Old 2nd September 2018, 21:01   #1216
bharatbs's Avatar
Thanked: 157 Times
Re: Ford Figo : Official Review
My friends 9 month old Ford Figo with 13,000 kms on the oddomter has started to make a loud grinding noise that seems to be coming from the speedometer/dashboard area. It starts around the 60 kmph mark. Any idea what this could be, cannot find anything on this thread?
He has already tried switching of AC and fan to eliminate those usual suspects.
bharatbs is offline
Old 2nd September 2018, 22:01   #1217
Thanked: 113 Times
I request you to kindly note the RPM at which the noise is heard. Also check in other gears at the same rpm if it persists. My 8 month old (oct 2017 manufactured) Aspire had a similar problem and it was rectified in the service centre. I used to hear a vibrating/abnormal sound during acceleration and engine breaking between rpm 1000-1500.
_nitink_ is offline   (1) Thanks
Old 3rd September 2018, 09:19   #1218
Thanked: 666 Times
Could be the alignment of the bonnet, the two rubber corks at the underside of the bonnet should be aligned properly.
Then there could be number plate which could be the culprit.
If the vibrations are felt through the steering, it could be a broken engine mount.
I could clarify more if I could get more specifics, like does it happen on acceleration or braking, at which gear, rpm?
bhphog is offline   (1) Thanks
Old 3rd September 2018, 09:29   #1219
samaspire's Avatar
Thanked: 4,868 Times
Can you record the sounds of it and post it here?
samaspire is offline   (1) Thanks
Old 3rd September 2018, 09:53   #1220
bharatbs's Avatar
Thanked: 157 Times
I am sharing the video clip, sorry for the vertical video. In this recording the grinding noise starts at 100kph mark. However now this noise is staring at 60 kph.
bharatbs is offline   (1) Thanks
Old 3rd September 2018, 12:03   #1221
bharatbs's Avatar
Thanked: 157 Times
Just to update it happens in all gears above 70 km/hr, no relation to RPM, starts only when the speedo meter crossed 70km/hr.
Bonnet alignment is fine,
Vibration not felt through the steering. steering wheel is absolutely fine
Number plate is fine
bharatbs is offline
Old 3rd September 2018, 13:08   #1222
Thanked: 612 Times
Does the vibration stop when you touch any part of the instrument cluster?
Does it happen even when the engine is revved-up at standstill?
You can isolate the vibration this way.
Since there is no vibration felt on the steering wheel would suggest that its not drive-train related however it cannot be ruled out.
Possibly a latch or something has come lose.
In our Figo we had a similar sound but it felt like it was coming from the front speaker. However it went away on its own.
arijitkanrar is offline
Old 3rd September 2018, 13:59   #1223
arunphilip's Avatar
Thanked: 6,347 Times
The fact that it is independent of RPM and dependent of speed indicates that it is not related to the engine, but related to only the drivetrain (gearbox and beyond). The fact that it comes from the speedometer area makes me wonder if its a problem with the instrument cluster.
Given that the car is just 9 months old - and therefore under manufacturer warranty - has your friend taken the car to Ford for diagnosis?
If he hasn't, is it because he wants to first get a handle on the problem before approaching Ford? Are speed warnings disabled?
The sound is a bit like a buzzing sound, which could either be mechanical or electrical.
If he and you are willing to get a little hands on, you can try pulling the fuse that powers the instrument cluster. The fuse box is behind the glove box on the passenger side (the glove box can be flapped down by flexing two stops present at the top left/top right of the glove box when it is opened).
This schematic shows that the 7.5A fuse #8 is what powers the instrument cluster. Circled in yellow.
Ford Figo : Official Review-inked20180903_li.jpg
And, in reality this is what it would look like:
Ford Figo : Official Review-inkedfuse-box-passenger-compartment_li.jpg
So, start the car, and with it idling, pull out this fuse, and drive again, seeing if the sound persists. That'll tell you if its a problem of electric origin from the instrument cluster. Then you can put the fuse back and see if the problem changes.
Since you can't judge speeds as easily now, you'll have to go by ear, or use a GPS app on your phone to give your speed.
arunphilip is online now   (1) Thanks
Old 3rd September 2018, 14:19   #1224
Blow Horn Ok's Avatar
Thanked: 986 Times
To me it sounds plasticky and electronic. I guess it's not from engine or drivetrain. Go by arunphillip's advice I would say. May be the speedometer here is at fault which starts making noise after reaching certain speeds.
Blow Horn Ok is offline
Old 6th September 2018, 17:16   #1225
Thanked: 612 Times
Just checking in to see if any update was found for the console noise?
Anything that can help existing owners?
Old 6th September 2018, 23:08   #1226
bharatbs's Avatar
Thanked: 157 Times
The car is currently outside of Bengaluru and there is no access to a Ford A.S.S. there. The owner plans to get it to Bangalore in a couple of weeks and have it checked, does not want to take a chance tinkering with other mechanics as it is under warranty.
bharatbs is offline
Old 7th September 2018, 10:12   #1227
Thilak29's Avatar
Thanked: 3,545 Times
I have been looking for options to replace my rear wiper, the ones Ford offers appears ridiculously expensive - please advise options available.
Thilak29 is offline
Old 10th September 2018, 12:56   #1228
Thanked: 612 Times
Recently was at the service center to get the front suspension inspected of our Figo 1.5 TDCi.
During that came to know of a PCM Software update available which was installed.
After that there isn't any noticeable change the engine feel other than the fact that range seems to be increased. When we reached the ASS, the DTE showed a range of 598KMs.
After the update the DTE showed 656KMs.
Anyone got the update installed? Feel any difference?
Old 10th September 2018, 13:18   #1229
tharian's Avatar
Thanked: 8,204 Times
Did you request for it or was it done proactively by the A.S.S?
They did explain why there are installing it now?
tharian is offline
Old 10th September 2018, 14:20   #1230
Thanked: 612 Times
We were facing problems with the bluetooth connection to the HU.
So asked them if there was any software update available. They found the PCM update and installed it. When I asked about what the update is for the technician said "Saar mileage, power, pickup, engine life better saar..."
arijitkanrar is offline   (4) Thanks
