Old 27th September 2023, 17:40   #2026
Thanked: 542 Times
Re: Maruti Jimny Review
Originally Posted by quickdraw View Post
Friend had gotten Koni FSD installed on his Jimny from MotoPoto
Kindly share your friend's feedback on the Koni shocks + H&R springs with 20 mm lift setup (that's the combination that's shown on MotoPoto website)
How does it compare with the stock suspension on
1) High speed cornering, handling and stability
2) low speed comfort and ride quality
3) gravel/broken roads ride
4) off road performance
Also, are the shocks adjustable? Does the vehicle have to be lifted on a lift for shock adjustment?
Thanks in advance.
PYSO is offline
Old 28th September 2023, 14:27   #2027
Thanked: 956 Times
Originally Posted by ShivC View Post
The correct one to order in case 5 are required is as under:
https://www.faradshop.in/p/galaxyloc...5-locks-1-key/
The Description is : Car Wheel Locks Galaxylock HA4/M 5 locks + 1 key
Have got these 5 fitted to all wheels.
In case you need help in ordering or otherwise please contact Kalpesh from Farad : 93260 89919‬. He is most helpful.
Attachment 2507174
I order these and got M14x1.5 instead of M12x1.25. Need to return it I guess.
Ragul is offline
Old 28th September 2023, 17:13   #2028
Thanked: 956 Times
A dozen missed calls the whole day with emails sent yesterday and today and - No Response. FARAD India is the most pathetic seller I have seen online. I guess he misplaced his phone in the gutters of Mumbai somewhere… such a small order and so much pain! Buyers - Beware making any purchase from this seller… first he doesn’t know to ship the correct parts for the Jimny, then this!
Ragul is offline   (8) Thanks
Old 28th September 2023, 19:39   #2029
Thanked: 177 Times
Can anyone enlighten us about how the windbooster helps? Does it work like a Diesel Tuning Box or is it a ECU that increases the power/torque ?
Drlmtukkar is offline
Old 29th September 2023, 09:13   #2030
ShivC's Avatar
Thanked: 581 Times
Yes I think what you have been delivered is for THAR. If you drop a message to Kalpesh he will most certainly respond and get the wrong one picked up and the right one delivered. His lack of response should be a one off as I have found him to be very responsive in the past. Do let us know how it plays out. The community will most certainly benefit from such feedback.
ShivC is offline
Old 29th September 2023, 22:16   #2031
fiat_tarun's Avatar
Thanked: 3,793 Times
Thanks to some pointers here, I ordered the floor storage tray and arm rest from Amazon Japan.
Got both for ~10k INR including shipping and duty and in 5 days! The local sellers were selling just the arm rest at ~11k INR. Super happy with the quality of the products as well, especially the floor tray which is made entirely out of soft rubber unlike the hard plastic one's being sold by local sellers.
fiat_tarun is offline   (22) Thanks
Old 2nd October 2023, 11:14   #2032
Thanked: 154 Times
Originally Posted by : Ragul View Post
I got a set of 6 hooks from Amazon @250/- a piece but now I don’t know where to screw them in. The purpose is to tie down stuff that jumps up over speed breakers using a cargo net, and I don’t see how I can achieve my objectives with only the sides of the car boot providing a place to put in any hooks and that too very high up whereas at least some hooks need to be on the floor (at least on the rear door side). I don’t want to drill holes into my brand new car as of yet. What are these moveable MGP hooks?
Attached below where all to attach the hooks dear.
All kinds of hooks can be attached at these points using M6 bolts.
Lavs is offline   (5) Thanks
Old 2nd October 2023, 14:07   #2033
Neil Roy's Avatar
Thanked: 1,679 Times
Been using the windbooster now for 2 weeks and that too inside the city only. Vehicle seems to more peppy and builds speed pretty quickly. It does not increase the power or the torque. It only increases the throttle response. Modern day car accelerators use electrical signals to control the engine RPM. Throttle controllers like windbooster, GTE tuning etc control the sensitivity of the accelerator pedal. Maximum power & torque of Maruti Jimny is 103.39bhp@6000rpm & 134.2nm@4000rpm. It means that maximum power and torque can be attained only at 6000rpm and 4000rpm respectively. Throttle controllers aid the process of attaining the power and torque quickly and repeatedly.
There has been enough debate about the supposed placebo effect of "throttle controllers" in general and has been discussed to death even on this forum...
https://www.team-bhp.com/forum/modif...-response.html (PedalTune: Customisable throttle response)
Iam very much happy with the Jimny post the windbooster. The way I see it, when we can spend 17 lacs on a Jimny, spending another 17000 isn't really going to hurt us more
Originally Posted by SUVolens View Post
Day 2. Srinagar
.....don’t despair by its highway lethargy. This car can be as much fun as a barrel of monkeys when you have the intent. It has enough composure to hold its line, as long as you have the measure of its super narrow power-band. 2,500 – 4,500 RPM – that’s where it’s all at........
100% true. The way the Jimny performs in this power band is a revelation. Only downside is the mileage which goes south real fast. Can you share the mileage displayed in these speeds?
Neil Roy is offline
Old 2nd October 2023, 17:03   #2034
Thanked: 177 Times
I’ve tested driven the Jimny thoroughly and have fallen in love with it. It’s the manual for me.
One problem though was -
The super short seat squab of the rear bench - has anyone tried fiddling with a longer base.
Also has anyone got a tuned Jimny?
Thanks Neil for enlightening me on the windbooster. Will surely give it a thought.
Old 3rd October 2023, 17:11   #2035
Thanked: 69,460 Times
Suzuki Jimny shatters bizarre world record.
Almost 800 pint-sized Suzuki Jimny off-roaders gathered in South Africa for a unique world record attempt.
Link
volkman10 is offline   (6) Thanks
Old 3rd October 2023, 22:32   #2036
796 Suzuki Jimny drivers set Guinness record for turning lights on simultaneously.
Old 4th October 2023, 16:57   #2037
RDS
Thanked: 442 Times
While they were at it, they could have used the time more judiciously, like setting the following world records:
1) Switching off Headlights Simultaneously (S)
2) Right Indicator On S
3) Right Indicator off S
4) Left Indicator On S
5) Left Indicator Off S
6) Putting car in O/D off mode S - Difficult to break this one
7) Putting Car in First Gear/L mode S
8) Move ahead 1 meter S
9) Move Back 1 Meter S
10) Not to miss - Putting in 4H and revving S / Putting in 4L and revving S/ Then putting back to normal mode and revving S
11) And Many more!
RDS is offline   (11) Thanks
Old 5th October 2023, 11:27   #2038
ecosport rules's Avatar
Thanked: 2,049 Times
One of the 'Do it yourself' hack many people have been asking me for.
Q)How to fit the rear defrost wire cap over the rear sunshade?
A)Simply use small Neodymium magnets on the provided double tapeas shown in picture and the problem is solved.
This will also make it removable when needed for easy cleaning.
ecosport rules is offline   (6) Thanks
Old 5th October 2023, 15:47   #2039
Thanked: 145 Times
Originally Posted by Rahul Lal View Post
Sometime back replaced OEM air filter with K&N 33-3151 air filter & OEM spark plugs with NGK Premium RX spark plugs DCPR6ERX-11P
With this throttling at initial stage has gone & pick up much better. Also overall engine running has become quite smooth. Even the fuel efficiency has improved.
Would like to thank you for this. Got these fitted today and my power related issues are sorted. The engine idles steady, revs freely and feels unshackeld in many ways. Thanks once again.
R.Daroga is offline   (2) Thanks
Old 5th October 2023, 19:01   #2040
quickdraw's Avatar
Thanked: 2,782 Times
I've had a chance to drive the car myself so will answer your questions.
1) High speed cornering, handling and stability - Much better than stock, it rides very flat and high speed stability and handling on tarmac is excellent
2) low speed comfort and ride quality - Great on tarmac, lesser wallowing so that results in better ride comfort
3) gravel/broken roads ride - A bit too stiff in my opinion, we are planning to adjust the dampers and check. Will update here once had a chance to do that
4) off road performance - Friend is happy with it. No trouble with damping performance but I prefer my stock Alpha ride quality. I do feel there was a downside because he was using steelies with 225 and mine has alloys with 215 section tires
Yes they are adjustable but you need to remove them and twist the upper part to adjust it. So they need to be taken off the car for the same cant be done on the fly.
quickdraw is offline   (2) Thanks
