Old 7th March 2024, 10:17   #4546
Fusion2006's Avatar
Thanked: 108 Times
Re: Jeep Compass : Official Review
Originally Posted by SKannan View Post
Just got information (through alternate sources) that the Limited 4x4 9AT which is being offered a discount of 3 lakhs is a showroom display vehicle and it has been driven between their dealer showrooms and stalls. But this information has still not been shared with me by the sales guy. Should I still consider this?
That would explain why a car from Dec 2022 is still unsold, and the salesperson should definitely have told you that. The fact that they haven't told you should be a red flag to avoid.
Fusion2006 is offline
Old 9th March 2024, 17:01   #4547
Thanked: 149 Times
If anyone needs the standard Halogen DRL bulb in case anyone's bulb has conked off, here is the link from Amazon. It is quite a cheap bulb yet Jeep service charges a bomb for it!
http://www.amazon.in/dp/B07X9QTLNY/r..._xc28Eb6RKSCNA
Thanks Behemoth.
One of the DRLs on my Jeep Compass burned out recently. The dealership said replacing it would cost around 7k (unclear if that's for one or both).
I found the item online through the link you sent and replaced it myself following some YouTube tutorials.
Last edited by suhaas307 : 11th March 2024 at 15:12. Reason: Spacing for improved readability
motorsan is offline   (3) Thanks
Old 10th March 2024, 05:17   #4548
Sandeep500's Avatar
Thanked: 412 Times
Hi Motorscan,
Is the DRL you replaced led one or halogen. One of DRLs on mine jeep has also conked off. Clicking on the above link shows it is currently unavailable but it looks like it is led.
There are other options showing but unsure if they are compatible.
Last edited by suhaas307 : 11th March 2024 at 15:11. Reason: Spacing for improved readability
Sandeep500 is offline
Old 10th March 2024, 08:20   #4549
Thanked: 149 Times
It is a halogen DRL. Mine is a 2017 model Jeep Compass.
motorsan is offline
Old 12th March 2024, 13:21   #4550
Dr_MNC_SK's Avatar
Thanked: 485 Times
7 months 7000 Kms in S4x4 Good Bad Ugly
Completing 7 months 7,000 kms in a JC Diesel Model-S AT 4x4. The Good, The Bad, The Ugly.
Brief Background: I am from the hills. My daily drive is of good roads bad roads and no roads in true sense. Upgraded from a 4x4 Thar.
Ergonomics:
Ergonomics for driver and passenger I found is perfect as adequate adjustment is possible and the 2 Memory seating helps especially to get back to position from cleaning and all. I am 180 cm and I can seat fairly comfortable behind my own driving position. Nothing very spacious but not to cringe about for its size. Also rear seat is not that small as mostly pointed in reviews unless one is XL in size. 3 average sized individuals or 2 +1 car seat easily can sit. The hump for the rear shaft is present but not very very obtrusive.
Driveability:
The USP of this car. Can anybody tell another car available in India south of 40 lakhs which feels as close to this.
AT in Hills:
I was sceptical at first but no more. It doesn’t hunt gears and stays perfect for 90+% of the time, for occasional hard braking or sudden deceleration it refuses to upshift when you nudge it to for some time. Hardly have to go to Manual Mode for gear selection. If very steep uphill, then if on Auto 4x4 mode then tries to start on 2nd (like always) which has to be manually overridden to 1st or have to go 4WD Low where it goes to 1st. If you don’t want AWD but want to start from 1st gear, then must manually override. The need doesn’t arise much except very steep climbs where you have to stop and go. On plain side highways it’s a no bummer, it catches the gear 99% of the time.
Fuel Efficiency and DEF Efficiency:
Hills Highway 9-10 kmpl. Hills Traffic 6.5-8 kmpl Plain Highways 14kmpl. No complaints as I was getting almost same with my Thar 4x4 also. DEF usage was higher for first few thousand kms then have averaged out, Now I guess it will consume around 5 litre for 3000 kms in the hills. Haven’t had any DEF issues even on cold winters or anything. Using Standard ADblue from ASS or sourced from Amazon.
Good Points:
Ample of steering wheel control buttons ergonomically placed front and back. No accidental presses. Presence of Dedicated Hardware Buttons (plus Touch) for HVAC.
360-degree camera is a boon in some tight spots in our hills though overtime with the experience of approximation usage has come down.
Music System and U connect is working flawlessly. An occasional software issue with Apple Car Play ® is there which can be sorted by restarting the phone.
TPMS is smart, detects wheel rotation itself, no need to readjust after wheel rotation. Takes around 10 kms of driving and it detects correct placement.
Turning Radius and Steering wheel weight is remarkable.
One touch Up Windows on all 4 doors.
LED Projector Lamps and LED Foglamps are doing a remarkable job. May need a long throw spot beams for highways but not able to figure out where to mount them. The frame is front in front of radiator is aluminium.
The specs GC at 178 mm is adequate because its the fully laden GC. It sits above 200 mm with only you in it. Haven't hit anything until now running frenzy on our roads.
Boot: This is good and bad both. The Auto Tailgate is good to have. No need to touch dirty vehicle on road trips to open & close the boot. The placement of the button is good for shorter people but for me I would have preferred it to be a bit outside not buried in. Day to Day grocery shopping isn’t that appealing when the boot door is clean cause it takes a few seconds and we are all in a hurry. Also, there is adequate storage underneath the boot floor where vehicle maintenance kits like Tyre Kit Cleaning Kit Inflators and the likewise can be stored. I have some utensils and 2 camping stools also stored underneath. Tie Points are added advantage.
The Bad Points:
The Start Stop System should have a permanent kill feature. It will work when it wants to and stop when it wants to. Although manual says it will be deactivated on slopes it doesn’t most of the time and if you are on Hold Feature then car goes back when engine restarts because it deactivates Hold and doesn’t activate Hill Hold in that brief 1 sec period.
Auto Headlamps/ Auto Wipers sensitivity is a hit or miss even with adjustment levels in the system. Less concerning as it can be overridden to manual.
The door sills are a bit high to my liking. People inadvertently step on it on ingress or egress making it dirty all the while.
Wish the fuel inlet could take in a regular diesel pump nozzle and not the narrow ones only. Have to hunt for these specifically while filling. They have provided a converter but the hassle and the dripping of diesel and the smell that lingers on in it is not worth it.
The air deflector underneath the front bumper is the lowest point on the car. It grates and squeaks on some rough patches. Although it hasn’t broken as of now there is a possibility. I guess it could be deleted.
Boot Space: If you know how to pack it will swallow an enormous amount of luggage. Airport Runs with Hard Box Luggage is another story. Road Trips with duffels and soft luggage is not a problem.
Mud Flaps: The OEM Mud Flaps (especially the front) kept of breaking as also mentioned by many users. Shifted over to a flexible time universal Mud Flap found dirt cheap in Amazon. Working great ever since.
The Ugly:
If I could say one thing Ugly, then it is the choice of 18 inches Wheels with a 225/55 tyre which becomes its Achilles heel. The low sidewall height combined with the tread pattern makes it vulnerable. Also the absence of AT availability in this size in India adds to the woes. The Trailhawk 17inchers should have been here too. I would trade my 18 inchers to anyone with 17.
Comparison / VFM:
Unless one owns or regularly drives the JC one cannot understand its driveability, handling and other safety features it has incorporated.
There has been a lot of comparison videos and lack of features etc in comparison to other cheaper vehicles available in India but basically its about the gizmos and all. There actually isn’t another comparable vehicle here except maybe the XUV 500 AWD AT or more likely the Tucson AWD AT or the Tiguan AT AWD or Subaru Forester (Not available in India) . No one compares the robust built quality, the safety features and the driving ergonomics and the handling. Established sedans seem difficult to handle after driving this vehicle.
It may be expensive in comparison to many similar sized vehicles available in India, but I feel it is worth the money if you are into serious long distance traveling and want a no nonsense well handling medium sized vehicle which will take you from A to B safely and with less fatigue and has an AWD for those unforeseen events en route. (Not for offroading)
Service Centre:
ASS here at Siliguri (Nearest) and Guwahati have been very cooperative and helpful.
Last edited by Aditya : 18th March 2024 at 08:40. Reason: Minor clean up edits; spacing
Dr_MNC_SK is offline   (37) Thanks
Old 15th March 2024, 18:24   #4551
SKannan's Avatar
Thanked: 73 Times
The Sales guy at Jeep again called extending the discount to 5 lakhs overall. The on-road cost quoted for Limited (O) 4x4 9 AT is now 32.3 lakhs
SKannan is offline   (3) Thanks
Old 15th March 2024, 20:34   #4552
Thanked: 1,932 Times
Here is something to think about
- This is demo car, so whatever the sales guy says, it is still a car which might have been driven and abused all these months since 2022. For all practical purpose, consider it a used car which has been handled by unknown drivers. Now the question is would you trust this car which has unknown history? There's a reason why they still couldn't find a buyer yet with all that discount.
- Even if you trust the car, it is a used car after all. So what would you pay for a second hand 2022 Car? Is the price quoted fair for a second hand car?
- You also need to dig deeper into service history. Has it been serviced regularly as per schedule? Any accidents?
- What about warranty? Will you get same warranty terms/condition and coverage for this car similar to new car? If not, what is going to be warranty coverage and are you comfortable with that?
- Last but not the least - - Would you be first owner?
Jeep is not known for reliability so I would say that you need to be fully convinced about this car and definitely can't consider this is as a new car. Discount has to account for all the points I mentioned.
Aviator_guy is online now   (1) Thanks
Old 15th March 2024, 20:50   #4553
arun_josie's Avatar
Thanked: 14,872 Times
What is the number on the ODO? If this is a demo car then 5L discount is very less.
arun_josie is offline
Old 15th March 2024, 21:55   #4554
Dr_MNC_SK's Avatar
Thanked: 485 Times
I have always wanted a hitch receiver so I can probably attach a luggage bed or a registered trailer or a bike carrier or something. The US Mopar has a direct fitment hitch receiver for around 21K INR. Its a bolt on and needs bumper cutting at the rear where they have provided a cover fascia to make it tidy. They have two version for trailhawk and non trailhawk US version. I got in touch with them for compatibility issue with Indian Specs but as a US based Mopar dealership were not able to confirm export VIN fitments. Does anyone has an idea if this is going to fit our Indian made Compass if its designed for the US Model.
Jeep Compass : Official Review-img_4185.jpeg
Old 16th March 2024, 11:41   #4555
Thanked: 23,829 Times
I don’t think it is legal for a private car to tow any kind of trailer or luggage bed. Expect issues with traffic cops.
Shreyans_Jain is offline   (4) Thanks
Old 16th March 2024, 11:58   #4556
Dr_MNC_SK's Avatar
Thanked: 485 Times
If you look at Sl no XI of Column 2, Non transport Vehicle, Private trailers can be registered as a Non Transport Vehicle. If registered then it shouldn't be a problem. Here in Sikkim Tractors and Trailers are registrable.
Jeep Compass : Official Review-img_4188.jpeg
Dr_MNC_SK is offline   (2) Thanks
Old 17th March 2024, 12:30   #4557
josetom89's Avatar
Thanked: 139 Times
I have send my 2021 Compass Diesel for 45000 service. I was informed that the service costs have increased for BS6 vehicles. Earlier it was around 18k and now it is around 23k. They said the oil type to be used for BS6 has changed. Don't know other details. The service costs for BS4 remains the same as per the service executive. The service centre is Hyson Jeep Kottayam. Heard they are to be replaced by EVM from next month.
Any info regarding this change in service costs elsewhere?
josetom89 is online now
Old 18th March 2024, 03:10   #4558
Thanked: 80 Times
I recently got my 2022 jeep compass diesel serviced for 45k kms in Chennai. It cost me 17.5K without the wheel balancing and alignment. Will try and share the bill later
AW1972 is offline   (2) Thanks
Old 18th March 2024, 13:12   #4559
Have a 2022 Jeep Compass Limited AT(BS6) . VTK Jeep OMR(Chennai) charged 23 K for second year service.
LazyTraveller is offline   (2) Thanks
Old 18th March 2024, 14:00   #4560
Thanked: 80 Times
If this helps, I placed an order for this from Boodmo today; it is out of stock on both Amazon and Flipkart.
pathik@2020 is offline   (1) Thanks
