Re: Volkswagen Vento : Test Drive & Review Thought of providing updates on the works done as the car had been driven for some 400 kms after. Quote:
Originally Posted by Crank Dealer is suggesting a Suspension overhaul and a few other changes which will cost upwards of 60K. | Quote:
Originally Posted by Crank Visited Jai Prakash on Wednesday. He did a test drive and inspected the suspension. He said it needs a complete overhaul. | Quote:
Originally Posted by Crank Suspension overhaul will cost 33K for Sachs and 30K for Monroe. |
Suspension was completely overhauled with TRW shocks, both front and back including steering rack. Total cost came to Rs. 36,700. Got the work done at a FNG nearby - Surya Motors (Bosch Service) at Pallikaranai, Chennai.
After the overhaul, I am able to feel the ride is bit stiffer, but no rear suspension noise or the thud over speed breakers. I also feel a bit of discomfort in uneven roads, sometimes, where the right and left shocks movements are felt as if they are not in sync. Probably its just my feel knowing there is a change in shocks. I am expecting the shocks to settle over a period of time as its now much better than the first ride. Fingers crossed.
I tried a maneuver that I had done multiple times, in which I navigate a 45 degree curve at a particular speed. With the new suspension it didn't feel that confident, so did it at a solid 30 kmph lesser. Again probably my perception. But certainly wanted to play safe.
Overall, the suspension work helped to drive confidently over rough patches without any problems, but the ride quality isn't plush. Quote:
Originally Posted by Crank Also by then my AC was becoming less effective. He is quoting 37K for the complete AC overhaul including the condenser coil. If we skip the condenser coil, then it would be 30K. |
Surya identified this to be a problem with a Compressor valve and not the compressor itself. So was able to fix this at Rs. 4,600. Quote:
Originally Posted by Crank He also suggested timing belt / chain change, which would cost 20K. He would get the timing kit that includes the water pump. |
Got this done by Surya at 21K.
Reason: Grammar
