Old 6th January 2023, 14:20   #1426
Thanked: 1,761 Times
Re: Nissan Magnite Review
Originally Posted by Crank View Post
I have left my car for Inspection service (2k service) today. They accepted that the brake noise problem and said will try to fix it. If it doesn't go off they will change the brake parts under warranty to fix the issue. Meanwhile they were suggesting to go for Under-body Ceramic coating by 3M for 4.6K. Is that worth it?
What is underbody ceramic coating? (Usually cermaic coating is done to protect paint) I have only heard of underbody anti-rust coating.
Not needed, but helpful if you live in costal place. If at all you want to do it, do from 3M store directly.
SideView is offline   (1) Thanks
Old 6th January 2023, 14:40   #1427
Thanked: 94 Times
It's anti-rust coating. Probably uses ceramic base and hence the label says ceramic coating for under-body protection.
Crank is offline
Old 7th January 2023, 01:38   #1428
Thanked: 432 Times
I have a couple of questions about the light setup of the Magnite - now that it increasingly looks like I'm going to buy it:
1. What is the rsocket-type and rating (wattage) of the fog lights (single bulb)?
2. If the LED bi-projector (main headlight) what is the socket + wattage of the replacement bulb?
Any info on these matters would be most appreciated - as well as any links/pointers to lighting upgrades on the LED-projector variants of the Magnite.
Transmission is offline
Old 7th January 2023, 11:48   #1429
ram_hyundai's Avatar
Thanked: 53 Times
Originally Posted by josetom89 View Post
Hi guys,
Any review on JBL speaker upgrade for Magnite. Is it worth it?
Yes, there is significant change. Now they have come with an updated set of JBLs.
ram_hyundai is offline   (2) Thanks
Old 7th January 2023, 18:39   #1430
josetom89's Avatar
Thanked: 139 Times
I got mine delivered last day. The vocals are good but the bass is almost nil. Don't know what went wrong there? Stock system had better bass output. Could it be something to do with the setting in the cross over? I am not an expert in Car audio. They have installed JBL CS790 CHi components at front and 621f coaxials at rear.
josetom89 is offline   (2) Thanks
Old 11th January 2023, 00:27   #1431
Thanked: 432 Times
1. What is the socket-type and rating (wattage) of the fog lights (single bulb)?
Adding one more qn to this list:
Can TPMS be added to the spare tyre?
Old 11th January 2023, 08:52   #1432
drhoneycake's Avatar
Thanked: 1,798 Times
Both the fog lamps as well as the headlamps are sealed headlight units. The LED lighting is based off of a led chip(s) inside that emits the light. There are no bulbs inside. And hence you cannot upgrade the lighting.
If your headlight conks off for any reason, the whole unit will have to be changed.
All OEM headlight units are sealed units. They do not use crappy LED bulbs that you get in the market.
drhoneycake is offline   (1) Thanks
Old 11th January 2023, 14:47   #1433
Thanked: 432 Times
Thank you!
While I found that the headlights are pretty decent in my test drive, I'd like a little more focus and brightness. So maybe I can just swap out the LED units for the halogen one and then install better projectors with user-replaceable bulbs in the halogen units. Thinking...
Old 15th January 2023, 19:32   #1434
Thanked: 51 Times
Hi there. I have a Magnite Turbo MT and have completed 8600km. The brake grinding noise isn't exclusive to the CVT models. I too experience it occasionally. It happens particularly upon using the car, after being stationary for a few days.
It persists on slightly hard braking for a km or two and then completely goes away.
I really do not expect too much quality from this car, so I don't have a problem with this. I feel it could just be coz of that layer of rust formed on the discs. Just thought I'd share my experience. Hope it helps
rishil.ghurki is offline   (2) Thanks
Old 15th January 2023, 19:39   #1435
Thanked: 51 Times
Hi there. In short, I don't think TPMS can be added to the spare, as it's not a full-size spare wheel. It is a downsized 15" steel rimmed wheel.
Also, with my experience of TPMS, albeit limited (GLA220d, Creta, Cousin's Magnite XV Prem.), I've noticed that it's never accurate.
For reference: I too own a Magnite, the Turbo with XV trim, so no TPMS on mine.
I'm the kind of person that checks and fills up air everytime I refuel, which is usually twice a month and before long-drives, so it's never made a difference to me
rishil.ghurki is offline   (1) Thanks
Old 16th January 2023, 14:53   #1436
Thanked: 7 Times
I too am experiencing the grinding noise when releasing the brake slowly, during very slow speeds(when starting the car.). But, people who drove my car said this happens during initial usage, will go away after sometime and first few services.
I experienced engine overheating also (bonnet gets too hot to touch), but later I realized this happens only during very slow speeds, which made sense as the radiator might not have gotten enough air. Still, I expected the radiator fan to have gotten activated early (sometimes it did, sometimes it didn't. I guess the fan-temp curve used by system is to blame). I always let the engine idle for a few minutes during car start and off too. I spoke with service center people, they said it is expected (kind of made it sound like this is something of an inherent problem with all Magnites, or at least Magnite CVTs)
Fellow CVT owners, how much city mileage are you getting? I am getting about 6-11 kmpl (odometer), full tank method indicated same. I think its very low, but I guess I have to wait until few kms and services (mine did roughly 300kms only).
A fellow BHPian mentioned he got very low mileage initially, but it got better over time, but would be nice to get inputs from fellow CVT owners too.
Mine is CVT XV Turbo.
NagarjunaB is offline
Old 17th January 2023, 13:58   #1437
Thanked: 432 Times
I have had a couple of poor experiences with a partially clogged valve on a front right tyre recently and that's what made me wake up to the utility of a good TPMS.
I am even willing to upgrade the 15inch spare tyre to 16 inches - so I was wondering if the ICE unit supports a fifth TPMS. Looks like the answer is no/unlikely so far. :(
Transmission is offline   (2) Thanks
Old 17th January 2023, 22:54   #1438
Thanked: 51 Times
I personally haven't experienced any overheating issues so far (touchwood)!
But, I can share something about the FE figures.
In all honesty, when I got my car back in March 2022, it took me quite a while to learn how it likes to be driven. I noticed that until around 3000-3500 km, the avg. fuel economy was quite poor, in both city and highway conditions, more or less around the same figures you've mentioned.
Now, with 8500km+ on the odometer and I having learnt more about my car, I'm comfortably getting 12-15kmpl in the city (with AC on) and 18-20kmpl on the cruising highway runs.
For reference: I use tank to tank method (although the display is quite accurate with +/- 1kmpl) and I only fill XP95 Petrol.
Old 17th January 2023, 22:57   #1439
Thanked: 51 Times
I believe there are a few good aftermarket options for TMPS, reliable ones too.
Perhaps the ones which have sensors right in the valve caps, so it can be fitted to your spare as well, should suit your needs.
Old 19th January 2023, 12:27   #1440
Thanked: 7 Times
In all honesty, when I got my car back in March 2022, it took me quite a while to learn how it likes to be driven... .
Thank you, but, if possible, could you expand a bit more on "how it likes to be driven"? Do you mean being lite on the accelerator? Or, getting into high gears quickly? (I am bit of a novice when it comes to auto mobiles)
