Old 14th April 2023, 16:03   #571
Thanked: 96 Times
Re: Hyundai Tucson : Official Review
Originally Posted by qaqa View Post
c. I am experiencing engine vibrations on the steering wheel at low speeds. The engine noise is also quite audible inside the cabin at low speeds. Is this normal for the Diesel Tucson? The vibration and noise is absent in my father's Diesel Seltos which I have driven extensively, hence felt there may be something wrong with my car. The car has only run 11K so far is about 1.5 years old at this point.
Assuming that you got the basic servicing done with all the fluids changed, try extra green from IOCL. It brought down vibrations significantly for me. If it works, you don’t have to keep using the same unless it is a personal choice. I fill up with 1 extragreen after 4-5 normal tank fulls. PS: mine is an XUV 700 but this might work for you as well.
ramradcliff is offline   (1) Thanks
Old 16th April 2023, 09:52   #572
Hi, I recently picked up a pre-owned Diesel Tucson (2021 facelift edition). I needed some help on some aspects -
I do not feel any noticeable vibration on my car from the engine, of course its not as smooth as BMW . Even the engine noise can be noticed only when the windows are rolled down. I have a 2018 Diesel GLS which has done about 30k kilo meters. You should get that checked, if all engine mounts are fine.
aa-Crecy is offline   (1) Thanks
Old 31st May 2023, 09:42   #573
Thanked: 1,537 Times
a. When running Android Auto, pressing the voice control button on the steering wheel does not summon Google Assistant. It instead activates Hyundai's built in voice command system. Is there a way to map the voice control button to summon Google assistant / Siri when running Carplay / Android Auto?
b. The rear camera quality is really poor. Not only is the resolution low, it is prone to washing out in bright light and becomes very grainy in low light. Has anyone tried to upgrade the rear camera? Any inputs in this regard would be helpful.
I have a 2017 Hyundai Tucson. I downloaded and installed the "Navigation Updater" software available online (https://update.hyundai.com/IN/E1/navigationUpdate), with a view to download and update the maps on the SD card of my Tucson. But when I ran that s/w, it seems to support map update only for the 2022 models.
I suspect its something to do with the compatibility with the GPS unit. But nevertheless, support for older models is a MUST.
How do I update the maps on my 2017 model, any idea?
vharihar is offline
Old 14th June 2023, 09:55   #574
Thanked: 103 Times
I've picked up a used 2017 model with AWD.
The HeadUnit software update maybe only available thru the service centers. Nothing is available or easily seen on Hyundai's web pages.
Once RC is transferred, planning to take it to them for a look thru and any updates that are pending.
trailsndirt is offline   (1) Thanks
Old 14th July 2023, 00:34   #575
M_Poweredd_'s Avatar
Thanked: 144 Times
Hello, I want an advice from you guys regarding my car purchase. We currently have a XUV 500 2014 with 1L kms on the odo. We are looking for a car that can be useful for city as wel as highway drives with family. 5 seater is enough for us. A used Tucson would be a good fit in my opinion or a used Jeep Compass. Budget is under 20L. Should I go for it? My hyundai salesperson said that there is a problem sourcing parts for the car. Is it true? I am going to use it for atleast 5 years.
M_Poweredd_ is offline
Old 14th July 2023, 06:59   #576
bijims's Avatar
Thanked: 2,382 Times
The Tucson is a CKD import, so there may be issues with parts availability, as it's not a high-selling vehicle. The Compass on the other hand is available in the used car market for very good prices, it tends to lose its value quicker and has lower resale value.
bijims is online now   (1) Thanks
Old 16th July 2023, 10:07   #577
Thanked: 103 Times
Reliability side, Id prefer the Hyundai over the Jeep.
Parts are not stocked by many dealers as it was a CKD and low-volume vehicle. Having said that, if your local garage has the expertise with diagnostic tools, can book the service ahead of time to allow them to get the parts needed.
My garage has serviced my Yeti 4x4 for almost 10 years, and now the Tucson 4WD automatic and had good insights on the issues with Hyundai and Jeep.
Jeeps tend to have the odd issues cropping up every now and then and over time, this garage has seen the same model year Compass come in at least 2 to 3 times in one year. Tucsons, perhaps once for the annual service and twice when something really broke but rarely for the same vehicle.
Still, I'd keep a couple of lakhs worth over the selling price for other things to fix on either vehicle to be safe - tires (including the spare), tire replacement kits (popular item to be nicked when sold in the second-hand market), cosmetics and one general service even if the log books shows it was done recently.
trailsndirt is offline   (2) Thanks
Old 11th August 2023, 13:34   #578
Thanked: 201 Times
I am currently planning to acquire a pre-owned Tucson. It is a 2018 GL 2WD Diesel 2nd owner 153000 km piece. The owner is asking for 12 L.
The owner says that the car was under warranty till March 23 and all repairs could be done when required, without a need for any penny-pinching.
I am in a dilemma. Is 153000 km too much? Or does it not matter much?
Also, which could be this warranty that was in force for five years and some 140000 km?
Can I request someone to throw some light on the situation, pl?
P.S I am yet to see the car in person.
skdking is offline
Old 11th August 2023, 15:06   #579
Thanked: 103 Times
153K is quite a bit but if the maintenance has been done as per the schedules, you may be able to knock the price down a little bit.
Regarding the warranty, it's now done. Anything from here on will be on the owner's pocket. Before you head to see the vehicle, you can drop by into any service center and ask about the coverage and costs if it helps.
I'd be more interested in the test drive - clutch, gear shifts, steering feel from lock to lock and all the electronics and buttons. This is a big vehicle and any bodywork can cost quite a penny. Do look at the tires, discs, and suspension.
Old 22nd September 2023, 10:28   #580
Thanked: 94 Times
hi trailsndirt, I was considering a used Hyundai Tucson from 2017 - 2019 and was inclined towards the Diesel GLS because of it's torque. One of the owners said that sourcing of spare parts was an issue.
1. Are there any garages you'd personally recommend in Bangalore for servicing the Tucson ?
2. What's the worst that one should be prepared for, in case of spare part unavailability ? And how much time would it usually take even to procure these parts (I'm assuming, from Korea)
capnemo is offline
Old 22nd September 2023, 10:41   #581
Thanked: 103 Times
Warranty will no longer apply for that number on the ODO.
Test driving will be the key.
Get a feel for the clutch, and gear shifts including reverse and lock-to-lock steering (while driving like in a figure of 8s).
Press every single button to make sure they are doing what they are supposed to. Tucson parts are not the easiest to get if something were to be sorted. If you have a buddy mech, have a look under the hood for any bits that might need to be looked more closely or need fixing.
Mine for context, after driving for 20 minutes or so started to show a belt squeak noise which needed a replacement along with the tensioner. The test drive did not reveal it.
Do look VERY closely at all the tires including the spare. Take the spare out and see if all the things needed are in place - jack, tools, etc. If any of the tires are installed the wrong way, insist on having the vehicle inspected in a garage. On mine, one tire was installed in reverse that hid a bulge/minor tear and was only noticed when I took it for alignment and balancing.
Old 7th December 2023, 00:31   #582
Thanked: 106 Times
Dear Bhpians and Tucson owners,
I'm trying to help an uncle of mine service his 2007/2008 Hyundai Tucson in Bangalore at an FnG. I'll try to split this post into a short context, requirements and questions for ease
Context:
This is a Diesel 4wd MT Tucson, used primarily for urban commutes and drives between Bangalore-Chennai/Goa. Its very loved by the owner and his family and is in great shape given the age (so he's not going to part ways with it soon - and he's not able to find a decent robust SUV [4wd] replacement under 40L that he and the family like enough). The car was regularly serviced till Covid times but post that has seen lesser running and some neglect (due to personal commitments). The owner loves to drive but has limited knowledge of the car's mechanicals. He's also mostly been the sole driver of the car.
Requirements:
- General service and check-up of the vehicle
- Replacement of the Hyundai and Tucson lettering
- Have the vehicle in shape for a Bangalore-Goa trip
I tried this place in Yelahanka (Fast wheels Bosch) over phone and he was confident he can service the car. He quoted 15K for the oil service.
Questions:
- I'm new to FnGs in Bangalore. Can anyone recommend a competent mechanic?
- How much does the oil service of an old Tucson cost? Some garages use very expensive oil (had an experience like this) for no reason.
- Are there parts that could fail on the long trip (but don't show any trouble now)? I can think of the turbo, coolant system, water pump, radiator fan and maybe battery. Any advice on what to be prepared for?
Thanks in advance for your valuable suggestions and responses!
Auto_guy_101 is offline
Old 7th December 2023, 09:18   #583
Red Liner's Avatar
Thanked: 18,242 Times
May I recommend Krithi Car Care. It is run by a distinguished BHPian right here. Advantage if something goes wrong is you can come back here and complain about him to the rest of us 😆
KRITHI CAR CARE
091484 74707
https://g.co/kgs/KjD6NK
But i found him honest, trustworthy and reliable in his advice. That is the reason I suggest him. Plus they have a new gigantic workshop now.
Red Liner is offline   (1) Thanks
Old 10th December 2023, 23:50   #584
Thanked: 106 Times
Thanks! This looks like a really nice workshop.
However, I spoke to them and they said as parts are hard to find for the Tucson, they're not going to be able to work on it. Strange they didn't agree to a check-up and oil service either.
Auto_guy_101 is offline   (1) Thanks
Old 11th December 2023, 10:20   #585
Thanked: 103 Times
Many mechanical or engine parts are not easy to get as they will need to be imported or sourced from some garage that may have one or two hanging about.
While the labor cost might not be as high as some German brands, the time to get parts is still not ideal.
I've had my vehicles - 4x4 Yeti and now a 2017 Tucson 4WD serviced at a garage on Harlur Road - Motovise. From what I've seen, it is one of the few places where you get access to a full diagnostic kit over the traditional "replace parts till it's fixed" approach.
https://maps.app.goo.gl/LhY4sqvRsMMhkgATA
It's best to call, explain the situation in some detail - share a video or pics, and also go there for the manager to see what's needed and then, take a call whether you want to work with them or if their timelines are ok with yours.
Btw, they also do a lot of bodywork and painting. I had the old Yeti's full body re-pray done by them and it came out as good as it would have from the Skoda factory.
