Originally Posted by Auto_guy_101
I seek advice on some of the following scenarios:
1. Had to stop on an uphill section and start: For steep climbs in an MT, some clutch control and handbrake does the job, but the climb needs to be done in 1st till the slope levels a bit (my exp). The DSG has hill hold and creeps up with slight throttle, but should I switch to M? Otherwise it will rev to 2700 rpm on D1 and upshift I guess.
2. Taking manual control on DSG at low speeds: in start stop traffic or apartment roads riddled with speed breakers, I've tried shifting to M1 from D2. However, the car just auto shifts to D1 when you break a bit. Should I use the gear lever to move to M? Should I be concerned?
3. Taking hairpins: Normally in an MT, its best to take them in 2nd gear with slightly high revs so you have the power to go up. Whats the best way with DSG? Sports mode or manual control or just let it be?
4. Braking on the way down: The Kushaq brakes rather aggressively and there's no way to moderately brake and I'm not great with engine braking (esp on slopes - have tried it but not used to it). From forum comments, I guess manual mode works, but should I be careful of anything?
I'm going to be driving on hills after almost 5 years and seeing the posts about the torquey 1.5 TSI, I think I'm going to enjoy it. Thanks in advance for the tips. |
1) I take this road regularly as well as multiple other Ghats and wouldn't fret too much thinking about this. I just let the AT do its job, the D1 in the DSG is pretty short geared and for most moderate ghat climbs(like Wayanad that you suggested), it will shift to D2 and continue in D2 without any strain. One issue with shifting to M1 is that you might forget about this sometimes and might realise this only when the engine booms, since you have suggested that you haven't driven in ghats for a long time, I personally it would again be better to concentrate solely on the road and not let these other things distract you. The cars are designed to handle it. P.S if there is a lot of stop and go traffic (which sometimes happens in Wayanad), do consider shifting the gear to N or P as prefered and using the handbrake, instead of trying to fill every inch of gap that opens up. This greatly reduces DSG strain and reduces heating up chances.
The only time at which i take manual control is when I want to have some fun and be aggressive in the corners. Or when I know the next corner is just around the corner and I know it will have to downshift for the next(this again I do very rarely).
2) Here again, I usually let the car do what it wants, I believe you are worried about the clutch strain with too much downshifting and upshifting (I am not knowledgable enough to comment on what is the exact best approach on this, as I have read posts supporting either side). If you really want the car to be kept in gear 1, maybe one thing you can do is to put the Gear in S mode and try M, S in general also holds the gears much longer before shifting and If this is not enough then M1 from S.
3) I would let it be. However if the road permits, I would ideally take it in one smooth go, so that no shifting happens in between, putting it in S helps so that it doesn't upshift too fast. However the gear shifting can get sharper in S for the fellow passengers
![Big Grin](https://www.team-bhp.com/forum/images/smilies/biggrin.png)
in S
4) The kushaq engine breaks kind of descent when going downhill and doesn't upshift too fast from my observation, if you are not accelerating, both in D and even more in S. However if this is not enough and you would like for it to go slower, please do use paddle shifters to go the right M gear. Not only does it make the car go down smoother, it will also reduce your need to use the brake and reduce the chance of brake fade.
Also as an additional pointer, the issue with Kushaq brakes are its very early bite point, don't worry too much, you will get the hang of it as you keep driving it more. I was also not able to use the brakes that smoothly initially but it grew on me quite well over the time.
Hope I was able to help. Don't worry too much and have a wonderful drive. Its a great car, and if you get the Ghat section without much traffic, you will have a blast. Even if you do get traffic in the Ghats, the section after the Ghats are really great(wide roads with the right amount of curves) to explore the insane midrange without having to push.
