Here is a follow-up post on the White Padmini.
In continuation to the previous post, I began using the car almost daily and noticed a significant improvement in it over the days especially considering how horrid it was the day I took delivery. Some miscellaneous pics :
![Restoring a 1990 Premier Padmini Deluxe BE-img_20230223_224808.jpg](https://www.team-bhp.com/forum/attachments/post-war/2442011d1687249713t-restoring-1990-premier-padmini-deluxe-img_20230223_224808.jpg)
During one of the many night drives to Worli Sea Face. I did get a set of wheel caps with the car but they don't seem original as they are plastochrome make and keep falling off whenever put on. So I feel it's best to drive without them lol
![Restoring a 1990 Premier Padmini Deluxe BE-img_20230329_230143.jpg](https://www.team-bhp.com/forum/attachments/post-war/2442017d1687249713t-restoring-1990-premier-padmini-deluxe-img_20230329_230143.jpg)
With vishy_76's recently acquired Premier President, 9199 was in fact the car that prompted him to get a Fiat of his own
One day while driving, a very strong petrol odor filled the cabin. Of course, a little bit of petrol smell is normal in these older cars. However, this was rather strong, I stopped the car with the assumption that the petrol pipe would have a leak somewhere. To my surprise, it was a leak from the fuel pump diaphragm, it seemed to have been cracked. So without further ado, I got a new one from a local shop. It wasn't the original make unfortunately but one made by a company called PTM. While I'd much preferred to put the original, in times like this, it's best to get what's available and move on.
Besides that, I realised that the radiator had a crack at the bottom and was leaking water out. Visited a reputed radiator specialist who suggested that it was best to replace it. Hence, I put a bigger radiator from an AC padmini for better cooling. Sadly don't have a picture.
![Restoring a 1990 Premier Padmini Deluxe BE-img_20230318_165550.jpg](https://www.team-bhp.com/forum/attachments/post-war/2442021d1687249776t-restoring-1990-premier-padmini-deluxe-img_20230318_165550.jpg)
Out with the old
![Restoring a 1990 Premier Padmini Deluxe BE-img_20230318_170250.jpg](https://www.team-bhp.com/forum/attachments/post-war/2442022d1687249776t-restoring-1990-premier-padmini-deluxe-img_20230318_170250.jpg)
In with the new !
Once this was done, the car drove fine for a few days and then all of a sudden began misbehaving. The jerking was back, paired with sporadic idling and the carburetor would occasionally flood causing the car to stall. That meant the one and only Ravi, who meticulously maintains my Zen and other cars and has spent his lifetime repairing fiats and the likes needed to be called in.
One look at the car and he said it is running like crap and needed a carburetor service and tune-up urgently. I abided by what he said and got a repair kit as soon as I could. The repair kits these days aren't of the best quality, but again had to make do with it.
![Restoring a 1990 Premier Padmini Deluxe BE-img_20230403_191823.jpg](https://www.team-bhp.com/forum/attachments/post-war/2442020d1687249776t-restoring-1990-premier-padmini-deluxe-img_20230403_191823.jpg)
No wonder this car had begun misbehaving. The innards of the carburetor had enough dust mixed with corrosion inside to build a building. We then went ahead with the procedure of taking it apart, then cleaning everything including the jets and other components, leaving them soaked in brake oil overnight, and assembling it together the following evening.
In the process, we also cleaned up the tappet cover from the inside as it had tonnes of soot and gunk stuck to it. Along with adding a new tappet cover gasket. Clear indications that this car had been neglected and not cared for.
![Restoring a 1990 Premier Padmini Deluxe BE-img_20230404_203241.jpg](https://www.team-bhp.com/forum/attachments/post-war/2442027d1687249776t-restoring-1990-premier-padmini-deluxe-img_20230404_203241.jpg)
After long-drawn scrubbing with diesel
![Restoring a 1990 Premier Padmini Deluxe BE-img_20230404_184433.jpg](https://www.team-bhp.com/forum/attachments/post-war/2442025d1687249776t-restoring-1990-premier-padmini-deluxe-img_20230404_184433.jpg)
Finally, it is all back together
Once everything was back together, Ravi did a quick adjustment for the carburetor and set the tappets. On starting the car, it sounded like a different car altogether. Gone were all the occasional vibrations and sputtering and it revved much smoother too! He told me to take it for a small spin and come back, post which he would further fine-tune the carb and tappets.
Post the fine-tuning, the car was almost inaudible on idle. It had now become a proper hoot to drive. It would start in half a crank as it should, pick up easily in second gear from a standstill, and whatnot. The only annoying thing left was the leaky exhaust. Mind you, it did sound cool at times, but I had to get it resolved. Ravi too assured, that post changing the exhaust, the car would become much much smoother.
The following day, I visited Automech to see if the existing exhaust could be salvaged. One look at it and they said it was gone beyond repair and a new exhaust was in order. Thankfully, there was not much rush at their workshop that day, so I got the job done then itself.
![Restoring a 1990 Premier Padmini Deluxe BE-img_20230407_121247.jpg](https://www.team-bhp.com/forum/attachments/post-war/2442031d1687249776t-restoring-1990-premier-padmini-deluxe-img_20230407_121247.jpg)
The gone case exhaust. A shoddy welding job had been done to it at some point.
Post the exhaust change, I cannot express how amazing the car felt. It almost felt like a new car. Ok maybe that's a bit of an exaggeration. But I'm sure many of you would understand what I mean. The difference between how the car was when I took it out of its uncared and neglected state to how it drives now is more than the difference of night and day.
This semi-restoration hasn't been the easiest. Parts have been costlier than expected and not all that easy to get. But it has definitely been one of the most fun and enriching projects I have taken up and I have learnt so much from it. BIG WIN
The car NOW drives (and stops:P) like an absolute dream. I can confidently say that it can be driven anywhere and come back without any hassles. Onto the cosmetics and bodywork now!
![Restoring a 1990 Premier Padmini Deluxe BE-img_20230407_231413.jpg](https://www.team-bhp.com/forum/attachments/post-war/2442033d1687249776t-restoring-1990-premier-padmini-deluxe-img_20230407_231413.jpg)
