Old 13th December 2023, 10:36   #9586
Thanked: 3,313 Times
Re: Maruti S-Cross : Official Review
Originally Posted by sudeepg View Post
Water pumps etc are belts where as the engine timing is a timing belt as well for the DDiS 1.6.
Originally Posted by kit_dennis View Post
1.6 S-cross with D16AA engine comes with timing belt. Attached snapshot of the S-cross manual.
Thanks for the confirmation. You learn something everyday. Would be interested to understand why the higher capacity engine uses belts though.
Drive on,
Shibu.
shibujp is online now
Old 14th December 2023, 18:43   #9587
Thanked: 85 Times
Is the glow plug for 1.3 and 1.6 engine same?
I got the pre heating warning today morning and most probably have to change the glow plugs.
kit_dennis is offline
Old 21st December 2023, 20:28   #9588
Thanked: 85 Times
To answer my own question, they are differrent and also about double in price.
Got the glow plugs replaced and the warning has gone.
Maruti S-Cross : Official Review-glowplug.jpg
Old 24th December 2023, 11:10   #9589
Sree73's Avatar
Thanked: 1,002 Times
1,10,000KM. ~8.5 Years. Still shining and going strong. 1.3 engine is smooth as butter. And the turbo kick once crosses the 1900-2000 RPM is still young and energetic.
Maruti S-Cross : Official Review-img_20231224_110432.jpg
Maruti S-Cross : Official Review-img_20231224_110356.jpg
Maruti S-Cross : Official Review-img_20231224_104802.jpg
Sree73 is offline   (2) Thanks
Old 3rd January 2024, 16:05   #9590
Thanked: 185 Times
In the hands of a good installer, the installation can be super clean. I had no idea about any electrical work on car, but with much reading, tools and confidence, you can get this done on the alpha (a buddy suggested). Alpha headlights are extremely weak for daily use in city or highway. I have done the upgrade myself (with my buddy) from stock to Morimotos Stage 4 and it was totally worth it. It's been running for years now without any problems.
Hello sir, where did you source the Morimotos from, may I ask? I have been searching high, and searching low; but no joy.
In the interim, I have switched to IPH bi-xenons in the fogs and 2-inch led projectors nestled behind the front grill.
Help!
thedragonreborn is offline
Old 10th January 2024, 11:11   #9591
KaandBaaz's Avatar
Thanked: 119 Times
Help!
Could you please share a photo of your setup and provide some feedback?
I'm considering installing IPH bi-xenons (tri-colour) for the fog lights.
I've noticed that the headlights on the Scross Zeta are quite inadequate for my night drives to my hometown in Kokan.
KaandBaaz is offline
Old 22nd January 2024, 23:05   #9592
Eddy's Avatar
Thanked: 13,789 Times
So this happened today while opening the boot. Placed an order for the replacement at the nearest ASS. 1750 for the part, 1500 for painting and 200 for fitting. Wait time of one week.
Maruti S-Cross : Official Review-img_0852.jpeg
Eddy is online now   (1) Thanks
Old 7th February 2024, 21:29   #9593
govigov's Avatar
Thanked: 1,101 Times
150K Kms service update:
Odo @ 148500
Changed engine oil / oil filter / front and rear brake pads .
Turbo intake side pipping had some oil built up on the pipe, this was informed as a complained. This was the reason for the hurried service. I had previously mentioned I wanted to move to a 5000 km oil change interval and thus had changed oil from an FNG at 146k kms and they had overfilled the sump. I was aware of the overfill, but was unable to drain as I had familial commitments, but kept monitoring. This was how I had noticed the oil at intake side pipe of the turbo.
Maruti S-Cross : Official Review-20240202_134816.jpg
Intercooled was removed and cleaned with diesel, the mounting points of the intercooler and pipes thoroughly cleaned and dried. The condensor was also cleaned using compressed air when the intercooler was removed.
During the oil change, added ceratec from liquimoly. 250ml of ceratec to 2900ml of engine oil. Too early for feedback, will report after accruing some kilometers.
Further plans:
ceratec in gear oil at 160K kms gear oil change. If anyone knows why I should not add ceratec to the gear oil, let me know.
govigov is offline   (4) Thanks
Old 7th February 2024, 22:18   #9594
Eddy's Avatar
Originally Posted by govigov View Post
rear brake pads .
Was this the first time that rear pads were changed in your car? What was the cost?
Old 7th February 2024, 22:54   #9595
Thanked: 44 Times
8 years, 56k kms of fun! 1.6 Delta. 320Nm, rear discs, 6 speed manual. And Diesel efficiency!
Maruti S-Cross : Official Review-scross1.png
ballkey is offline   (2) Thanks
Old 7th February 2024, 23:27   #9596
govigov's Avatar
This is the third set for the car. First from factory, second was around 2019/2020 and used baleno rs pads. The third set, from today was again baleno rs pads. The rear rotors are still the ones from the factory.
The front has had the rotors replaced once.
govigov is offline
Old 16th February 2024, 18:23   #9597
ike
ike's Avatar
Thanked: 1,796 Times
Further plans:
Doesn't Liquimoli have a dedicated additive for the gearbox? I'd rather use that rather than using in the gearbox something meant to be put in engines.
ike is offline   (1) Thanks
Old 17th February 2024, 00:21   #9598
govigov's Avatar
Correct. They have MOS2. I would most likely use that over ceratec, though that can also be used. MOS2 is just better for the gearbox over ceratec.
govigov is offline   (1) Thanks
Old 8th March 2024, 13:20   #9599
Thanked: 85 Times
Odo @ 148500
My car(1.6) is currently at 148k and is due for 150k service in the next month or so. I am looking for a reliable service centre in Cochin area or Bangalore.
Where do you service your's or can you suggest some good place?
Old 8th March 2024, 22:18   #9600
govigov's Avatar
Nexa kalamassery the one by indus motors.
https://maps.app.goo.gl/Kd3N19gBguY1pyfM9
