Originally Posted by thanixravindran Is there any update from service centre? I don't think it is to do with any fluids as they bled the clutch system. Please check the technical stuff threads as they may need to check the clutch assembly master cylinder. Please let us know the diagnosis. It is always scary to visit the service centre as they may create issues with a perfectly running car. |
Finally got my car back today(Dec 13th). And yes, like you rightly pointed out, it was issue with the master cylinder. They have replaced it and the issue seem to be resolved now. But what caused this to suddenly fail after second service is still a mystery.
Ordeal of service center visit
TLDR: They fixed the clutch issue taking 2.5 days, but this time, they stole my dashcam's SD card
Dec 11:
Visited service center to drop off my car like I had discussed with the service advisor. He took the car keys and said he'll call me the next day after fixing the issue. When I asked for the job card, he was very reluctant to give the job card and he kept insisting for the job card. He started giving new reasons every 5 mins that his system is not working properly, that the server is down, his system has to be restarted, none of which seemed believable considering other service advisors were generating the job cards for other customers right next to him.
On too much of my insistence, he came back to the desk, filled the check-in sheet(where they note down the odometer reading, complaint, scratches etc) and gave me a copy of it. I denied and asked for the proper job sheet. He again started denying and roamed around.
After too much of reluctance and making me wait for 30 minutes, he finally decided to create a job sheet and gave it to me. Not very sure about the motive behind his reluctance
Dec 12:
At 10:30, I called the service advisor to check the status since he hadn't given me any update. This time he mentioned, they are still working on it and it would take more time. He mentioned they need to check the clutch master cylinder and for that they need to open the gearbox(Not sure if it was genuine because atleast as per multiple online sources I checked, no one mentioned about removal of gearbox etc for master cylinder replacement. However for slave cylinder, there was a mention of slave cylinder being inside of the transmission in some cases). I still agreed to him since I'm not an expert in this area.
At 12:15, he calls me back and he started asking from where I got my foot mat. And he suddenly started blaming that the foot mat has caused the problem by obstructing the clutch everytime it's pressed and so on. But this definitely was fake because I clearly know the foot mat I'm using doesn't cause any obstruction and there is atleast 0.5-0.75cm of gap between the clutch pedal(when fully pressed) and the mat.
I blatantly denied his claims and he started mentioned not to use these unauthorised mats and they have sent the video to the Skoda team and they have also warned about not using those mats which might not cover this kind of repairs under warranty etc. But later he mentioned this time, he'll get it done in the warranty this time and he'll deliver the car the next day
At around 4:30, got a call from Skoda customer care. Context: I had replied to one of the tweets where one more person had mentioned about the same issue on his Kushaq and he had to visit the same service center as mine multiple times and yet his problem was not solved. I hadn't tagged Skoda explicitly in this reply, but still customer care called me to enquire. I mentioned the what had happened, and asked them not to raise the complaint to avoid conflict with the service center people. But still the customer care person escalated and raised a complaint.
At 5:15, I got a call from CRM of the service center. She started asking why I raised the complaint, while I could've directly talked to her or the service manager about the issue. I mentioned the same thing to her that firstly I didn't directly tweet to Skoda and told her that I even had asked customer care person not to raise any complaint since service center was already working on the issue. She still seemed very frustrated and asked me to delete the tweet.
Just to not escalate the situation, I even replied to the email from customer care(with service manager and CRM in cc) that I don't want to raise this as a complaint and service center is already working on the issue.
Dec 13:
I got a message from service advisor that my car would be ready around 4:30pm.
Went to the service center around 5pm, and then service advisor started giving me the papers to sign. On insisting that I want to check the car before signing, he took me near the car and asked me to check and left immediately.
I checked my car and clutch issue seemed to have been resolved.
I started checking if everything else is in place and noticed that they had completely disconnected all the cables to my dashcam(power supply and rear dashcam connector) and even the power socket plug. (context: Everytime I used to drop the car to service center, they used to disconnect the dashboard by removing the power socket plug. This time while dropping the car at service center I had turned off just the dashcam screen, while the dashcam was still on and recording just to see if they'll avoid disconnecting the cam thinking it's already turned off. Was curious to know how they take care of my car while it's in service center)
This is when I noticed that the SD card was also missing from dashcam. On enquiring the service advisor, he asked me if I really left it in dashcam. On saying yes, he came to the car and searched around. After searching, he mentioned he'll try getting the CCTV footage checked to find who would've taken it. On insisting him to get it checked while I was there, he again started acting reluctant by saying, it needs to be checked by IT people and it'll take time. Even after I mentioned I can wait, he was not ready to get it checked while I'm there and he asked me to give time until next morning. He started saying if they don't find, he'll pay for the new one from his pocket.
This is when I started suspecting they intentionally removed my SD card to cover up something they might have done while thinking the dashcam was off.
Anyway, I'll again follow-up on this in the morning and see what happens
Here's the reference document mentioning labour and part details
