Old 22nd April 2015, 13:22   #3841
re: 4th-gen Honda City : Official Review
Originally Posted by srameshdelhi View Post
Can someone confirm that Spare Bulbs are not provided anymore from Honda?
No spare bulbs for me either. Had checked at the time of delivery and was informed that these aren't provided any more. (I checked because I had received spare bulbs for my Spark 6 years back).
keviv is offline
Old 22nd April 2015, 15:34   #3842
tejas08's Avatar
Thanked: 1,147 Times
Originally Posted by KRN View Post
I didn't get spare bulbs either when I took delivery of the City
I did get spare bulbs alongwith my car (Delivered on Apr-2014) but they are pretty much useless. The stock bulbs although Philips or Osram really are the regular bulbs and nothing extravagant.
My suggestion to you guys would be upgrade the Low Beam and High Beam to Philips Extreme Vision / Osram Night-Breaker Unlimited and keep the current stock ones as spare.
Note: Changing the High Beam to the above mentioned bulbs too does not give the desired effect. The High Beam reflectors are not good.
tejas08 is offline
Old 22nd April 2015, 22:50   #3843
Thanked: 25 Times
Get hids for the high beams. The stock reflector is pathetic, had upgraded lights to xtreme vision but was of no use. I just had light scattered with no usable light. I thought of installing hid hesitantly, but once installed to my surprise the beam pattern changed to focussed straight ahead. An amazing side effect. The high beams act as auxiliary lights now extending the beam length of the lows. Try the hid's, you would be pleasantly surprised.
fastraj is offline
Old 22nd April 2015, 23:23   #3844
D4D
D4D's Avatar
Thanked: 336 Times
What RPM does the petrol engine spin at 100 Kmph in fifth gear?
D4D is offline
Old 22nd April 2015, 23:57   #3845
pixantz's Avatar
Thanked: 1,014 Times
D4D checking out the vital stats of VVTi?
pixantz is offline   (1) Thanks
Old 23rd April 2015, 09:30   #3846
tejas08's Avatar
That's on my mind since a long time. That's the same point I made at the below post too.
http://www.team-bhp.com/forum/test-d...ml#post3689774
Everybody has their own views, hence I suggested going for Philips Extreme Vision first. If they find it's good enough for them, then can continue using it else go for an upgrade to HID.
There are some folks on the forum who are actually satisfied with the Low Beam on Stock bulbs too. Depends on every person's perception.
About 2200 RPM.
tejas08 is offline   (1) Thanks
Old 23rd April 2015, 10:52   #3847
I have an AT.
So far, in the 500 kms that I have driven the car, the speeds have varied from 10-90kmph and I haven't seen the RPMs go above 2K. I am talking about the "D" mode.
keviv is offline   (1) Thanks
Old 24th April 2015, 08:55   #3848
tejas08's Avatar
About 2200 RPM.
My Bad. It's 2900 RPM. I don't know why I got that 2200 RPM in my head. Yesterday while going back from my office, I checked the Engine RPM at 100 kmph.
I have an AT.
The credit for that goes to the 7 Virtual Gears that the Automatic has. The Manual is a 5-Speed Gearbox. Hence the RPM for Manual at 100 kmph is around 2900.
tejas08 is offline   (2) Thanks
Old 24th April 2015, 09:57   #3849
sun_king's Avatar
Thanked: 308 Times
At 100 kmph it is 2900 RPM, stable with Cruise Control set. 110 kmph, it goes to slightly over 3000.
I was quite surprised by Tejas' first reply of 2200, so tested it today morning when going to pick up a cousin of mine.
sun_king is offline
Old 24th April 2015, 12:31   #3850
geotracks's Avatar
Thanked: 213 Times
I had a question on fuel tank capacity. At around 14.8 kmpl - 15 kmpl, I am getting around 400 kms on ODO, before the fuel needle touches 'Empty' mark. Now 400 kms tank full to tank full is seems very low. My Getz goes to around 450 ks before touching empty. Is the Honda City tank really that small? Once I get the fuel indicator light around 400 kms ODO reading I have to fill up.
What are other Honda City owner experiences on this aspect? Would be good to know.
geotracks is offline
Old 24th April 2015, 16:21   #3851
There are some folks on the forum who are actually satisfied witceh the Low Beam on Stock bulbs too. Depends on every person's perception.
About 2200 RPM.
Are you sure about that 2200 figure?
I checked my meter today while driving and it was revving at 2800 at 100kmph. 2200 was around 80, if I remember correctly. What could cause this possible difference?
shubhamag92 is offline
Old 24th April 2015, 17:00   #3852
aviator1101's Avatar
Thanked: 2,502 Times
I checked it today over a long open stretch of around 12 kms. In cruise control mode at 100 kmph, the rpm was around 2900-3000. Also i noticed that on gradual climbs the rpm increased slightly and the instantaneous fuel efficiency readings dropped quite a bit.
aviator1101 is offline
Old 24th April 2015, 17:45   #3853
adarsh76's Avatar
Thanked: 231 Times
Situation is different in 'S' mode. I haven't clearly checked how much it climbs but definitely above 2500 or 3000.
adarsh76 is offline
Old 24th April 2015, 19:22   #3854
knight.rider's Avatar
Hi. Can someone please elaborate on the tyre rotation pattern? Completed 5000 kms on my stock MRF. I couldn't understand the jargon online, as to which method is correct and how it shall be repeated subsequently.
knight.rider is offline
Old 24th April 2015, 20:24   #3855
harry10's Avatar
Thanked: 3,774 Times
Usually rotation is done at every 10k km AFAIK. I think it's even mentioned in the service manual.
harry10 is offline   (1) Thanks
