16th December 2023, 22:54 | #9451 | |
Newbie Join Date: Oct 2023 Location: Kochi
| Re: Mahindra XUV700 Review Quote:
(2) Thanks |
The following 2 BHPians Thank the.photosapien for this useful post: | IamNikhil, rs_cockpit |
17th December 2023, 01:39 | #9452 | ||
BHPian Join Date: Mar 2021 Location: PB08
Thanked: 716 Times
I know many people with XUV700, and none of them have encountered this problem. | ||
() Thanks |
17th December 2023, 01:48 | #9453 | |
() Thanks |
17th December 2023, 01:52 | #9454 |
BHPian Join Date: Mar 2008 Location: Bangalore
Thanked: 783 Times
| Re: Mahindra XUV700 Review I seriously feel the key detection component has a bug either in the sensor or software and needs a look in by M&M, have heard exact same issue from another owner too. You can also see this creating issues with key tagged profile - if you keep this feature activated in adrenox you will repeatedly see "Activating profile <name>" message popping every now and then instead of once during bootup and I feel this happens due to the system dropping and sensing the key back again. |
(1) Thanks |
The following BHPian Thanks Sandegov for this useful post: | rs_cockpit |
17th December 2023, 10:17 | #9455 |
BHPian Join Date: Oct 2023 Location: BANGALORE
Thanked: 153 Times
| Re: Mahindra XUV700 Review |
(1) Thanks |
The following BHPian Thanks SamDiablo for this useful post: | himanshu_trikha |
17th December 2023, 11:45 | #9456 |
Newbie Join Date: Aug 2022 Location: Mumbai
Thanked: 7 Times
| Re: Mahindra XUV700 Review Dear tbhp members, I post this to get valuable inputs from the group members on an issue where I am going through a state of distraught and perplexity wrt my XUV700 . Vehicle : XUV700 Diesel AT Luxury The problem statement: Sudden Battery drain resulting in vehicle not starting- Needing Jump Start With jump start Vehicle starts and then there is no problem whatsoever, till the issue reoccurs suddenly. Occurrence: 4 times in 1.5 years First : Within a month of purchase ( Purchase date 31st July 2022) Second time: 23rd Jan 2023 Third time : 20th Nov 2023 Fourth time : 13th Dec 2023 Problem Description: Vehicle runs daily around 80 Kms . In 1.5 years I have cloaked 35k Kms. On all 4 occasions mentioned above, the vehicle had run at-least 40 Kms. After reaching the destination, it was parked and in the evening upon starting it did not start. Time lapse between last vehicle stop and problem occurrence: 8-10 hrs average There is no consistent pattern in other operations while the issue occurs. For ex – At times all of the other operations like Driver Seat movement, Window roll up and down, Remote operated door knobs would all not work. Sometime some of them would work. Vehicle gives cranking sound but doesn’t start . Resolution: I have approached service center in 3 out of 4 times . They could not find any issue with the vehicle or the battery and returned the vehicle with simple statement : Sir everything is all right, lets see if this comes up next time In their submission , they have checked with scanner , fuses and there is no electric current leakage Once ,they have also sent the battery to Amaron to check which took a week and same result. Battery is fine. Yesterday ( 16th Dec) : I decided to directly go to Amaron Pitstop and get the battery checked. The result seems to be again “GOOD BATTERY”. The guy checked initially with Multimeter then a proper Battery meter and water levels also checked and found ok. Agony: The issue is so random that I have lost confidence on vehicle coming alive next time I push the start button. The bigger concern is that there has been till date No diagnosis of the problem. If it was a battery problem I would have invested ( assuming its past 1year warranty ) but I don’t want to do that till the time I am sure that problem is with the battery and not the vehicle I am also not hopeful of diagnosis with Mahindra Service Center because of their failed attempts till now and their known missing abilities/aptitude for diagnosis. While I understand approaching the Service center will be the only way out but at this time I have exhausted my own line of probe and I seek opinions, ideas, workarounds on this matter both on the technical side as well as how to approach M&M to solve it . Needless to say, having been a car owner and enthusiast for over 20 years , I have taken full precautions to not let the battery die for reasons of cabin light kept On by mistake,using infotainment system without starting the car ,even to the extent of not using parking lights when vehicle is switched off. |
() Thanks |
17th December 2023, 20:14 | #9457 |
Newbie Join Date: Sep 2023 Location: Kallakurichi
| Re: Mahindra XUV700 Review Dear bhpians, This is my first post after my introduction post after gaining my membership. Thank you all for providing such a great review and updates about your ownership of beloved machine. I have been looking out to replace my dad's Ford Figo. Love at first sight I happen to look at Jeep Compass on Bengaluru roads back in 2017 and fell in love with its stance. Later in 2018-2019 I happen to drive my friend's Compass since we worked in same company and also in same building. Our outings for weekend were planned as family outing and I absolutely loved Compass drive and handling. I happen to drive the car occasionally and loved ut. But, I was not so serious to replace the Figo at that point of time. After WFH due to the covid then job switch during the pandemic I happen to stay with my parents along with my wife and kid. Love for 700: Later in 2021, the urge to replace the Figo started increasing slowly. I was looking at Compass but I felt that it was priced higher for what it offered and decided not to go with Compass. And during that time, I came across the mighty 700 teaser. Fell in love after the teaser and started browsing about the release date, specs, etc. extensively. I even added the car to the cart and tried to book on the first day with introductory price. Booking failed and I tried again. Even after repeated tries, the booking didn't happen. Later I decided not to go ahead with the booking. I happen to get a call from the dealer on the 2nd day of booking and they were ready to punch a booking in my name with the first day's introductory price. But I did not go ahead with it. Took my first TD in March 2022 and was all smiles after the TD. The car was HUGE! For someone who has driven a manual hatchback all his life and jumping into AT SUV, I felt the car to be huge and the TD was done in a very high volume traffic road. But I absolutely loved the raw power and decided this will be my first car (purchase out of my own pocket). Coming to September 2023, I booked online for AWD version with dealer #1 on my parents 40th anniversary without telling anyone about it. I thought to keep it as a surprise even after knowing that the delivery dates on web showed somewhere in June-Aug 2024. Come October, our figo has sudden loss of power and the service people informed that there are rat bites and hence the problem. It was rectified and put a huge hole into out pockets. I asked them to spray rodent repellent on the engine bay. Slowly I disclosed to my family that I have booked AWD version of 700. I wanted my dad to TD the 700 and hence I asked for TD at my place. The showroom provided AX7L Petrol AT and my dad was impressed with the performance. We were dicussing about Scorpio-N and decided to take TD of Scorpio-N in another dealer #2 from my hometown. In November, we TDed Z8L petrol AT. I fell in love for a very high seating position in the Scorpio-N. My dad wanted petrol car for its refinement but I wanted diesel as our place in Tamil Nadu or Bangalore (work location) has no ban on diesel engines yet. And another reason, wanted better mileage. After driving Scorpio-N, I was in a confusion whether to go with XUV or Scorpio-N and cancelled my AWD booking as this dealer at my hometown promised early delivery of 700. For past 2 years I wanted XUV700 in my den but TD'ing Scorpio-N started confusing me. But I being more of a highway traveller, deicided to go with my love 700 ❤️ as I won't be going for any off roading. Now comes the part where I need your suggestions I booked 700 AX7L D AT (non AWD) Midnight Black with the dealer by paying the booking amount and booking was punched on 9th December. Fortunately or unfortunately, on our small outing for shopping on the same evening, our Figo starts acting wierd. Think it has smelled that it is going to be replaced sooner or later On the same day, almost near midnight dropped a message to my mahindra SA to check if I can get early delivery of the vehicle from first lot of 2024. On 13th morning, I was told that the same variant and color 700 is going to be billed to the dealer and they asked if I'm ok to go ahead with the delivery of the vehicle. I quickly had a word with my family and said ok to it. I was promised that invoice will be done in my name and sooner VIN will be shared to me. Meantime, I asked few doubts regarding loan processing to my SA and he told finance team will help me with loan process. Through my preferred bank, my loan is sanctioned and I told my bank not to disburse any amount before I give a go. I'm yet to sign any bank documents as of today. Also I asked my Service Advisor for PDI once the car reaches them. I even told him that I need the PDI before paying/releasing any payment. But he told me it is not possible as this car is not my original allotment. He asked me to pay something to hold the car in my name and invoice it in my name. And was told after the car reaches the dealer, I can do the PDI. If I'm not satisfied while doing PDI, they said the amount can be refund to me. All these conversations happened over call with my SA. My doubt here is, will this car come from factory for real or is the dealer trying to push me a PDI rejected car or may be if someone has decided to pass on the car due to some financial arrangements. I know I'm over thinking, but still for a car of 3Million, I need to be sure that I'm not given a defective product which was rejected in PDI by some other customer. Fingers crossed. I'm in 2 minds now, whether to go with this vehicle or wait for another 22-26 weeks (waiting time mentioned by dealer for AX7L D AT) for my alloted car to come. But I'm not sure if my Figo will hold up until my allotted car come in. Please provide your valuable suggestions and ideas. Sorry for the long post. Looking for your suggestions. TIA -ID |
() Thanks |
17th December 2023, 20:37 | #9458 |
BHPian Join Date: Feb 2014 Location: Mohali
Thanked: 273 Times
Just wanted to share my opinion on a possible issue—Immobilizer Malfunction. If your engine's cranking and turning over, but it's not firing up and running, this might be the culprit. Immobilizers usually rely on transponders in your key or fob and a receiver unit in the car. When you get that key or fob close to the ignition, the transponder shoots a coded signal to the receiver. If the code matches the one stored in the car's memory, the immobilizer system deactivates, and voila, your engine starts. Here are some potential reasons behind the glitch:
You can try switching the keyfobs as well. |
(1) Thanks |
The following BHPian Thanks sunilsoft for this useful post: | rs_cockpit |
18th December 2023, 01:49 | #9459 | |
Thanked: 7 Times
| Re: Mahindra XUV700 Review Thanks Sunilsoft, thats a food for thought and a likely cause. Would keep this in my list of points to get checked while visiting SC for resolution. Just a thought though, if an Immobilizer issue is preventing it to start, how would jump starting the car work? Quote:
() Thanks |
18th December 2023, 06:58 | #9460 | |
Thanked: 273 Times
IMO You should ask the service center to update/reflash the immobilizer software. If they could change the immobilizer and transponder even better. | |
(2) Thanks |
The following 2 BHPians Thank sunilsoft for this useful post: | Carophile, rs_cockpit |
18th December 2023, 08:05 | #9461 | |
Newbie Join Date: Dec 2023 Location: Prayagraj
Thanked: 7 Times
() Thanks |
18th December 2023, 08:12 | #9462 |
BHPian Join Date: Apr 2020 Location: Trivandrum
Thanked: 692 Times
| Re: Mahindra XUV700 Review My 700 just completed 1.3 years and had done 29k kms. I am all set for a 6k kms highway run starting tomorrow. Prepped the car for the run by doing the below things. Anything else to be checked specifically ? 30k service done. Oil and oil filter replaced. Coolant topped up. DEF topped up. Brake pads have done 10k kms only. Tyre pressure is set at 34psi. Wheel alignment planned for today. Wiper blades change for today. |
() Thanks |
18th December 2023, 09:18 | #9463 | |
BHPian Join Date: Jan 2022 Location: Chennai
Thanked: 160 Times
Finally, they replaced the front disks along with pads and since then I have covered 4000 Kilometers without much issues. At times there is a faint noise(more of a humming) while braking and coming to standstill. Far better than the earlier squealing noise. Push the service center for a replacement of Disc and brake pad assembly. | |
() Thanks |
18th December 2023, 10:44 | #9464 | |
BHPian Join Date: Oct 2021 Location: Chennai
Thanked: 143 Times
(1) Thanks |
The following BHPian Thanks Enthusiast81 for this useful post: | SS80 |
18th December 2023, 11:07 | #9465 | |
BHPian Join Date: Jul 2021 Location: Mumbai
Thanked: 2,772 Times
(1) Thanks |
The following BHPian Thanks IamNikhil for this useful post: | rpmmachine |
