Old 1st October 2016, 17:51   #1831
Thanked: 13 Times
Re: Maruti Ciaz : Official Review
The cabin light console in my two year old ZDI was malfunctioning and was changed under warranty recently. Have checked with someone else who owns a year old ZDI and it was confirmed that the cabin light console in his vehicle too had gone kaput! Maruti has not issued any official recall but considering this to be a manufacturing defect it should do so immediately! Have asked the Service Advisor to check for any other notices from Maruti regarding defective parts in the Ciaz ! This is not expected from one of the most trusted and reputed manufacturers in India! Id say lets wait and watch how Maruti reacts!
Benipal0006 is offline
Old 2nd October 2016, 17:42   #1832
Thanked: 18 Times
Originally Posted by CA Dhruv View Post
Has anyone got the projector bulbs changed? I am planning to swap the manufacturer fitted bulbs as night drives are usually on unlit highways. Which one should I opt for?
I am facing a similar problems with the headlights. They are insufficient on a dark highway. Though i went through some of the replies given, i am still not clear. Please help me with this.
Since, the projector unit is for low beam and normal one for high beam, if one needs a better vision at night, do we change both? or changing the High beam would suffice? Some info i got in my search are these snaps.
Kindly help with your advices
Maruti Ciaz : Official Review-img_20161002_170146.jpg
Maruti Ciaz : Official Review-img_20161002_171357.jpg
sandeep959 is offline
Old 2nd October 2016, 23:21   #1833
mithunvvijayan's Avatar
Thanked: 127 Times
Attachment 1561730
Attachment 1561731
I have been dabbling with various headlight options and had settled with hid conversion kits in my earlier vehicles. But with Ciaz, the high beam comes in H1 and low beam in H7 configuration.
Phillips xtremevision and osram night breakers are but just a slight improvement over regular halogen lamps.
Hid conversion kits are costlier when compared to LEDs. They are also a bit clumsy, while installing. Will need a cut or two in the wiring. If you can get hold of Philips led headlights with H1 and H7 configuration, then it will make a significant difference.
And fogs lamps in our cars do not give clear visibility. Due to smaller reflectors and lower mounting height, it won't be worthwhile to change the stock lights with higher intensity ones.
mithunvvijayan is offline   (1) Thanks
Old 3rd October 2016, 00:29   #1834
rambo1o1's Avatar
Thanked: 328 Times
Attachment 1561730
Attachment 1561731
Originally Posted by mithunvvijayan View Post
I have been dabbling with various headlight options and had settled with hid conversion kits in my earlier vehicles. But with Ciaz, the high beam comes in H1 and low beam in H7 ..............................................
I have upgraded both the low and high beams to Philips rally 80w, using a full wiring harness/relay kit. Been using this setup for the past 1.8 years without any issues.
There is tremendous improvement in the high beam and adequate improvement in the low beam.They key after upgrading the bulbs is to correctly level the headlight throw.The ciaz has a screw in each headlight to adjust the throw over and above the factory default.
I am not sure how much difference the nightbreakers/xtream vision will make w.r.t 80w halogens but if you find LED bulbs expensive or untested, upgrading to higher wattage halogens will solve your problems.
With this setup you will mostly use the low beams and high beams for the occasional open straight highway or pesky motorist who wont dip their high beams.
Reagrds
rambo1o1 is offline   (2) Thanks
Old 3rd October 2016, 16:26   #1835
ptaneja's Avatar
Thanked: 1,130 Times
Guys, a quick question!
I have ordered shell synthetic oil 5w40 during amazon shopping fest at 3300. The question now is, I called Maruti service centre, and they have flatly denied changing an oil we bring from outside. As per them, they are not authorised.
I will get it changed outside, but is this statement true?
Hope no warranty issues later?
ptaneja is offline
Old 3rd October 2016, 16:41   #1836
Thanked: 21,423 Times
Yes. They do not agree if customer brings his own oil.
When I gave my oil MGDO Mobil Super 5W40 during the 90K service, they were hesitant. Even though it is Maruti recommended.
I told them warranty is out anyway so just do it. I was asked to mention in writing in the job card - "Customer has provided his own engine oil for service".
Indirectly washing their hands off if something goes wrong and customer goes to claim warranty later.
a4anurag is offline
Old 3rd October 2016, 17:16   #1837
Thanked: 51 Times
Try pitshop if you are located in Bangalore. You can book the same from amazon and pitshop folks will come to your place. If not in Bangalore buy Oil filter from Amazon and visit any service center. They will charge 250 to 300 bucks
aka_iitd is offline
Old 3rd October 2016, 17:25   #1838
ptaneja's Avatar
Yes. They do not agree if customers brings his own oil.
Damn. The only reason I wanted to have it done at MASS was to get it on their records that oil have been changed at xxxx kms mark. But I guess thousands of us are already following the practice of service outside of MASS once warranty wears out.
My known garage would charge me around 100 for the same.
The question was not about charges.
The question is, what if something goes wrong with the engine - would they entertain the warranty, or would eventually try to wash off the hands saying that oil was not changed at MASS, and moreover the manual says 5W30, and you have put in 5W40 !!
Man, it seems I have made a mistake in ordering
Should I cancel the order ?
Suggestions please ??!!
ptaneja is offline
Old 3rd October 2016, 17:50   #1839
Thanked: 727 Times
Practically and Logically, it no more makes sense in buying it online. Cancel the order, in my opinion.
riteshritesh is offline
Old 3rd October 2016, 17:56   #1840
sathish81's Avatar
Thanked: 163 Times
I suggest you do not put in 5W40. The oil would be more viscous(thicker) when heated and this might cause problems. Usually a lot of testing , research goes in before manufacturers suggest a oil grade and I wouldn't consider going against the recommended grade if I were you.
sathish81 is offline
Old 3rd October 2016, 18:28   #1841
ptaneja's Avatar
Cancelled the order.
Would go with what junk they have in large barrels and no sign of marking or labels. I would not be surprised if they put in semi-synth instead of fully synthetic.
ptaneja is offline
Old 3rd October 2016, 21:55   #1842
Thanked: 2,317 Times
Got the stabiliser bar bush changed today. Apparently it is a 36 bucks part which was annoying in such a new car.
The work took 2 hours and the front axle had to come down.
No more noise for now. Though the glovebox rattles and the seat creaks in a brand new car. Well, it's a Maruti and I guess we should live with it.
DRIV3R is online now   (1) Thanks
Old 3rd October 2016, 23:33   #1843
Thanked: 127 Times
Reagrds
The reason why I omitted high wattage halogen lamps is due to some bad experiences with them. I had to learn the hard way that the high heat produced by these bulbs tend to damage the reflectors as well as the plastic covering of the headlights, giving them a dirty yellow tint over time. An experienced auto electrician identified the problem and cautioned me not to use them, unless the headlight cover is made of glass, as in commercial vehicles.
Hope that ciaz headlights are robust enough to withstand the higher heat produced by these lamps.
Old 4th October 2016, 06:51   #1844
ptaneja's Avatar
My friend, what were the symptoms observed before the change happened ?
ptaneja is offline
Old 4th October 2016, 09:12   #1845
Noise from the suspension at slow speeds on undulations, especially when you are driving alone. More pronounced when you take speed humps when on a turn, or when front wheels take the hump one after the other.
