Old 21st November 2020, 17:55   #3016
Thanked: 108 Times
Re: Tata Zest : Official Review
Originally Posted by discoverwild View Post
It's one of the ignition coils that has probably burnt out. Nothing much to worry about. The car does fine even without one of them. Have the issue on the Vista.
Thanks buddy! So this issue doesn't show up on their diagnostics? How was it done in your Vista?
devilicious is offline
Old 21st November 2020, 20:46   #3017
discoverwild's Avatar
Thanked: 3,695 Times
My FNG knew it was a recurring issue. I did replace one of the coils a couple of years ago. When the second one went kaput, he asked me to ignore it. Never caused trouble in a year's time.
discoverwild is offline
Old 22nd November 2020, 01:34   #3018
Thanked: 233 Times
Originally Posted by digitaldeepak View Post
Happy to share today My Zest QJD clocked 151000. Its been 5 years and 1 month. Doing very good. Except fuel pump failure no major complaint with the car. Tata motors service is every time a hit or miss but in my case it is almost bulls eye.
Did you get the fuel pump changed or got it repaired? Can you share the cost? It will be good to know if it happens with any of us.
parth.jain is offline
Old 23rd November 2020, 21:38   #3019
Thanked: 9 Times
Replaced both the times. I don't think so that it can be repaired(at least as per Tata service personals).
digitaldeepak is offline
Old 26th November 2020, 15:57   #3020
Thanked: 699 Times
Duplicate post with Team Bhp (Automotive air conditioner servicing & maintenance)
Car : TATA Zest XMS MJD 90ps / 2015 / 47K
Symptoms : No A/C effect and small noise is heard if A/C is on.
Diagnosis by TATA A.S.S : Cooling coil need to be replaced. Estimate Around 17,000.
Diagnosis and estimate by Independent mechanic : Pending
Car was serviced just 2 days back, no issues before service.
All four tyres were replaced after service, and wheel alignment / balancing done outside.
Will update here once Diagnosis and estimate by Independent mechanic is done.
Is there any possibility that problem happened due to service?
Any other owner faced similar issue?
Vishal.R is offline   (1) Thanks
Old 26th November 2020, 18:13   #3021
Reinhard's Avatar
Thanked: 18,118 Times
By chance did your service list contain anything to do with AC cleaning / overhaul etc? If yes - I very much suspect they managed to leak the refrigerant accidentally while fiddling with the system. Its best to get it checked from outside & just recharge the gas once. Replacing the coil without confirming there is a leak won't be the right solution. (Of course the estimate that A-S-S has given to you is also for the worst case, they may just eventually say that a recharge was enough.)
First of all - check that the compressor relay TICK-TACK happens when you press the AC button on the dashboard. Then check the cooling control knob is on the "COOL" side sufficiently & has not been inadvertently turned to the center / HOT positions. Check where the air-flow is directed. In case they have accidentally changed it to demister positions, all the air will be blown towards the windshield.
If all this is in order - get the quote from the FNG, with focus on just recharging the gas once. Try how it goes. If the cooling reduces - there is a leak in the system / plumbing somewhere that will have to be found out.
Reinhard is offline   (2) Thanks
Old 29th November 2020, 15:18   #3022
Thanked: 74 Times
Hello all,
My Zest diesel has some electrical issues. A few functions aren't working
  • remote lock unlock
  • music systrm
  • reverse parking sensors
  • music system display
  • air con controls (AC is on by default)
The car starts and runs just fine. I showed it to a fng first (Carsmith Motors) who redirected me to Tata service center as they weren't able to scan any error codes.
TASS (KHT Motors, Whitefield) just came back to me after their preliminary investigations. They want to replace the whole music system assembly, costing 45,000 plus. I am not sure if replacement is the only way. Can it be repaired?
I am not sure what options do I have. Any Tata specialist FNG suggestions (in Bengaluru) are most welcome.
himarg is offline
Old 29th November 2020, 23:57   #3023
Thanked: 74 Times
Originally Posted by himarg View Post
Hello all,
  • music systrm
I got the car back from TASS without any repairs being done and after paying the inspection amount. Spoke to the technician there and he said that the fuse kept blowing off multiple times implying that something is wrong with the Head Unit. However, since the time I returned from TASS, remote lock/unlock and AC start stop is working.
I am thinking of the below possible options, in the order of preference:
  1. Find a reliable FNG with expertise in diagnosing TATA electrical or electronics issues
  2. Replace the head unit with a compatible system. However, the new system must be fully Zest compatible and have Android Auto + Apple Car Play
  3. Leave the HU as it is and run the car without music and reverse parking sensors
  4. Replace the HU @50k approx
BTW, the variant is XT, I forgot to mention it earlier.
himarg is offline
Old 30th November 2020, 01:47   #3024
Thanked: 7,685 Times
Try to get a proper diagnosis before deciding on anything.
You can check the wiring diagram to see what's common in these systems. Basically, narrow down to the fuses that are 'blowing'. From there you can try to isolate the suspects. If there are any new aftermarket fitments - you should check them first.
Also, have a good look at the wires in engine or footwells for any signs of rodent action.
Dry Ice is offline   (1) Thanks
Old 30th November 2020, 15:47   #3025
Thanked: 74 Times
Thanks for the suggestions Dry Ice.
Unfortunately, the circuit diagram will probably be like Latin or Greek to me. Considering my lack of competence with anything having wires , I am searching for a reliable electrical/electronics repairing place. I have found one in T BHP directory and will probably try it out the coming weekend.
I also asked the TASS technician and checked myself (as much as I could) - there doesn't seem to be any rodent problem.
However, since the AC controls and remote lock unlock have started working after their diagnostic - I suspect some lose wiring may be at play. That is my primary line of thought currently and I will try to confirm the same at the FNG in coming days.
If that doesn't pan out, then the second option is to get a decent aftermarket HU.
himarg is offline
Old 3rd December 2020, 12:10   #3026
Thanked: 108 Times
[*]Replace the head unit with a compatible system. However, the new system must be fully Zest compatible and have Android Auto + Apple Car Play
There are after market head units available which are fully compatible with Tata Zest XT. I had a contact in Delhi but somehow misplaced his number. In all, a third party solution is very much possible in lesser amount.
As for TASS, their only solution to anything wrong with Music system is to update software and then replace the whole unit which is very frustrating.
Not sure what other manufacturers do for their cars.
devilicious is offline   (1) Thanks
Old 3rd December 2020, 12:14   #3027
Thanked: 108 Times
Originally Posted by low_rider View Post
My Zest is due for service by this month end. Although I do not have any issues with the Tata ASS, but wanted to try out some reliable FNG this time, mainly for the cost differential. The car is almost 6 years now and 86K on the odo.
Any pointers to a reliable FNG in Gurgaon would be appreciated. TIA
You can try GoMechanics. Their yearly servicing cost for Tata Zest Petrol is ~4200. Though, have never used their services myself yet.
Old 3rd December 2020, 18:17   #3028
Thanked: 74 Times
Thank you, this is a relief to know.
I wonder with the ever increasing electronics in cars, are we heading towards a maintenance nightmare? I jokingly asked the TASS SA if Zest HU is 50k, then Altroz's must be touching 1L. He only smiled in reply.
himarg is offline
Old 3rd December 2020, 19:31   #3029
Thanked: 3,375 Times
Hi, boodmo is quoting about Rs.27k for Zest Head unit (link). Why don't you check with Prerna or Kropex about its cost?
50k seems steep for the head unit.
srvm is offline   (1) Thanks
Old 4th December 2020, 11:12   #3030
Thanked: 74 Times
I checked the link and think that the product is the HU used in XM and XMS (without touch screen), hence the price difference. In fact, there are multiple such options.
https://boodmo.com/catalog/part-musi...play-38990763/
https://boodmo.com/catalog/part-musi...mory-37466716/
I will try to find out more about the exact HU model and check the prices. Thanks for sharing !!!
himarg is offline
