Old 20th June 2013, 16:49   #5881
binaiks's Avatar
Thanked: 1,160 Times
Re: Fiat Grande Punto : Test Drive & Review
Originally Posted by Arch-Angel View Post
White smoke should ring some warning bells. It should be checked immediately. Are the oil levels normal? Ask them to check the oil pump as well. I forgot yours is a diesel vehicle and listed something else. Was the car driven in the rains? Ask them to do a compression test also since white smoke will be observed if the engine has low compression.
He checked with the OBD reader, and it showed that the engine was hale and hearty. He did mutter that the engine level appeared low.
Originally Posted by headers View Post
Boss: Turbos do not blow easily - The SA has no clue how to check / rectify issues:
Please go inside the workshop when they connect the OBD, ask them to run all tests - It would pin point the actual point of concern and give you a printout as well.
Ofcourse, all this is possible if the service technician understands how to use the OBD scan tool.
Please check engine compression values.
I usually sit with the guy throughout the work. I was there when he used the OBD reader as well.
Now my office days doesn't give me time to head there, and the workshop is closed on sundays as well. I hope to take an off to go there next week, and sit with him through out to find what could be the issue. I suspect the lube pump - not sure.
binaiks is offline
Old 21st June 2013, 10:09   #5882
Thanked: 426 Times
Hello,
My father owns a Fiat punto petrol, run about 30k kms. Off late, there are some issues we cannot seem to get our head around and need your inputs.
1. Whenever we turn the ignition on, we get an "airbag failure" message.
2. Car starts and runs with no problems for the most part. At times, it switches off while running and throws an "engine with a lock" icon on the display. Then refuses to start for about 5 minutes, after which it starts again and runs like nothing happened. This recurs every 50 - 100 odd kms or maybe every once in 3-4 days.
What could be the issue? Are these two inter connected? The Service centre guys say it could be the battery. However, I disagree it could be the bat since everything else runs absolutely fine. Yes we could change the bat but I doubt it will solve our issue here. Anyone else faced these issues? Thoughts?
Thanks!
Kapil
wolfy is offline
Old 21st June 2013, 10:13   #5883
headers's Avatar
Thanked: 559 Times
Originally Posted by wolfy View Post
Hello,
Thanks!
Kapil
It IS the battery. Fiat has this unique feature of checking battery threshold voltage and raises such alarms if below specification.
headers is offline   (4) Thanks
Old 21st June 2013, 10:15   #5884
Thanked: 426 Times
Thanks headers.
Both issues inter related? Air bag failure yes. The second issue too?
wolfy is offline
Old 21st June 2013, 10:25   #5885
headers's Avatar
Thanked: 559 Times
Yes..replace battery then all issues go away..
headers is offline   (2) Thanks
Old 21st June 2013, 10:38   #5886
Thanked: 539 Times
Hello,
Thanks!
Kapil
The first issue is definitely one related to the battery. Change the battery and the problem will disappear. This error message used to show on my car on and off for the good part of a year. But when it started to become a daily affair, I decided on changing the battery.
The second issue could also be the battery, but I am not be sure. The "engine with a lock" is actually a sign for the engine immobiliser getting activated and the engine shutting off. In the year or so the "airbag failure" warning kept popping, I never had this issue.
julupani is offline   (1) Thanks
Old 21st June 2013, 11:10   #5887
Thanked: 3,075 Times
I have the same "Airbag Failure" message in my car now and the FIAT ASC mentioned that it is due to the battery. They checked the battery and confirmed that it has become weak.
The SA also mentioned that as it gets weaker, I might get the "engine with a lock" warning as well. He also mentioned that if I stop the car (and switch off) for a few minutes after a fairly long run, the car might also refuse to start till the battery cools down a bit. So I guess all your issues are related to the battery.
However, if your car switches off by itself while running, it might be better to get that checked separately.
StarrySky is offline   (1) Thanks
Old 21st June 2013, 11:42   #5888
sandeepmdas's Avatar
Thanked: 2,678 Times
The sources of the lock sign, "airbag failure", "ABS failure -do not proceed!" and (in my case) a blinking odometer are all the same. The moment I changed the battery all these gremlins disappeared for good.
However, I've not experienced the above-said issue. I guess it too could be related to the battery; perhaps the ECU is not getting the correct/number of inputs and as a precaution it is turning the engine off ? My advise is to change the battery and then put your GP under "observation" rather than troubleshooting. Let us hope this gremlin too would go away with the battery swap.
sandeepmdas is offline   (1) Thanks
Old 21st June 2013, 11:50   #5889
Thanked: 426 Times
Cheers Guys!
Thanks for the responses! I will report back once we change the bat.
wolfy is offline
Old 21st June 2013, 16:31   #5890
Arkesh's Avatar
Thanked: 62 Times
Cheers Guys!
I am sure you will get rid of the problem after installing a new battery. My friend too had exactly the same issue on his punto 1.2. Its perfectly alright after replacing battery.
Arkesh is offline   (2) Thanks
Old 24th June 2013, 09:43   #5891
Thanked: 13 Times
Dear Friends,
I just got my Punto (BNW) delivered with 45Kms on the Odo. In the last two days I’ve covered 200kms. The Average Consumption indicator started at 11.5 and gradually went down to 6.5 then came back to 8.5. Now it’s hovering around 7 km/L. This is in Coimbatore and a heavily crowed town. Please share your expert views & advise
sivadeep is offline
Old 24th June 2013, 09:46   #5892
Originally Posted by sivadeep View Post
Dear Friends,
First of all, are you sure the MID is showing FE in km/l and not litres/100km? You can change the setting via MID.
Old 24th June 2013, 10:06   #5893
Thanked: 13 Times
Thanks for quick response. It says 7.5 l/100. Pl help to understand and change this to km/lit
sivadeep is offline
Old 24th June 2013, 10:56   #5894
theexperthand's Avatar
Thanked: 2,479 Times
@Siva: You can change the settings of MID to show KM/L instead of L/100 KM. Please take the help of the user manual - I do not remember the steps now, but it is fairly simple and straightforward. You have to cycle through the settings (clock, speed limit warning, buzer leavel etc).
7.5L/100 translates to 13.33, which I think is ok for bumper to bumper city traffic.
theexperthand is offline
Old 24th June 2013, 11:00   #5895
Thanked: 13 Times
Great sir, I'll change. Thanks for the clarification
sivadeep is offline
