Originally Posted by Sankar The new one is called K-next engine. |
Thanks! Corrected this soon after you posted.
Originally Posted by hemanth.anand Can this AMT controller be fixed to an alto for example? (if space permits i.e.) If MASS provide this option, there would be many takers I guess |
Originally Posted by PapaBravo So is it possible to make my normal MT car an AMT by just attaching the Magneti Marelli box to the transmission ? Is it practically feasible ? |
Well, the Alto
will be getting an AMT by the end of 2014. After that happens, it should be fairly easy to bolt on. The trickier issue will be the controls in the cabin (but they are just electronics, so it is possible).
Alternatively, you could retrofit a half-way-there solution like
this.
Or opt for a eClutch system from
bosch Quote:
Originally Posted by latentpotential Perhaps, the only thing I would ask more, is an owner should put up a video log alongwith a torque or simlar application capture log, which would show the exact behaviour of the Magenti Marelli unit. |
In most cases (baring close to WOT and heavy loads) the upshift points would be similar to those mentioned in the review. What other info would you have liked to see?
Originally Posted by theMAG 1. Between the two - the regular driving gear-change energy sap observed and the suggested technique of slightly lifting off at 10 km/hr intervals to facilitate a smoother power availability during gear change, which offers more seamless power delivery? |
For smoothness, definitely the latter! Mostly because the gearshifts happen when you expect (or rather dictate) them in that case.
Originally Posted by agnimidhun This seems odd and unsafe. Does it mean that one needs to constantly press the accelerator when driving uphill - or else, the car might slowdown and start rolling backwards? |
Originally Posted by guptad42 Shouldn't it downshift to the right gear for the speed, instead of stalling like this? |
Let me just clarify here (as well as edit the opening post to avoid any confusion): this does NOT mean the car shifts to neutral when you take your foot off the accelerator whilst going uphill. This also does NOT mean the car does not downshift - it only applies when
lugging at crawling speeds (in 1st gear). The fact is that you'd have to be a horrible driver doing something terribly wrong to ever get into this situation. To put it into perspective, if you did the same thing in a manual car, the car would stall. In this case the AMT shifts to neutral to prevent a stall. It was just mentioned as an interesting / technical observation.
That said, it would probably be safer to stall in-place than to shift to neutral - however, the AMT is using the same logic it does when say, you try and drive ahead when there's a big rock in front of your wheel.
Originally Posted by e46 I would however, like to know if am allowed to, what took you guys close to 4 months to come up with this. I believe, this is the first time we had to wait this much. |
Yes, it is. To add to what was mentioned earlier, we only ended up driving the car in April - and the next few weeks were spent dealing with Team-BHP's server move, which to be honest affects TBHP in a much larger way, and hence i had to prioritize that over the Celerio review.
Originally Posted by Kaumad How did you arrive at the Transmission Efficiency values? |
Source. Naturally they are a generalized value for each type.
Originally Posted by Kaumad Further, "transmission efficiency" is of no consequence to the consumer, fuel efficiency is. |
Since we were talking about the transmission in that post i provided energy efficiency numbers for better understanding of each type of transmission. For comparing overall fuel efficiency, there's already the ARAI numbers which consumers are well familiar with.
Originally Posted by Gannu_1 I got a bit confused with this one: |
Ahh, i see what you mean here. I will rephrase that point. Thanks.
Originally Posted by girimajiananth He shifted from D to M while driving and the car stalled for no reason. ... After a while he tried shifting it from D to M , the car stalled for the second time. |
That's strange, and sounds like more of an electrical problem to me, simply because the act of shifting from D to M does absolutely nothing mechanically.
Originally Posted by rohan_iitr Also, does the MID display the gear information in D mode also ? |
Yes, see
here.
cya
R
