Old 19th January 2020, 17:16   #6511
Thad E Ginathom's Avatar
Thanked: 29,949 Times
Re: Volkswagen Polo 1.2L GT TSI : Official Review
Originally Posted by zen View Post
... Bajaj are playing hardball while processing warranty claims and issuing warranty extensions.
Internationally, all/most companies insure against the cost of warranty claims: it is a part of the corporate insurance market. It is absolutely unacceptable that the end customer should suffer because of internal financing changes.
I have no idea about the actual mechanics, though. What I would expect (and my small insurance-industry experience is from almost twenty years ago now) is that the manufacturer is the insurer for warranty clams, and that they would offset these expenses by buying reinsurance. The relationship between the company and its reinsurer(s) should be completely irrelevant to the end customer.
Thad E Ginathom is online now   (2) Thanks
Old 22nd January 2020, 00:41   #6512
Thanked: 288 Times
Hi guys, I have a 2015 1.5 tdi polo with r15 wheels. The current usage of the car is semi rural and highways and therefore low Ground Clearance has become an issue. I know polo is the least suitable for these conditions but selling it off with such low resale value seems to be a ridiculous idea, and so we've decided to keep it and use it for daily needs.
Therefore, I need suggestions on options that I have to increase the gc. Tyres with different specs is what I am inclined towards and not so much towards spacers, suspension kits etc. Has anyone done it successfully before?
Apologies if this topic has been discussed in this thread before. I tried scrolling through it but without any luck.
Malhi is offline   (1) Thanks
Old 22nd January 2020, 10:50   #6513
Viraat13's Avatar
Thanked: 3,419 Times
I think you'll be better off installing an engine protection plate. The Polo is a pretty high car as it is, I've not heard of cases of under-body hits. Taller tyres will give you a few mm more of GC, but the plate will be added insurance.
Viraat13 is offline
Old 22nd January 2020, 12:13   #6514
Thanked: 288 Times
It has one plastic under body plate. Are there any metal plate options?
The gc isn't enough even for 'under repair' stretches of the highways let alone bad roads. Believe me, I've come to complete halts in the middle of highways, on encountering big potholes, reversed the car and bypassed them to avoid underbody scrapes. In comparison to the swift, for example, the polo is way behind in tackling bad roads.
Malhi is offline
Old 22nd January 2020, 23:18   #6515
SLK
SLK's Avatar
Thanked: 1,417 Times
Yes, Polo is ok, but in situations where you park near/ facing a footpath a small hit to the front under-body is known to cause major internal injuries (to the things in the engine bay).
That isn't quite true in my experience. The overall GC of the polo could be marginally lower than the swift, but it actually works much better because of stiffer springs. Also, the lower lip (front bumper) of most Marutis is a big problem, they scrape and break and what not, which is much better in Polo.
I have one question of my own. Its a topic discussed before, but let me show my Polo's idle rpm.
Volkswagen Polo 1.2L GT TSI : Official Review-20200122_212718.jpg
If you calculate, this comes to slightly below 700, which is cool. The problem is that most often its idling at 950 (without AC), and if I push the accelerator to take it to about 1500 once and then it comes back and settles at this 700ish. Does this happen with others?
SLK is online now
Old 22nd January 2020, 23:58   #6516
McLaren Rulez's Avatar
Thanked: 5,515 Times
Probably the cold start idle rpm is higher (900) and once it warms up, it settles to 750.
McLaren Rulez is online now
Old 23rd January 2020, 00:03   #6517
SLK
SLK's Avatar
This is all warmed up, after driving for an hour. I'll get a video next time.
SLK is online now
Old 23rd January 2020, 07:50   #6518
Thanked: 8,503 Times
I was amazed by the Polo's ability to Off-road just two days ago. I had to drive through a completely-dug-up narrow road to reach my society, thanks to a ginormous traffic jam resulting in a 45 min crawl for 400 metres. And oh boy, my heart was in my mouth while negotiating this mess of stones, deep dug out patches, water and incessant two-wheelers traversing in the opposite direction, all struggling. As usual, there was no notice of the road being dug up ahead. I had to take a sharp left turn, which was like a 2-feet step from that road level, and I was at a point of no-return. Initially, the car hesitated, and I realised that the Traction control was playing its part. So I switched off the TC, put the DSG in Sport and gave the pedal an almighty shove (Hail Mary! situation). Thankfully, the car leaped up easily without hurting the undersides. Any other typical sedan/hatch would have surely left its bumper or its underbelly behind in the circumstances. The passersby were left astonished.
Volkswagen Polo 1.2L GT TSI : Official Review-img_3290.jpg
fhdowntheline is offline   (1) Thanks
Old 23rd January 2020, 11:05   #6519
Viraat13's Avatar
I'm not sure. The part number is for the plate is 6R0825235 (Courtesy TheLizardKing).
If you calculate, this comes to slightly below 700, which is cool. Does this happen with others?
YES! It is a very inconsistent "issue" though. I always thought it was some problem, but luckily it happened at the SC once and the guys scanned and checked everything it was OK.
In short: nothing to worry about.
Impressive. I've taken the Polo on some bad roads too, and I've come away without a scratch.
This is the highest car I've ever owned, so my perspective isn't too great to begin with.
Viraat13 is offline
Old 23rd January 2020, 11:19   #6520
suhaas307's Avatar
Thanked: 14,506 Times
Agreed.
Careful negotiation would get you through most situations.
I have driven my lowered Polo 1.2 TSI over some gigantic speed breakers and even over non existent roads. You will find pictures of my escapades on my ownership thread where I had driven off the tarmac and over a pathway that was created for mining trucks and tractors, and my car came out unscathed.
If you drive a little quickly over non existent roads, you may have a problem. But if you are careful, you wouldn't have any issue.
suhaas307 is offline
Old 23rd January 2020, 14:37   #6521
I had to drive through a completely-dug-up narrow road to reach my society ...
Sadly, all the roads around my house are at least as bad. In many places, there is no tar surface, just mud and holes. The roads have been repeatedly dug over the past two years, and never repaired.
There is a storm drain across the entrance to my street. It is built high above the road level, with quite a wide flat. The slopes either side have worn down recently, and some part of my Polo GT tdi often catches.
Old 23rd January 2020, 17:00   #6522
Thanked: 288 Times
I see what's happening here. "Bad roads" in the rural areas could actually qualify for "Off road" trails for our urban brothers.
Therefore I googled a photo to illustrate what my German engineering masterpiece has to go through.
I know what many might be thinking, but I can't sell it off because I have spent more on it's alloys and tyres than the value being offered to me for the whole of it.
The swift does a better job in tackling such situations than the sophisticated polo.
Ps- where I come from (UP) one can come across a similar road conditions in the middle of a town, on district roads or even on under construction highways.
Volkswagen Polo 1.2L GT TSI : Official Review-images.jpeg
Malhi is offline   (3) Thanks
Old 28th January 2020, 09:13   #6523
BlueEyes's Avatar
Thanked: 206 Times
I am curious to know if anyone has installed these new side skirts & plastic bits from front/rear bumper? Not sure if this can be done, are these glued to the running board and the bumper? These would add extra bit of protection & I believe they look good on the white car. I know there are after market front lip which can be installed on the front bumper but I need side skirts also. I am guessing these would have there own part numbers & can be purchased & installed separately. My white GT is 5yr old and it has taken lots of beating especially the front bumper. I don't want to replace the entire bumper but would add these if possible
Volkswagen Polo 1.2L GT TSI : Official Review-28012020-084438.jpg
BlueEyes is online now
Old 31st January 2020, 22:57   #6524
Thanked: 116 Times
The stock tires on my GT has worn out as per service advisor. Its clocked in 65K Kms. Its Good Year Assurance model.
Can someone please suggest on which tyres should I replace it with that best suits the GT TSI?
ramb is offline
Old 1st February 2020, 06:02   #6525
graaja's Avatar
Thanked: 25,620 Times
I would highly recommend Michelin P4ST. They have a great balance between comfort, handling and road noise. If your car comes with the 15” wheels, then 195/60/15 is a good size to go.
graaja is online now   (1) Thanks
