Originally Posted by CircleOfLife Just before second year service, battery low indicator turned on. Car does run 5+ days a week. I pushed SA for replacement to be on safe side but their process is very clear from Skoda. First they charge the battery is able to hold it then no replacement initiated. Hopefully it doesn't knock off any time soon. Previously Vento battery knocked off at 2yrs 4 months mark and the replacement battery lasted until it was sold. |
Update: Skoda
Octavia 2021 battery knocked off just shy north of 2 years. Skoda
won't replace under warranty. Please do read ahead.
2 Years 1 Month and Varta battery
knocked off. I wonder all these Varta batteries are programmed to knock off just after warranty period. This is not new had a similar experience with VW Vento before but those were Exide batteries. Octavia being a
CKD had little higher expectation's. Why not i am paying big bucks from my pocket for it. Vehicle is completely in
stock condition and even dash cam isn't installed, but that hadn't made any difference to battery life. I take good care of the car following all procedures not to switch of engine immediately after a run, stop HU every time, let engine warm up every morning etc.
Sequence of events:
Vehicle has been throwing low battery from past couple of months and during
second year service had explicitly called out on the battery low warning issue.
Mody Uppal was the service center where second service was done.
Battery at this point was still under warranty period. Service advisor made a note of the issue and they said battery test result as good battery and as per manual they would just charge and give back. I
wasn't convinced but there were no data points after battery test report to challenge that battery is dying. Though i told SA mark my words i give this battery max 2 months. Voila prediction came true.
15/11:had to drop my kid to his badminton practice session and car won't start. All kinds of error were popping on the instrument cluster. Was in a hurry decided to
jump start the car with help of local battery vendor. Immediately called SA at Mody Uppal shared the video of the issue and conveyed that i would be coming next day 11/16.
16/11: Reached service center on time and
first battery test was done. Result came a good battery. As engine was run in hot we waited for another 1.5 hrs to let it cool and run battery test again.
Second test resulted as good battery. Service advisor was about to return car but i pushed it to be connected to ODIS to identify if there was any leakage causing the issue. Once connected to ODIS couple of steps and battery went dead right at workshop.
Had questions for the SA how did battery test turned out good battery while it is dead now with 5 mins of second test. Honestly most of these SA are hardly trained better and usually beat around the bush. There was no point chasing them for proper answer other than asking if battery can be replaced under warranty. Service advisor first checked on stock availability which wasn't there with them. Nearest SC that had battery was
Mahavir at Sanath Nagar. Car was jump started at Mody and i was off to Mahavir immediately.
Mahavir has a reputation of it's own and is among the
oldest skoda dealership in the country.
Old is gold but with Skoda none of old dealerships are gold. Skoda hasn't gained this bad boy reputation just by themselves . Dealerships are a big part of their contribution. This dealership and service center is always and will be my last preference among dealerships. My
previous experience with gear lever replacement with them wasn't good with them either. This time had to bite the bullet and reached Mahavir SC by 3:00 PM. Told them about the issue. They deiced to do battery test again and test result was good. They wanted to check if there was any leakage and as they didn't have ODIS available due to the work load for the day was asked to come next day
11/17: Reached service center on time at 10:00 AM, Job card was opened by 10:20 AM and then car was lying under sun for next 2 hrs. I had to push them to get started on the issue. One literally has to chase advisors on status update. Post lunch had to multiple times nudge SA on status update. My patience wore off at this stage and i went on the floor to talk to supervisor. He conveyed that battery is knocked off. I asked the same question even today morning when battery test was done it came as good now how it is knocked off. Again some story. Realizing there was no point to continue further discussion I requested them to check if this can be claimed under
warranty as the battery issue clearly flagged during
second service . Flat comes the answer
No. I talked to service manager to at least check with Skoda once, he redirected query to warranty head and he also denied
without checking with Skoda even once.
With both
time and patience wearing off including a PTO that had to be availed to sort out the issue, decided to shell out
16,732/- for no
mistake of mine. Yes it is part that can go kaput but i did notice the early signs
before warranty expired and no proper corrective action was taken. At end customer bear the brunt of their investment.
Mahavir also passed on the buck sir this is serviced at Mody we don't know what they have done.
They are not out of their old mentality. Still can't understand why this dealership wasn't closed when Zac closed many other non performing ones.
Btw during my time spent at service center i did see a superb being reversed and hitting kushaq and technicians casually moved ahead. This issue is not only with them but across dealerships with few other friends have major dents on their cars with other brands.
Never leave your car unattended at any service center.
I knew post Zac Hollis leaving India things will be back to usual self with Skoda legendary way of treating customers. This is one such instance of many more ahead.
My only call out is be
cautious if you observe any battery issue
with in warranty period push for a change, post that have no expectations of
Skoda being supportive about the issue. I hope they would partner with customers to have any kind of customer retention ahead.
