Did a quick 10 km test drive of the Basalt Petrol Automatic. I'll share my observations as an end user and compare it with my current rides (Tiago, XUV700, Glanza - all petrol) to provide a clearer view for potential owners.
Engine:
I feel this should be the most important criterion when choosing a car.
The initial pull is very strong. Despite being a turbo engine, it has strong low-end power and accelerates smoothly from a standstill. On highways, after 80 kmph, the power tapers off. I couldn't exceed 90 kmph in the city, so can't comment beyond that. Quick starts from red signals will be fun in this car. I had reset the fuel meter at start, and it showed 9 kmpl fuel efficiency at the end of fairly spirited drive. The gear lever doesn't move in straight line, it has notches for different positions.
XUV700 > Glanza > Basalt > Tiago NVH:
Noise – It's quiet up to 60 kmph, and gentle throttle inputs keep cabin noise minimal. However, if you push it hard, some noise indicates the engine is working harder. The AC becomes noisy at full blower speed. Road noise starts creeping into the cabin after 60 kmph.
Vibrations –
Super smooth, with no vibrations at all at any speed up to 90 kmph. It’s well-balanced and doesn’t feel like a 3-cylinder engine.
Harshness – Overall, it’s a refined car, but under hard acceleration, it pulls strongly and feels like it's working harder.
Glanza > XUV700 > Basalt > Tiago Ride:
This is Citroen’s strongest point in India, and they need to market it well. The
low-speed ride is phenomenal; I didn’t need to slow down for small city bumps, craters, or unscientific speed breakers. It glides over them without feeling floaty. At higher speeds, the ride feels mature and confidence inspiring.
Basalt > Tiago > XUV700 > Glanza Handling and Steering:
Handling is good but not exceptional. At lower speeds, the steering isn’t as light as Hyundai or Mahindra but is manageable. If you’re used to super-light steering, this isn’t as effortless at parking speeds. At mid to high speeds, the steering weighs up well and performs as expected. However, if you
try to change direction while accelerating hard, it tends to get nervous, and I had to let off the gas to regain composure. Taigun and Kushaq are better handlers.
XUV700 > Tiago > Basalt > Glanza Interiors:
The interior is pleasant and functional, with all buttons easily accessible and of good quality. Ergonomically, it’s well sorted. The seat has height adjustment with excellent range, so anyone can find a comfortable driving position. The steering has tilt adjustment with decent travel. The AC buttons are tactile and can be operated without looking after becoming familiar with them. The center armrest fouls with the handbrake when extended because the handbrake is on the passenger side. The ORVMs and IRVM are of decent size and provide good visibility. The seats are of good quality, but the leatherette finish felt inferior to the XUV700. Comfort is good in both the front and rear. The
dashboard and materials are all hard plastics but of good quality, with no creaking noises in a 1,800 km run test drive car. VW and Skoda could learn from Citroen here. There are 2 cabin lamps with a yellowish hue. It seems they aren't LEDs, but I’m not sure. The view from inside is good, and the bonnet was visible to me at 5'6" height, even at the lowest seat position, though it lacks an SUV feel and is more car-like to drive.
XUV700 > Basalt > Tiago > Glanza AC:
It cooled well but not as efficiently as the C3. It's quite noisy at full blower speed, but this might be because it was a hot day, and I did the test drive around 2 pm. Overall, cooling was more than satisfactory. No sunroof is an added advantage here, and I didn’t miss it.
Glanza > XUV700 > Basalt > Tiago Space utilization:
The cabin space is good but not comparable to Creta/Seltos or GV/Hyryder. The rear can seat 2 adults comfortably, but the third will be a squeeze. Small children can sit easily. The
boot space is excellent, and you can pack for 5 adults for a week-long road trip in Indian style.
Glanza > Basalt > Tiago > XUV700 Exterior:
The car looks good aesthetically, but looks are subjective. It has 16-inch wheels with striking alloys. Slightly bigger wheels could improve its stance and road presence. The pull-up door handles were not an issue, and I didn’t even register them as unusual. They are cohesive and don’t cause any problems. However, the keyhole is an eyesore. The
door thud is good in both the front and rear. The boot lid has decent weight. Note, the car has scored 4 stars in BNCAP. The flip-type key is of good quality but again, made of hard plastic.
XUV700 > Basalt > Tiago > Glanza Quote:
Overall:
When I saw it in pictures, it looked great, but on the road, it seems smaller and was a bit underwhelming. However, on the road, it garnered a lot of glances, and even bigger vehicles like the Fortuner gave way at intersections. Currv, on the other hand, looks better with its bold design on the road, also it seems to have more premium interiors compared to Basalt. Though the C3 Aircross appears bigger than the Creta, this car is not comparable to the Creta in terms of size, maybe due to its sloping roofline and shorter wheelbase, which make the Basalt look smaller. The top-end model goes for around 16 lakh+ and feels pricey at that range. It's a good attempt to boost sales and can be improved in future iterations. Anyone looking for Magnite, Kiger, Venue, Sonet, Brezza, 3XO can consider but those looking for Currv, Creta, Hyryder etc may not go for this!
Pricelist : Basalt 17 Aug 24.pdf |
Note: Although I don't own a Citroen, the Pune dealer B4S Motors has been consistent, providing home test drives of the C3, C5, and Basalt after a couple of follow-ups over the years.
Some pics -
