Old 16th February 2017, 09:45   #5461
adarsh76's Avatar
Thanked: 231 Times
re: 4th-gen Honda City : Official Review
Originally Posted by Sree73 View Post
A reproduction from Honda City Owners manual found online. These are calculated with respect to engine speeds in each gear. So, if these speeds are crossed in each gear, will be exceeding the specified engine RPM.
Tejas, Sree is right here. There was a case reported in Peninsular Honda, TVM. An Amaze car (forgot if it was a Diesel or Petrol) which had some gearbox damage. The car was repaired free of cost to the owner applying the warranty. However, later on when Honda technicians assessed the problem (records of Diagnostic System), it was found that the car was red lined too much.The warranty claim was rejected and Peninsular Honda had to bear the costs.
After that, the check is being done very strictly (may be across all dealers) for damages applicable for warranty coverage.
Suggest you should stick to what Honda says if you do care about warranty.
adarsh76 is offline
Old 16th February 2017, 10:15   #5462
Thanked: 20,584 Times
Originally Posted by Ruchir031 View Post
They however yet did throttle body cleaning and EBD without my permission which costed additional 1.2k.
I actually do get throttle body cleaning done on my folks' '09 City in Gurgaon during every service. Costs about 400 and there is a difference in throttle response.
libranof1987 is offline
Old 16th February 2017, 14:42   #5463
Scorpion 10's Avatar
Thanked: 102 Times
Originally Posted by Rocketscience View Post
Have been noticing this strange thing with my City (D) from quite sometime now
What could be at fault here ? I noticed this in my petrol i20 too in the past but not any other cars.
Some time back, my friend was complaining about engine vibrations in his Amaze and issue was found to be a problem with clutch switches.
Update in forum the feedback from SA, this will be helpful for others.
Scorpion 10 is offline
Old 16th February 2017, 15:07   #5464
deerhunter's Avatar
Thanked: 992 Times
I couldnt find that in my owner's manual. Mine is a 2014 March iVTec.
Amaze diesel has some sort of speed limit restriction. That may have something to do with engine/GB damage at high rpms.
In my City iVTec owner's manual, no mention is made of the rpm restrictions/speed per gear. So I guess there are no issues with the City petrol.
4th-gen Honda City : Official Review-img_20170216_152548_hdr_edited.jpg
deerhunter is offline   (1) Thanks
Old 16th February 2017, 16:37   #5465
Thanked: 102 Times
Attachment 1609088
I guess it's the user manual of Amaze. City's Diesel variant has a 6-speed manual transmission and there is no mention of the same in the manual.
Old 16th February 2017, 16:50   #5466
adarsh76's Avatar
Thanked: 231 Times
Attachment 1609088
Still, have a check with your service adviser on this. You know how costly it would be if something happens.
The warranty terms and conditions may not be mentioning about the rpm limits but certainly it would be saying that 'improper driving will void the warranty' or some similar phrases.
adarsh76 is offline   (1) Thanks
Old 16th February 2017, 16:52   #5467
The Brutailer's Avatar
Thanked: 1,437 Times
One question I've always wanted to ask : Has anyone seen what happens when the Range in MID goes to 0?
How many kms can you go after that?
The Brutailer is offline
Old 16th February 2017, 17:10   #5468
deerhunter's Avatar
Thanked: 992 Times
A friend has gone 15km in a petrol city after the MID showed 0. He was somewhere in Odisha and failed to notice his MID. Anyway, he found a petrol pump before running dry.
I will check with the service manager tomorrow.
Old 16th February 2017, 17:14   #5469
Oh so around 1 litre is left? 15kms is quite low. Atleast 50 kms should've been kept as backup.
Old 16th February 2017, 17:15   #5470
deerhunter's Avatar
Thanked: 992 Times
He did not run out of petrol. He found a pump after running for 15km. Maybe the car would ve run for 50km if he had not found the pump.
Old 16th February 2017, 17:23   #5471
Thanked: 564 Times
Be careful. The max allowable speed for Honda city in 2nd gear is 71 KMPH and 93 KMPH for diesel / petrol respectively.
LOL that's just stupid, rev limiter is built for a purpose.
H_Dogg72 is offline
Old 16th February 2017, 22:04   #5472
Makin Rulesz's Avatar
Thanked: 477 Times
I have driven around 10KM in City diesel after the MID hit 0 on some rural state highway. Car would not accelerate even on flooring the pedal and I had to shift early to keep it moving. Driven slowly in third gear with AC off till I found the fuel station.
Makin Rulesz is online now
Old 17th February 2017, 12:03   #5473
Thanked: 1,091 Times
One can generally manage to squeeze out a reasonable distance even after the low-fuel warning light illuminates or the range has hit 0 on the MID.
I remember experimenting on my old Corolla to see how far the car would go before dying. I managed to cover 69 KMs (after the fuel warning light came on) before the engine died due to lack of fuel. I had carried a 2 liter can of petrol which then helped me get to the nearest fuel station.
The most I have done in my City (petrol) with the range displaying 0, is about 18-19 KMs. I made it to the petrol pump without any issues. Though I believe it isn't a good idea to drive for too long on the reserve as it may be harmful for the fuel filter/fuel pump.
fordfreak is offline
Old 17th February 2017, 12:25   #5474
Thanked: 3,361 Times
The fuel pump was sure struggling to maintain the right fuel pressure, the chances of damage being very high.
Driving around with less than 1/4th of the Tank full is a bad idea and is a sure shot way to damage or cause premature failure of the fuel pump and also the catalytic converter.
Both are expensive parts and its always better to keep the fuel pump submerged in fuel and never to let the fuel level go below 1/4th.
for_cars1 is offline   (4) Thanks
Old 17th February 2017, 17:08   #5475
Thanked: 477 Times
100% agreed with your comments about possible damages to the fuel pump. In my case I had enough fuel(at least 2 bars if i remember correctly) when i reached the first available fuel pump. But unfortunately it was shut for maintenance and by the time I could reach the next one, MID started showing 0. I did the last few KM's almost coasting.
