
