Old 30th December 2018, 12:24   #76
msabbasi's Avatar
Thanked: 336 Times
Re: Restoration: 1948 Rover (P3) 75-6 Light Saloon
Originally Posted by KartikeyaL View Post
Its almost been an year now at the workshop and the car has been receiving attention in some areas, the engine is now back in the car and runs much better, the vibrations are gone.
On the body front the excessive camber on the rear springs has been corrected as seen in the picture below.
Attachment 1829949
I have received new front coil springs from the UK and if we still find the car lower from the front, might replace the existing springs as they might be a little too tired.
With regards to the correct stance of the car as it sits on the road, My humble suggestion would be to see as many pictures on the net to decide what is the correct stance. To me it seems that the rear needs to down by a couple of inches while the front needs to come up by the same amount. Pic is attached (courtesy of http://momentcar.com).
Hats of to you for staying with the project until you are satisfied.
Restoration: 1948 Rover (P3) 75-6 Light Saloon-1948p32.jpg
msabbasi is offline   (5) Thanks
Old 27th June 2019, 15:42   #77
KartikeyaL's Avatar
Thanked: 15,804 Times
Originally Posted by KPS View Post
Hi Kartik,
I somehow feel that the front bonnet is not right because the front grill is sitting low.
The angled bonnet is not matching the squarish shaped car, I am open for correction
KPS
Originally Posted by vintageman View Post
But please give thought to what KPS said , may be the body needds to be re-aligned on the chasis by a couple of inches and the radiator raised up
Chauhan
Well, the incorrect stance of the car has been irritating to me for long and finally we got onto to correcting it.
The drooping front
Restoration: 1948 Rover (P3) 75-6 Light Saloon-dsc05739a.jpg
The reason for the car drooping from the front was a bit silly, if I may say so, we did not have the correct radiator mount as it was missing, the one fabricated here was so low, that the starting handle hole and the hole in the radiator grill also did not match, all this unfortunately was missed, silly mistakes do happen, happy that we are now able to fix it.
Front taken apart
Restoration: 1948 Rover (P3) 75-6 Light Saloon-img20190624wa0030.jpg
work on
Restoration: 1948 Rover (P3) 75-6 Light Saloon-img20190624wa0110.jpg
The right stance, finally
Restoration: 1948 Rover (P3) 75-6 Light Saloon-20190626_180454.jpg
the bonnet panel's, will now have to be re-aligned and corrected.
Would like to thank everyone who brought this to my notice.
cheers
Kartik
KartikeyaL is offline   (8) Thanks
Old 27th June 2019, 16:34   #78
KPS
KPS's Avatar
Thanked: 12,086 Times
cheers
Kartik
Happy to note that this problem has been solved. I sure it make a big difference in the stance.
Look forward to seeing the car back on the road again.
KPS
KPS is offline   (1) Thanks
Old 27th June 2019, 16:51   #79
vintageman's Avatar
Thanked: 689 Times
Nice work Kartikeya, thank you for the update
vintageman is offline   (1) Thanks
Old 28th June 2019, 07:10   #80
msabbasi's Avatar
Thanked: 336 Times
It is heartening to see that getting the job done right is of paramount importance. It is of little consequence of how many times the job has to be repeated in order to do so. Emphasis is on "right".
Even the most respected restoration houses in the world repeat their work several times to get it right. Kudos to you.
Do share pictures of the vehicle profile once you are satisfied with the result.
msabbasi is offline   (2) Thanks
Old 28th June 2019, 15:09   #81
KartikeyaL's Avatar
Thank you for the motivation !
here is a picture of the work in progress !
Restoration: 1948 Rover (P3) 75-6 Light Saloon-img20190628wa0054.jpg
KartikeyaL is offline   (7) Thanks
Old 2nd July 2019, 14:16   #82
KartikeyaL's Avatar
Some more progress
Restoration: 1948 Rover (P3) 75-6 Light Saloon-20190702_113110.jpg
Restoration: 1948 Rover (P3) 75-6 Light Saloon-20190702_113138.jpg
Old 7th July 2019, 06:14   #83
msabbasi's Avatar
Thanked: 336 Times
So far so good. A picture of the side of the entire car will give a better view of how the bonnet sits with respect to the rest of the vehicle.
msabbasi is offline   (1) Thanks
Old 5th September 2019, 13:17   #84
KartikeyaL's Avatar
Finally, we have fixed this one irritating issue and the car now has the correct stance, here is one picture, more to follow soon.
Restoration: 1948 Rover (P3) 75-6 Light Saloon-69488767_2390064167780217_8556192435569426432_n.jpg
Old 8th September 2019, 07:27   #85
msabbasi's Avatar
Thanked: 336 Times
Your persistence has paid off well. It looks just right in this picture.
Old 8th September 2019, 16:28   #86
KartikeyaL's Avatar
Here is a comparative before and after picture
Restoration: 1948 Rover (P3) 75-6 Light Saloon-20190908_162259.jpg
And a few more from our Sunday drive
Restoration: 1948 Rover (P3) 75-6 Light Saloon-img20190908wa0107.jpg
Restoration: 1948 Rover (P3) 75-6 Light Saloon-img20190908wa0106.jpg
Restoration: 1948 Rover (P3) 75-6 Light Saloon-img20190908wa0105.jpg
Old 9th October 2019, 13:46   #87
KartikeyaL's Avatar
Couple of pictures from last Sunday's drive
Restoration: 1948 Rover (P3) 75-6 Light Saloon-img20191007wa0014.jpg
Restoration: 1948 Rover (P3) 75-6 Light Saloon-img20191007wa0020.jpg
Old 20th July 2020, 13:36   #88
KartikeyaL's Avatar
Pictures from a Sunday drive in March 2020
Restoration: 1948 Rover (P3) 75-6 Light Saloon-img20200308wa0056.jpg
Restoration: 1948 Rover (P3) 75-6 Light Saloon-img20200308wa0062.jpg
KartikeyaL is offline   (5) Thanks
Old 21st September 2020, 15:30   #89
KartikeyaL's Avatar
The Rover recently took part in a movie shoot near Jaipur, its a South Indian film, the number plates were changed by the film crew.
Restoration: 1948 Rover (P3) 75-6 Light Saloon-img20200918wa0015.jpg
Restoration: 1948 Rover (P3) 75-6 Light Saloon-img20200918wa0016.jpg
Restoration: 1948 Rover (P3) 75-6 Light Saloon-img20200918wa0033.jpg
Old 28th September 2020, 21:56   #90
msabbasi's Avatar
Thanked: 336 Times
Wow, She was already a star of these pages but now a star on the silver screen
