Old 26th July 2012, 08:10   #2791
superutp's Avatar
Thanked: 303 Times
Re: Chevrolet Beat : Test Drive & Review
Originally Posted by faustus77 View Post
Superutp
Hi
Read that you are maintaining 34psi tyre pressure
AFAIK the company recommended is 32psi and the attendants at a petrol pump advise 30psi.I fill around to 31psi.
I do not drive for days together so what pressure would you recommend?What is the advantage of overinflating?
Thanks and regards
Originally Posted by AbhishekB86 View Post
If you were my younger sibling I would confiscate the vehicle and wouldn't let you drive for a week.
22? Why? 34?? Why superutp why? The vehicle will be fine at 32 and you shall feel no harshness in the ride quality. Although I am happy to see such continous excitement about your ride, If I come to your city we're meeting up to share the happy vibe
@ Abhishek: would you really do that after all the 'continuous excitement' I have provided?
22 because I forgot that car owners check tyre pressure of the tyres of their cars.
34 because I always thought increasing the tyre pressure aids in improving FE!!
P:S If I come to your city, we are meeting up so that you can teach me the 'shift at 2k' mantra
@faustus: As I said above, I was always under the impression that increasing the tyre pressure by a few psi helps in aiding FE albeit at the expense of ride quality.
OT- So I guess that theory is not true??
But my FE did improve or was it a placebo effect as a result of ignorance.
superutp is offline
Old 26th July 2012, 10:55   #2792
Auto freak's Avatar
Thanked: 347 Times
Increasing the tyre pressure to 34psi will theoretically have a benefit in terms of FE. Downside being a slightly stiffer ride quality.
This is because a higher inflated tyre tends to be more stiff and has lower rolling resistance. Same can also be achieved with tyres made of hard rubber compounds (tyres that claim to last long and improve FE)
I experimented this with only the front tyres inflated to 34 and rear at 32. I found a marginal improvement in FE and have been maintaining the same pressure since. Not much of noticeable harshness in ride.
PS: I run Michelin energy XM1+ 175/65 which by itself is a soft compound tyre and is wider than stock. May be that's why I don't experience a noticeable deterioration in ride quality
Auto freak is offline   (1) Thanks
Old 30th July 2012, 13:42   #2793
Mortis's Avatar
Thanked: 1,473 Times
My 1 year and 2 month old Beat has started rusting under the rubber beading that surrounds the window frames. Could you guys check whether the same is happening in your cars ? Just pull back the lip of the beading around the windows and take a peek inside.
What should be done about this ? Does the Beat have a rust free warranty ?
Mortis is offline
Old 30th July 2012, 22:42   #2794
jeganatu's Avatar
Thanked: 985 Times
Yes. Rust proof warranty for 3 years. Check your manual.
jeganatu is offline
Old 31st July 2012, 22:21   #2795
white-rabbit's Avatar
Thanked: 35 Times
Originally Posted by mi2n View Post
Got the 30k servicing done. Skipped on nothing. Changed everything as per schedule and some more. Paid INR 4500 in total including some voluntary replacements including wiper blades, couple of lamps, the pollen filter(was replaced without consent). Along with the carb, got the fuel tank cleaned as well. Car feels smooth as silk.
Overall, quite satisfied with both the quality as well as the reasonable cost of upkeep of my chevy.
Will try to post a detailed report/pics as an update to my ownership thread once i receive the car from the workshop where it is currently undergoing repairs of a few ding, dents and scrapes caused by an errant private bus last week.
Guys ,My car is completing 24 months in August.I have not received any reminder calls for service.It is running in 18000km odds.When will be the 2nd service done?I think we have one in 24th month/20000 km,right?
BTW,Mi2n-what is the red switch on your right hand side?
white-rabbit is offline
Old 1st August 2012, 19:58   #2796
mi2n's Avatar
Thanked: 2,257 Times
The service schedules and intervals are clearly mentioned in the owners' manual. For the Beat (P) it's 5k kms/6 months interval. As a ready reference, it's at 1k,5k,10k,15k,20k and so on. So, at 18k you should be looking at a possible 5th service. I guess by 2nd service you are referring to the 2nd paid service (the 1st three being free) unless you have skipped a scheduled service. In that case the 5th service(2nd paid service) should be due at 20k kilometers or 24 months.
You can refer to my ownership report for details of servicing here :http://www.team-bhp.com/forum/long-t...ilometers.html
The red switch(now black) is for the aftermarket Fog lights + cabin mood lights combo.
mi2n is offline   (1) Thanks
Old 1st August 2012, 20:18   #2797
AbhishekB86's Avatar
Thanked: 377 Times
As mi2n mentioned you need servicing at every 5k. You should refer to the servicing manual for schedules and if you have skipped all this while you will know through the manual what all needs to be done.
In case you have lost it I guess one of us can help you.
AbhishekB86 is offline   (1) Thanks
Old 8th August 2012, 01:32   #2798
Mortis's Avatar
Hey just wanted to give you guys a heads up and hope you can check and report back in this thread.
So after noticing a bit of rust under the rubber beading between the read window glasses and the metal frame due to the rubber being badly/loosely fitted I checked a few more Beats and 3 out of the 4 had the same problem.
So all you Beat owners please check your cars to see if the rear window rubber beading is badly fitted and if the frame inside is rusting
Mortis is offline
Old 8th August 2012, 07:54   #2799
superutp's Avatar
Thanked: 303 Times
Thanks for the info, will check mine later and report back. So did you go to the service centre regarding this?
_______
Small Update of my FE: This time around I got a FE of 11.84!! One of the best in city FE I have got so far. I have no idea how because I remember clearly revving the nuts of my Beat once in a while. Maybe its gotta do with the 34PSI tyre pressure and under 2k driving when I am not revving up.
superutp is offline
Old 8th August 2012, 11:49   #2800
Daewood's Avatar
Thanked: 234 Times
A small change in the intervals. It's 6 months as before but the km interval has changed. Its 7.5k/6 months(whichever is earlier), 15k/1 yr ...and so on.
This is being communicated by the GM dealers through posters at their service centres.
Daewood is offline   (1) Thanks
Old 8th August 2012, 23:19   #2801
Thanked: 377 Times
Hello Mortis,
Thanks for the heads up. I randomly checked the rubber beading on the left rear side and found no rust. Thankfully. Keep us updated on how Chevy A.S.S. responds to this
The Curious Case of Superutp
Yes I think the higher mileage is because of the increased psi pressure and the constant irritant after your life to shift at 2k (me )
I can just picture you suddenly jumping to 50 in second gear. Haha!
My F.E. is tumbling down. Last checked it was 12. I wonder if its got to do with the water logged roads and the constant up and down shifting from the 1st to the 2nd gear and vice versa. I tanked up again, shall update soon. Really hoping it jumps back to 13 again.
Originally Posted by superutp View Post
_______
Old 8th August 2012, 23:32   #2802
jeganatu's Avatar
Thanked: 985 Times
hi, my beats current FE level stands average at 16.5kmpl with 50% ac on HW & 14.9 kmpl with 100% ac.
City FE is between 10.5 to 12.5kmpl as our city ride is confined to lot many short runs with mixed AC usage. Do you think my HW FE is satisfactory or should I need to go for FE test? My beat is already 19900 on the odo & due for 20k service.
jeganatu is offline
Old 9th August 2012, 00:02   #2803
Thanked: 377 Times
Depends on a few factors. That is a very generic question you put up.
You would need to put in a few details:
1. Is your city run during peak hours mostly?
2. What air pressure do you maintain?
3. At what RPM do you shift gears?
4. Have you upgraded your wheels?
I can go on and on but I would suggest firstly ensure your fuel station is reliable and the correct PSI pressure i.e. 32 or upto 34(bumpy ride) maintained.
If you shift gears at 3 k then try a tank up and sedate your driving (2 k), you will see an improvement in your numbers.
I will still not suggest a F.E test unless you test it yourself with a few stations.
12.5 is a decent number although 10 isn't.
I haven't heard of Beat owners complaining of a big variance in F.E figures. On an avg I get 13-13.5 kmpl during peak hour city commute 2 hours a day.
I have done 25k+ on my car. I have no issues with the F.E or for that matter with anything. My car is niggle free
Your highway FE sounds decent. But again do put up a few more details.
Old 9th August 2012, 10:30   #2804
Thanked: 32 Times
Heard Beat 2013 is in pipeline. i dont have any valid source but can somebody give some info.
idea is offline
Old 10th August 2012, 09:45   #2805
superutp's Avatar
Thanked: 303 Times
Hello Mortis,
Dude! seriously!
How dare you only get 12 as your FE!! shame on your '2k guru' title! water logging is not an excuse!
I dont know why but I keep revving up the engine even though I know it clobbers the FE.
Have been driving with the AC off a few times nowadays and wow, the Beat feels so much more zippy' er and fun' er to drive.
I think your FE is perfectly alright. Though if driven carefully I think 18kmpl is manageable on the highway. But that would involve the traffic agreeing for your FE cause.
My city FE ranges from 10.2 -12 kmpl (but then, as I have mentioned before, I do rev up) and I have had only 2 proper highway runs, one of them gave 18 odd kmpl and the other 15.
superutp is offline
