After owning the Hyryder G Hybrid variant, I do concur on most of the issues highlighted by bullboy.
Originally Posted by bullboy
1. Sunroof and AC: The sunroof transmits significant heat to the cabin, affecting mileage. During morning runs (7:30 AM - 10:00 AM), the car returned 3-3.5 km/l more than in the afternoon, despite similar traffic conditions. This issue is exacerbated by non-UV cut glass. The AC struggles to regulate cabin temperatures, with rear passengers still feeling heat from above. It's disappointing that neither Suzuki nor Toyota has addressed these concerns. |
This is so true and in peak summer when the sun is overhead, the heat is literally felt on the head. It's similar to how one feels while using a black umbrella under harsh sun. The AC is not bad rather the heat entering the cabin is high. You can feel the heat when you hold your hand near the mosquito net.
2. NVH: The engine feels unrefined and diesel-like when revved, with intrusive cabin noise. Vibrations are felt on the passenger seats, accelerator, and steering, especially at standstill when switching from EV. Road noise and electric motor noise are also noticeable.
I agree. The car gets noisy when revved and there is more frustration as the car does not pace up while the engine whines like an old horse. I can relate this to the old RE that I used to own. I had used diesel engines before (1.6 TDI) and it's more crude than it (say equal to the 3 pot 1.2 TDI)
Originally Posted by bullboy 3. Ride: Despite minimal suspension thuds, the ride is stiff, and road imperfections are felt in the cabin. I haven't driven at high speeds, so I can't comment on speeds above 80 km/h. |
The suspension is good for the city if you compare competition like Creta/Seltos. However, on the highway lanes with speeds beyond 3 digits it is a bit unsettled at high speed banked corners. You won't feel the confidence to push. It behaves like a Fortuner at bends.
Originally Posted by bullboy 4. Seats: The under-thigh support is lacking, causing discomfort during long drives. I've experienced back pain during drives of over an hour and now rely on support pillows. The rear seats are too upright, even in the second position, and lack proper support. The cushioning on the seats is slightly on the softer side. |
It depends on the build of the person, but overall for the price better seats are expected.
Originally Posted by bullboy 6. Parking Sensors: Lack of front parking sensors in a car of this price range is surprising. |
The visibility at the front left corner is poor as the car is kind of bulbous so to speak. It needs one also considering the long bonnet.
Originally Posted by bullboy 8. A-Pillar Blind Spot: A significant concern, especially when combined with door visor, a big problem at night. This could have been mitigated with front parking sensors and blind spot monitoring. |
This is similar to a Jazz.
Originally Posted by bullboy 9. Comfort: Rear seat access is challenging for elderly, and overall comfort is only okish. |
Adding to this the rear seats are stiff, maybe a different foam to save some space to accommodate the battery. And a major let down is the rear headrest which can't be pulled down fully as it nudges onto the mid neck which is uncomfortable and it has to be always set up, which block the rear visibility.
Originally Posted by bullboy 12. Ambient Lighting: Poor visibility and fixed colors limit its usefulness. |
Reminds me more of the Swift. They could have gone with any other colour than the dreadful orange.
Originally Posted by bullboy 13. Creaking/Noises: Due to the aforementioned quality issues, there are creaking noises from the front dash and the rear tray that extends the battery floor, especially on bad roads. |
Had this issue of creaks coming around the mid-console area. This is addressed after my complaint about it with a insulation kit that is silently provided by Toyota to customers who complaint for free of cost.
Originally Posted by bullboy 14. Headlights: The headlight is weak, and the throw in low beam is not good. It's also too close to the car and not adequate in the rain. As I understand, it cannot be upgraded either. Fog lamps are sorely missed. |
Every headlight is poor nowadays, so it's a bane for us Indians altogether.
Originally Posted by bullboy 17. Music System: The system is basic, even in the top model, and falls short compared to what competitors offer. I would describe it as marginally better than the system in my Ignis. |
The music system is bare basic for the price and it gets boomy if you enable speed-dependent volume ON. The door pad vibrates if you keep a water bottle in the storage area adding to the embarrassment.
Originally Posted by bullboy 18. Voice Command: Limited functionality and unintended activation are frustrating.Missed turns in the map when it activated by its own. |
Never used this thanks to Siri.
Originally Posted by bullboy 20. Horns: The horn is a standard fitment found in all Suzuki cars, such as the Swift and Baleno, etc. The dealer provides an option for a Windtone upgrade priced at Rs. 2950. |
I still find the horns decent enough for an OEM one.
Originally Posted by bullboy 21. Driver Door Issue: The driver's door does not close on the first attempt, attributed to air pressure. However, my concern arises from why this issue is exclusive to the driver's door and not the others. The door's construction feels notably light. |
The door closing is still an issue. Maybe this is a design flaw where trapped air is not vented out.
Originally Posted by bullboy 22. Dub Dub Noise from the Brake Lever: When switching between the accelerator and brake pedals, the lever hits the limiter and produces a sound. Upon observation, it appears there is no rubber or damper bush in the connector of the brake booster and lever. |
There is also a noise when you suddenly take your legs off the brake. A thud that is found in cheaper cars of Suzuki stable.
And the mileage figures are not so great if you drive it like a regular driver (no grandma hypermiling please) I get around 14.6 KMPL in city and 20.5 KMPL on highways.
The car is true to TBHP review a 'good attempt' on mass market hybrid just not the best.
