Hyundai Elite i20 : Official Review Hello BHPians
Half year review of my Elite i20 Asta, Petrol.
I purchased in August 2018 from Advaith Hyundai, Outer Ring Road, Bangalore.
Costed me around Rs. 8,60,000/- including road tax.
The build quality is top notch and the first thing you notice inside is the dashboard. It feels premium. Well worth the money.
My current ODO reads around 4,500 km. I use it for office commute and weekends, so not much for long-distance or highway running.
Petrol engine is extremely refined and smooth.
I'll come to the benefits of the Asta variant:
(i) Android Auto - This is wonderful, once you get used to the map on the screen, there is simply no going back.
The other benefit of plugging in the phone for Android Auto / Apple Car is the benefit of charging. The i20 USB port has very strong charging current. Your phone will get topped up quickly.
(ii) Rear parking camera and sensors - This variant gets camera display on AVN and is extremely convenient.
(iii) Other small conveniences like dead pedal, sliding armrest, tilt+ telescopic steering.
Mileage
Combined mileage is around 10.8 to 11.2 kmpl for petrol which is not very appreciable but considering Bangalore traffic and stops, it is still acceptable.
There is instantaneous display of fuel consumption and you will notice that driving with a heavy foot will take a strong hit on the mileage. I have toned down my driving style after seeing that meter.
I drove with a heavy foot during one cycle - full to empty. I got a mileage of 9.3 kmpl.
All figures are with AC on almost all the time.
Comfort
Seating is extremely comfortable and the presence of addons like dead-pedal and arm rest makes it one notch more comfortable.
Extremely good insulation, NVH levels are upto mark.
Automatic Climate Control is good, however, I think the air-conditioner is a bit underpowered for a max sized sub 4 premium meter car.
The handrest is extendable and comfortable but in city driving, where you need gear changes every few seconds, it feels far away from your arm. A better reach could have been implemented.
There are 2 USB ports. One for connecting to the car and other for charging only. The current is sufficient enough to make separate car chargers redundant.
That said, the USB ports can be a little tough to reach because they are situated under a protruding dash.
Driving
Extremely refined and smooth engine, it's a pleasure to drive
Same case with the gear box - buttery smooth in the forwards gears (see my notes below on the reverse gear)
The steering wheel is very very smooth and light. It's almost like without any effort, you can make the turns.
Transmission is extremely accommodating, you have much room for slow speed in the higher gears (4,5) without stalling the engine.
ABS kicks in nicely and I feel it is upto the mark.
Note: If you don't put on the seat belt and reach a certain speed (which I believe is 20 kmph) there is a continuous loud intermittent beep for like 1-1.5 minutes. This is very irritating especially when you're trying to just move the car here and there. There should have been a setting to turn the beep off, or at least control the volume of the beep.
Sound System
Powerful and punchy sound system. Tweeters are an add-on
There is some problem with the software, probably. When you pause a song on bluetooth connection, there is a strange kind of echo - probably because of bluetooth lag
The tweeter on the LHS of the car has started to give off the sound of a dying speaker already even though I keep volumes extremely low.
Arkamys sound system feels more like one with preset equalizer settings, and in my opinion, is just holds marketing value.
Integrated 7 inch Audio Video Navigation
This is the most powerful functional feature added to this car. Hyundai provide an SD card loaded with maps and you can drive comfortably getting directions. The built-in GPS and Maps ensure that on long trips, if you don't have network on your mobile phone, you don't get lost.
The software is nowhere near to Google Maps, and also doesn't offer traffic and live updates, but that is not a surprise. Google is Google.
Android Auto:
I use my OnePlus 6 with Android Auto and use Google Maps for navigation. The touchscreen display has all features to search, modify, navigate, etc. -- Fully functional
The music and call menus are equally loaded.
Note: I used to have very frequent disconnections on the phone-car USB connection and required a plug and unplug of the wire.
After a latest firmware update on OP6, the phone restarts completely as soon as it is plugged in to the car. It is very frustrating and the software is usable only after the restart of the phone.
Exterior
--------------- No rear wiper in Asta variant -----------
Come on Hyundai, this is extreme level cost cutting. Even the Grand i10 has a rear wiper on the Asta.
The other thing that I feel under-equipped is the headlamp. In my opinion, it is not up to the mark.
I upgraded the stock lamps to Osram 35W HID kit for approx Rs. 10,000/- and needless to say, the difference is astronomical. It is done without cutting any wires, so don't be worried about the warranty.
Also, using HID does not affect the controls / dash in any way. Some reports have said that HID causes problem in some cars' controls. This is not the case here.
Other Thoughts
Hyundai has done some amount of cost cutting. Asta variant comes only with one remote equipped key. The other one is normal - push and twist.
Pushing the lock button causes the car to emit a LOUD horn for 0.5 seconds which is EXTREMELY convenient in locating the car in office and mall basements.
Unlocking on the other hand, causes two such horns.
Some Notes
I have very frequently noticed that putting the gear in reverse causes the knob to get stuck and the car doesn't go in reverse. You gotta engage the first gear and then reverse gear again, sometimes couple of times before it actually engages the reverse gear.
That being said, the normal forward gears are extremely smooth, so this maybe an isolated issue with my car.
Car feels a little under-powered with all five passengers.
What is awesome
Refinement and NVH levels
Dashboard quality
AVN system
Front and Rear seating comfort
What could have been better
Rear wiper
Headlamp
More powerful Air Conditioner
Better reach of the handrest
Better placement of the USB ports
Both keys will full remote control
My advice: Go for the Asta variant. Asta has better value for money than Sportz with some really awesome features.
Top end Asta (o) is very highly priced and, in my opinion, not value for money.
That's all for now folks.
Thanks |
