Originally Posted by Apolo4409
(Post 5704296)
As a fellow owner, I urge you to please have the sensor changed ASAP. I just went through this on mine and it’s a miracle I am still here to tell the tale considering how badly it could have ended. Without ABS, a sudden brake for whatever reason can lead to all 4 wheels locking up and turning the car into an uncontrolled 1-1.5 ton metal block. ABS is extremely crucial in our roads where every second there is a surprise waiting for us in the form of a distracted jaywalker, stray cattle and pets, distracted drivers and the worst of all, the energy conserving folk who refuses to either turn on or fix their taillights and headlights before going on a journey at night on roads without street lights. Given yours is a DSG, there is also the other issue where the gearbox relies on your speed sensor to decide gears and the ECU will use the data as well. Had a horrible experience with the speed sensor out in a DSG vento, the car will accelerate and decelerate on its own against driver input. The cause was the speed sensor being faulty. Each erratic response coincided with the speedometer needle going all over the place. While I am not a VW mechanic, from experience I believe the speedometer and ECU rely on the front sensors for the speed data while the rear 2 sensors are just for ABS. So if you are not seeing the erratic behavior it’s probably the rear sensor. As for the cause of this, it can be anything from a water ingress to bad luck. The newer sensors are said to be more reliable but it’s yet to be seen. |
Originally Posted by Dead Head
(Post 5704507)
I have a Polo GT TSI of mid 2018 vintage which has clocked 32000km . It has been self driven and routinely serviced at the VW ASC at Ram Mandir. I have changed the battery once but the original tyres are still doing service , with perhaps once or two incidence of punctures in all the tyres. I have had the punctures tended using the proper 'mushroom patch' rather than the quickie method of putting in a rope like substance from outside. The paintwork has had a few nicks and scratches which have been touched up.The car looks pretty good. I use the car sparingly as it is not our primary vehicle. It runs only about 400 km a month . The question in my mind is , how long should I continue using this vehicle? Lovely , as the car is, it will not appreciate with time . Also the insurance and annual service costs 40 /50K annually. Sooner or later I will change the tyres which would be roughly another 32K . Sparing as my usage is , maintenance costs will only rise as time passes. If I sell now, I may get 6.5 L for it ( perhaps, going by the prices I see on FB market place) Or should I hold on to the vehicle for another 3 years after which it may sell for 3 or 4 lakhs ? Have I reached break even point or should I allow heart to rule over the head? Also I dont know of any vehicle which can replace the Polo GT TSI and at a cost as reasonable as what I had paid for it . Just some randon thoughts ...... |
Originally Posted by Dippy
(Post 5704561)
32000 km is nothing. Please don't sell your GT TSI. Truth be told there is no hatchback out there that can match the car in terms of pure analog fun. New car prices are also through the roof and you will get nothing in the price point that you paid for the Polo that will excite you. You will definitely have to shell out substantially more money. Keep the car and enjoy it for as long as you can. Timely service and even tyre change will work out cheaper in the long run than getting a new car. I have a 2016 GT TSI that has clocked almost 38000 km in the last 7 years. Usage has gone down considerably after the Thar came home, but I will be holding onto it till it turns 10 years old minimum. Many people have asked me if I want to sell but I have politely rejected the requests. |
(Post 5704507)
I have a Polo GT TSI of mid 2018 vintage which has clocked 32000km . It has been self driven and routinely serviced at the VW ASC at Ram Mandir. The question in my mind is , how long should I continue using this vehicle? Lovely , as the car is, it will not appreciate with time . Also the insurance and annual service costs 40 /50K annually. Sooner or later I will change the tyres which would be roughly another 32K . Also I dont know of any vehicle which can replace the Polo GT TSI and at a cost as reasonable as what I had paid for it . ... |
(Post 5704568)
Sound advice Sir , thank you Dippy . I think vehicle manufacturers are duty bound to render spares availability and service for 15 years ? |
Originally Posted by VwRabbit
(Post 5704691)
I have faced the ABS issue on both my GT TDI and TSI but thankfully it was within warranty, don’t ignore this even if usage is low as I have done the same and have faced issues with braking performance with the pedal feel becoming similar to stepping on a stone at times that too at low speeds. Another problem is that like some others have pointed out when one wheel sensor fails eventually the others will too however last time when it happened to me which was maybe a year and half ago the SA informed me that they now have a new batch of sensors which will rectify this issue and installed that on all wheels post which i have not had any problems even though my car is lowered and runs on upsized tyres (also it might be because my usage now is mostly on highways so better roads but previously used to take it to some rural broken patches of roads). |
(Post 5704691)
Another problem is that like some others have pointed out when one wheel sensor fails eventually the others will too |
(Post 5707039)
a soft rattling sound |
Originally Posted by Thad E Ginathom
(Post 5707144)
Could be the internal ventilation fan? Try turning it on and off. Mine has been annoying me for years. I want it fixed, but my FNG is really reluctant to remove the dashboard unless really needed, so I'm just beginning another year of it |
(Post 5705577)
I don't see the point in replacing all four because one had gone. I think the SA just wants to make the sale. |
(Post 5676708)
I have been driving with these lights on the dash for the last one month. Perhaps my imagination but the car seems to pull a shade bit less , coasting at 50kmph the car was on D6 rather than D7. |
