Old 7th June 2021, 15:50   #1036
Thanked: 266 Times
Re: Hyundai Verna : Official Review
Originally Posted by somspaple View Post
Yep mileage is low - but considering it's a Hyundai and a slushbox it is to be expected. How far is your typical city commute? Longer commute generally results in better mileage.
Even I ended up test driving another same exact Verna and even it had the same problems. I reported it to the service center but there was nothing they said they could do about it. Yes it’s the diesel and torque converter to be blamed here but in my other torque converter cars like the creta which has the same exact engine and gearbox has less vibrations compared to the Verna. Damping sheet is a good idea to overcome this. I’m astounded that it had no impact on the clatter. Are the results competent though?
speedfreak77 is offline   (2) Thanks
Old 7th June 2021, 17:43   #1037
drhoneycake's Avatar
Thanked: 1,794 Times
It’s so strange hearing these complaints of diesel clatter. My nearly 3L kms run VERNA CRDI is still one of the most refined diesels around. Still drives like new too.
I get around 13-14 kmpl in city and 21 on the highways.
Any changes to the engine apart from the detune ??
drhoneycake is offline   (4) Thanks
Old 8th June 2021, 12:39   #1038
torquecraver's Avatar
Thanked: 31 Times
We own both 2014 Verna 1.6 CRDI and 2019 Next-Gen Verna 1.6 CRDI in the family, the refinement is not comparable to each other. The 2019 Verna sounds coarse inside the cabin and there are considerable vibrations in cabin when compared to the fluidic Verna. There is so much more diesel clatter in the Next-Gen Verna.
torquecraver is offline   (4) Thanks
Old 8th June 2021, 23:04   #1039
Thanked: 943 Times
Now the comparison with Creta is interesting. You are right, they are same engine/gb. Probably is it the issue with engine mounts then? One of the members mentioned that he had to get the mounts changed to take care of excessive clatter on this same thread.
somspaple is online now   (3) Thanks
Old 9th June 2021, 03:06   #1040
Thanked: 266 Times
I’d look into it. If the mounts trick works then I’d be more than happy and keep this car for another 2-3 years. The Creta even though is 4 years older than the Verna, Its engine clatter is way less and its far more silent.
Old 10th June 2021, 13:43   #1041
gollabhat's Avatar
Thanked: 89 Times
I have been able to extract a FE of 20kmpl on the highway in my 3.5 years old & 10k driven 1.6SX petrol. The car was driven at 70KMPH on Cruise Control. Normal highway runs returns approx. 14 - 17kmpl on the highway & 8 -10 kmpl in the city. Attaching an image for reference
Hyundai Verna : Official Review-img_20210301_102700.jpg
gollabhat is offline   (1) Thanks
Old 10th June 2021, 21:10   #1042
Thanked: 266 Times
Even though I said I don’t care about the FE, when a petrol has more FE than a diesel you can feel a bit aggrieved.
Hyundai Verna : Official Review-8b93f60074f64c4a904aca9960b7be0d.jpeg
speedfreak77 is offline   (1) Thanks
Old 21st June 2021, 10:57   #1043
vnabhi's Avatar
Thanked: 2,409 Times
Can somebody post the specs and cost of a Verna Next Gen 1.6 Diesel's battery? The car was manufactured in June 2018.
i find online portals like batterybhai and amaron.in confusing. There are too many variants of Verna listed in the former, and the Verna diesel is missing from the latter.
Thanks in advance.
vnabhi is offline   (1) Thanks
Old 21st June 2021, 13:07   #1044
Thanked: 21,429 Times
AFAIK the OEM battery is Exide rated at 60Ah. This is same in my Creta 1.6 Diesel (Oct 2017). I changed the same to Amaron FLO 68Ah in January 2019.
OEM Exide
Hyundai Verna : Official Review-img_20181016_200629_copy_1600x900.jpg
Rated at 60Ah
Hyundai Verna : Official Review-img_20181016_200453__01_copy_1600x831.jpg
New Amaron
Hyundai Verna : Official Review-img_20190124_220636_copy_1600x1200.jpg
Rated at 68Ah
Hyundai Verna : Official Review-img_20190124_191003_copy_1600x1200.jpg
Old 21st June 2021, 14:09   #1045
vnabhi's Avatar
Thanks Anurag. We changed to a newer Amaron that cost us Rs 5600 after exchanging the older Amaron. The one you have replaced is an older model that now costs 4900 in exchange.
The stock Amaron lasted only 2 years 7 months! I guess there is more battery drain on newer cars that have ventilated seats, sunroof, DRLs etc.
vnabhi is offline   (4) Thanks
Old 23rd July 2021, 18:42   #1046
Thanked: 4,767 Times
I am very curious as to what maintenance the ventilated seats require, once the car becomes older? Is it costly/hard to maintain, or is it just like your normal AC unit?
Secondly, does turning on ventilated seats on the highest setting, also affect the fuel efficiency of the car?
07CR is offline   (1) Thanks
Old 9th August 2021, 16:05   #1047
I own New Gen 2018 Verna 1.6 diesel. If I stop in the middle of steep uphill and try to start from there, it needs atleast 2 to 3 attempts to pick up, engine stalls. Is this a coordination problem or diesel engine don't have good pick up or need to press accelerator fully with black smoke from echaust?
Such issue wasn't there with my Ritz Petrol before. I drove it in Ghat roads in Kerala and Kodaikanal frequently.
Any member facing such issue? Experts please guide on this.
ybgavali is offline   (1) Thanks
Old 9th August 2021, 23:36   #1048
ph03n!x's Avatar
Thanked: 6,104 Times
How many KM have you done? How is the maintenance track of the car? I had a 2013 1.6 CDRi SX(O) and have driven it across pretty steep climbs (Wayanad, Ooty, Munnar, Kodai) - never faced what you're describing. And never has it belched black smoke.
Check the air filter, MAF sensor. Check how good the clutch is, your mileage in normal driving in the plains should be 15+ KMPL at least.
Short answer, no - the 1.6 CRDi doesn't stall that easily, and the Verna Diesel is as powerful as some of the cars that were sold along with it in the D Segment!
ph03n!x is offline   (4) Thanks
Old 10th August 2021, 21:03   #1049
Thank you for your time and suggestions. I drove it for 40k with timely servicing. Mileage is also good...21.6km/l for past 6k km.
Will get MAF sensor checked.
Old 10th August 2021, 22:51   #1050
ph03n!x's Avatar
40k is nothing for the Verna
Mine was at 1.10 lakhs when I sold it with the factory clutch! And your mileage is good too - the ~15 KMPL I've said is mine, with 120+ KMPH (that + is like full throttle ).
Any idea how steep the gradient is? The car is powerful enough to climb 30° gradients is 2nd from standstill without any accelerator input (wouldn't advice you to try, bad for the clutch)!
And how are the tyres, are they stock Bridgestones, maybe getting worn out @40k - or have you changed them?
Sigh! I miss my Verna!
ph03n!x is offline   (1) Thanks
