Please brace yourself for a really lengthy post of problems.
PROBLEM 1:
Originally Posted by g_goyal2000 I experienced a peculiar problem with my Grand i10 2-3 days ago.
I had started the car, but the car was not in motion.
It was standing with AC & engine on.
All the lights & alerts in Instrument Cluster had been displayed as is the case when the ignition is turned on.
Then suddenly after 20-30 seconds, all the lights & alerts in Instrument Cluster again got displayed even though the car/engine was already running, but not in motion.
All the meters like tripmeter, etc., but not ODO, got reset all by themselves.
Initially, I thought the battery connections might have shorted or might be loose.
But the ODO, clock, date and FM channels were untouched.
What could be the problem?
This kind of problem has happened to me first time.
Even my first car service is due in next 2-3 days.
Please help. |
Originally Posted by Car's Paradise Dear Sir,
I had encountered a similar problem one month back in my Grand i10 Petrol (Magna Variant).
I had stopped at a toll plaza, and when the car came to a complete halt suddenly all the tell-tale lights in the instrument panel came up in-spite of the engine being on, and they went off in a second or two.
Both the trip meters, avg. speed meter, vehicle running time meter, FM channels were reset.
The same day i had retrofitted steering audio switches onto my existing steering, which involved the change in spiral cable(clock-assy) and adding new wiring for the switches (however the switches are not functioning as on date and i am trying to find out a solution for its functioning) .
I had thought the lights in the instrument console came up because of the retro-fitment , but since that day the problem has not cropped up again *touch wood* . I tried to find any error code with the help of ELM 327, but nothing showed up.
Will definitely update if the problem reoccurs.
Car's Paradise |
Originally Posted by sidzz Well, I witnessed live, the niggle discussed earlier in the thread.
Today morning in bumber-to-bumper traffic the console lights went off and all meters were reset except the odometer. All needles went back to default position and did a full sweep. As if I had switched off and on the ignition quickly. There was no jerk or loss of power. I did not panic as i had already read the posts.
This happened first time in my 1.5 yrs of ownership.
Has anybody found any solution to this? |
During 1st service checkup in May 2016, mentioned this problem to the Hyundai SA who said later that they found no problem, but nevertheless, have reset the electric system (whatever that is) and I would not face this problem again.
I was starting to think this was a one-off incident.
But it was not.
I experienced it 1-2 times more later.
But I noticed one thing peculiar both times.
The rear power windows safety lock did not seem to work after occurrence of this issue.
Lock them and the rear power windows were still working.
So, I thought there must be some shorting of wires.
But this problem used to get resolved all by itself after some time (can't say how much time).
This problem hasn't occurred again since past few months.
PROBLEM 2:
However, now a new problem has cropped up.
A MORE DANGEROUS problem.
Many times, when I start driving after starting the car, the steering wheel has more of an inclination towards my right side than towards centre.
While driving, I have to make an effort to keep the steering in centre or in direction I'm driving.
If take my hands off the steering while driving, the steering wheel slowly start inclining towards right (did that for a short distance to check the issue on different & regular route roads).
But later on, the problem automatically goes away.
It seems this steering problem has taken the place of meter reset problem.
PROBLEM 3:
Since the 1st service of my car, the engine has started making noise.
Prior to 1st service, the engine never made any noise even when I was standing beside it.
Now, even when I'm sitting inside the car with all windows closed, I can still mildly hear the engine noise.
I tried my cousin's 1.5 yr old Grand i10 and it was as silent as if it was brand new.
And the clutch feels as if it has worn out.
Prior to 1st service, I could easily put my car in motion if I gradually eased off the clutch pedal in 1st gear.
Now after 1st service, when I try to do that, the engine just turns off (I hope you understand what I'm trying to say.)
In bumper-to-bumper traffic, I have to make an effort to keep the car in motion & engine on.
PROBLEM 4:
The suspension has become a little hard after 1st visit to service centre.
Is it possible that service centre has indulged in malpractice and probably changed engine oil with low grade mineral oil and swapped brand new clutch plate, wire or entire assembly with worn out ones; and might have tinkered with the suspension?
PROBLEM 5:
Moreover, if I'm sitting in my car with engine on and windows down, there's weird humming/vibration which only goes away when I close all the windows.
Now, those area lot of problems.
I was better off with my 9 year old WagonR with which never had such problems even after servicing.
Please help guys.
