Post-War
https://www.team-bhp.com/forum/post-war/)
Originally Posted by kevinephraim
(Post 2856445)
firstly congrats on yet another one!
Is the red the final finish coat? and so.. now what? Will it come back to you after painting, for the Mechanicals?
I am a little confused after seeing the pictures and reading through the posts. |
Thanks Kevin :)
The Red is not the Final Finish coat, by wednesday we will have the FINAL SURFACER sprayed on, after which the ONLY job left would be 3 coats of final paint. I shall post the pictures once the surfacer is sprayed.
Basic mechanicals will be worked on here with me, only the Bolt-On Engine will be done elsewhere. Nothing to get confused, i really wished to finish 100% restoration on this Beetle, after having done so much, but you really cant do much.:)
Great to see your efforts and dedication towards the restoration of such a priceless machine yielding fruitful results.
I am amazed at the level of details you have mentioned with complementing photographs.
Have always been a mute reader of all your restorations so far and loved the VW Micro Bus one the best. Somehow, that one came up really well in Yellow and I personally liked that too.
Hope to see rest of the details in coming weeks:thumbs up
Originally Posted by paragsachania
(Post 2856499)
Hope to see rest of the details in coming weeks:thumbs up |
I never get tired of VW's you know:D
The Bus truly took too much of my time, but its now running nice.
Coming back to the project, 3rd week into the work that has gone in. The painter has made sure this Bug is Rust-proofed Inside out. Each nook and corner is properly sealed, every panel is properly tapped out and treated.
We are treating it with the FINAL Surfacer ( GLASURIT - Germany ) in a days time, after which the basic mechanicals will be done and the car should be sent out to the respective owner for further work.
YET.. The only grouse i will have is "Not having got the chance to Complete the BUG after doing all the major of Donkey's work"
Almost at the fag end of body shell restoration. Complete shell is now
1) Rust-proof
2) Body-tapping done
3) Metal replacement done
4) Shut-lines checked and set
5) Body-lines checked and set
6) Door/ decklid / bonnet setting complete
7) Mechanical components opened out, cleaned and painted
8) Few mechanical components replaced (tie-rod ends/suspension dampers/ axle joints/steering damper etc)
9) All locks and handles fitted and working fine.
I am thoroughly happy with the painter with the budget and the timeclap:
He said 3 - 4 weeks and an approx., budget of Rs.55k and he has been Bang On with both, the Budget exceeded a wee bit more by 2k, but the quality of work done is top notchclap:
I just wish this bug would have been finished by him.. sadly, i can just wish all the best for this bug at its new place, The new painter must actually take it over from here and not goof up.
The bodyline has come out really impressive, smooth and even & so are the panel gaps, as you mentioned. I think apart from final spray and fittings( including interior) everything else has been taken care of. Great work Pavan ji.:thumbs up
Originally Posted by samsag12
(Post 2870632)
The bodyline has come out really impressive, smooth and even & so are the panel gaps, as you mentioned. I think apart from final spray and fittings( including interior) everything else has been taken care of. Great work Pavan ji.:thumbs up |
Fresh updates.
The car is getting towed to the paint booth ( GT Tuners ) today evening.
And
YES..! i am getting to finish the painting and detailing job on this car:Cheering:
More updates later.
Paint shade selected and its the same shade as my 1967 VW Beetle - YUKON YELLOW :)
The paint is from DUPONT and the quality being DUPONT SUPER. As the name says it, Its Super Expensive at around 13k for a complete final paint kit
1) 1.5 ltrs Covering coat - WHITE
2) 2.5 ltrs Final coat - YUKON YELLOW.
Hoping to finish off with the painting by weekend. The car has reached GT TUNER's (Mohnish - T-BHP)
Hi Mr Pavan,
Been following your threads with interest as I have a typr 3 awaiting restoration. Just a quick query?/ where to source parts for it?? any ideas???Please do let me know if you do have any reliable source for mostly mechanical parts, rubber parts and trims lights etc a reply to me on planter472002@yahoo would be most appreciated. Thanks
Arthur
Pavan ji thats great news, looking forward to the WIP pics and final outcome. I am sure with the level of prep work your team did on this Bug, its surely gonna be a flawless car. Won't talk too much, kahi nazaar na lag jaye :) Best of luck.
(Post 2880500)
Pavan ji thats great news, looking forward to the WIP pics and final outcome. I am sure with the level of prep work your team did on this Bug, its surely gonna be a flawless car. Won't talk too much, kahi nazaar na lag jaye :) Best of luck. |
The D-day arrived, Yet again BUNKED office for the Nth time this month, and off i go to GT Tuners where the car is parked.
1) Wet-sanded the car over once again
2) Checked all the spots and re-worked on the putty job
3) Dried the car, cleaned up and loaded it into the paint booth.
4) Sprayed Dupont Base White, allowed it to dry
5) Wet-sanded the white again to get that smooth surface
6) De-greased the car
7) Sprayed 3 coats of DUPONT - YUKON YELLOW (Same shade as my VW Beetle):D
8) Switched ON the afterburners for baking the paint, and returned home by bidding good night to the Dirty fellow inside.
One full day at GT Tuners and exhausted, but Job done, no complaints:thumbs up
Visited GT Tuners this morning, the paint has baked perfectly. Color looking very good. :)
Some snaps
Pavan, is this the final coat?
I could see the paint coats as it was sprayed on the bonnet. Guess you have one more coat, right?
Originally Posted by PAVAN KADAM
(Post 2867060)
We are treating it with the FINAL Surfacer ( GLASURIT - Germany ) |
Pls share your experience with Glasurit surfacer.
Is it easier to use? Any other differences (positive or negative) that you or the painter observed?
Originally Posted by mjothi
(Post 2886635)
I could see the paint coats as it was sprayed on the bonnet. Guess you have one more coat, right? |
Sir, Pardon me. The pics are from my mobile phone camera, and they dont do justice to the actual surface.
Please wait up for sometime before i put some better resolution pics. :)
Originally Posted by thebulletboy
(Post 2887040)
Is it easier to use? Any other differences (positive or negative) that you or the painter observed? |
Pankaj, the Glasurit surfacer is actually Wonderful, It binds very well and masks off any minor scratches or surface dinges. BUT if you are painting lighter shades like Yellow / White / Red this surfacer is a pain as it has Green Tint, So you have to do a White Base to get the covering and the Depth right. Same as i did with this car.:thumbs up
The color's looking eye-catching, i will reserve my comments till i see some pics clicked under natural light although paint has indeed come out smooth & even. :thumbs up
