Old 1st May 2020, 13:52   #316
Thanked: 184 Times
Re: My Maruti S-Cross 1.6L Alpha : Stage 3 Wolf ( ~200 HP / 420 NM )
Originally Posted by Dr.Naren View Post
We faced only one issue and that is the major one as the steering won't be functional.
XL6 steering has larger hole and doesn't fit tight on S-Cross column......
Hope it fits
Is it possible to retrofit cruise control in swift zxi+ considering the updated dzire now coming with cruise control? Mine is swift zxi+.
indrasis_gun is offline
Old 1st May 2020, 17:13   #317
Thanked: 57 Times
Thanks Reinhard. Voicing my thoughts exactly. Except for the cruise control i wouldn't miss anything in the zxi. But then one can't have everything.
HONESTabdul is offline
Old 1st May 2020, 22:31   #318
Dr.Naren's Avatar
Thanked: 17,273 Times
1. ECU should be same.
2. Instrument Cluster change might be required.
I know someone who retrofits cruise control in Maruti cars. I shall update you after the lockdown
Dr.Naren is online now   (2) Thanks
Old 1st May 2020, 23:36   #319
Thanked: 184 Times
Thanks Sir for your update. The Cruise Control icons can be seen in the instrument cluster in bright sunlight.
indrasis_gun is offline   (1) Thanks
Old 31st May 2020, 12:36   #320
Leoshashi's Avatar
Thanked: 42,877 Times
Re: Maruti Dzire : Official Review
No underbody protection. You can see the ground below clearly:
Maruti has fixed this and now the view from inside engine bay looks like this:
Maruti Dzire : Official Review-capture.jpg
Two additional covers have been added. Old Dzire:
New Dzire:
Leoshashi is offline   (7) Thanks
Old 31st May 2020, 13:18   #321
DaptChatterjee's Avatar
Thanked: 361 Times
Great news! As they have announced it for both old and new Dzire, I assume this will be available as spare part and can be fitted into existing cars (mine is 2018 make). Any idea about the cost and part number?
DaptChatterjee is offline
Old 31st May 2020, 13:32   #322
Leoshashi's Avatar
They haven't announced it for the Old Dzire. But I think it should fit easily. Should fit even the Swift. Part numbers of the main covers:
COVER, MAIN FLOOR UNDER, RH
Part Number: 72812M54T00
Price: Rs 480
COVER, MAIN FLOOR UNDER, LH
Part Number: 72822M54T00
Price: Rs. 480
COVER COMP, ENGINE UNDER
Part Number: 72410M54T00
Price: Link failed. Will update later
Leoshashi is offline   (5) Thanks
Old 4th June 2020, 09:34   #323
Thanked: 184 Times
Mod Note : Please do NOT post messages that add little or no informational value to the thread, or post the SAME MESSAGE on multiple threads. We need your co-operation to maintain the quality of this forum. We advise you to read the Forum Rules before proceeding any further.
indrasis_gun is offline   Received Infraction
Old 29th July 2020, 12:38   #324
Leoshashi's Avatar
Some detailed snaps of the changes done to new Dzire, wrt newly added caps and covers:
Sump cover:
Maruti Dzire : Official Review-img20200729wa0022.jpg
Cover under the front foot board:
Maruti Dzire : Official Review-img20200729wa0023.jpg
IMO both these parts can be retrofitted to old Swift and Dzires(3rd Gen) easily.
Old 31st July 2020, 11:47   #325
NFS2024's Avatar
Thanked: 460 Times
Sump cover:
Attachment 2035929
Attachment 2035930
Any idea if these are plastic or metal? This should give some much needed protection for the underbody. Looks like Maruti must have received lot of complaints on this.
NFS2024 is offline
Old 31st July 2020, 11:57   #326
Leoshashi's Avatar
These are made of plastic, a bit thicker than the variety you get for fender liner. The new DualJet has its sump placed a bit below compared to the K12M and is almost in between the two wheels(as per claims of a known SA). So MSIL has given this protective sheet. The cover below the front footboard is for NVH purpose I believe.
MSIL should provide engine guards as accessories for all their models, like Ford do. Ford's engine guard is of awesome quality.
Leoshashi is offline   (1) Thanks
Old 31st July 2020, 12:23   #327
Reinhard's Avatar
Thanked: 18,115 Times
+1. In fact all mainstream car makers should. I'm sure there would be sufficient buyers. I suspect in addition to the cost of the part & screws - its the added few minutes in servicing + updates of SOP documentation that also keeps this part out from most cars. Where the goal is to quickly complete the routine service + oil changes and get the invoice printed - the extra 5 minutes of removing the plate for oil drain & re-installation surely amounts to a significant time added in turn around times at service bays in the big picture - numbers of cars serviced per week surely would show a difference. (Of course good engineering & a plate that allows for oil drain without own removal would be the best solution.)
Reinhard is offline   (1) Thanks
Old 31st July 2020, 13:07   #328
Leoshashi's Avatar
Indeed. Similar solutions exist. For example, take a look at this engine guard available on Aliexpress, it has quick removable covers for draining engine and gear oil:
Maruti Dzire : Official Review-images-64.jpeg
Leoshashi is offline   (2) Thanks
Old 28th August 2020, 17:14   #329
Thanked: 184 Times
Sir, What is the cost of this part?
Old 5th September 2020, 07:14   #330
Thanked: 350 Times
Hi All,
My dad is getting back pain when sitting in the Co driver seat in our Dzire that was bought last year. When I sat and checked, I felt like the seat is too low. My Dad is around 70 and doesn’t have the same problem in our old Figo.
Any suggestions, should I add extra cushion base or some Lumbar support accessory.
Ananthang is offline
