Old 6th August 2013, 14:01   #1426
condor's Avatar
Thanked: 16,186 Times
Re: Tata Safari Storme : Official Review
I am surprised at the last point above .. slot in to 1st, let go of the clutch, and the vehicle will pull .. doesnt need any CRDE / DiCor engine. A simple TD will do that.
condor is offline
Old 6th August 2013, 21:32   #1427
4x4addict's Avatar
Thanked: 4,546 Times
so they reworked the gear ratios. The best thing about the change is that now reverse gear is much shorter.
Besides the gear ratios, they also made the final drive (crown/pinon) ratio shorter from 3.73 to 4.3. This results in much better low end acceleration. Although the mhawk engine is only 120 people fine the Scorpio peppier only because of the shorter gearing. The draw back though is that at 120+ speeds, the Storme will run at a higher rpm than the older 2.2 VVTI safari.
4x4addict is offline
Old 6th August 2013, 21:38   #1428
condor's Avatar
I think the more important reason for the percieved peppiness is the lighter weight of the Scorp / XUV, as compared to the Safari twins.
condor is offline
Old 6th August 2013, 22:59   #1429
tsk1979's Avatar
Thanked: 22,924 Times
No it won't. The 5th gear has been made taller(Check out the screenshot in the review)
tsk1979 is offline   (1) Thanks
Old 7th August 2013, 12:35   #1430
avanishphatak's Avatar
Thanked: 234 Times
Hi I haven my Storme for the Ist service 1500km today, just wanted to know should i go for Teflon coating and anti-rust treatment from the service center?
they r coating 8k which i feel is little on higher side .
thanks in advance
avanishphatak is offline
Old 7th August 2013, 12:56   #1431
ebonho's Avatar
Thanked: 10,852 Times
Does anyone know if there is a hood deflector offered for the Storme - either by Tata Motors (as for the Safari Dicor) or by some aftermarket brand (like Carry Boy)? I tried looking but cannot find one anywhere.
ebonho is offline
Old 7th August 2013, 13:00   #1432
condor's Avatar
@Avinash, TML gives either 3M or Weurth. Check prices outside at 3M outlets & decide. You could take the anti-rust.
Which T.AS.S ? and which location ?
Is it possible to get one fabricated in Fibre-glass.
condor is offline
Old 7th August 2013, 13:03   #1433
Thanked: 234 Times
@condor
I have given it at KHT brookefield ,its the same service center where I used to give my old 2.2 dicor. I guess they do 3M
by the way I got the Price money which I had won in the win for sure contest
Ipad mini worth Rs30500 , for which 30% (rs 9150)TDS had to be made
Old 7th August 2013, 13:11   #1434
Thanked: 28 Times
@condor
Avinash, try 3m marathalli. Better then getting it done at Tass.
CharlesA is offline   (1) Thanks
Old 7th August 2013, 13:23   #1435
Thanked: 234 Times
@Charles
do they also have anti rust treatment ?
Old 7th August 2013, 14:34   #1436
Thanked: 28 Times
@Charles
Yes they do have it. Do call them and check, i think the price will be lower than TASS.
Old 7th August 2013, 15:14   #1437
suman's Avatar
Thanked: 280 Times
Originally Posted by narayan View Post
The beast has arrived. Ownership thread coming soon
Congrats man! Need a better picture though
suman is offline
Old 7th August 2013, 15:40   #1438
narayan's Avatar
Thanked: 2,374 Times
Thanks Suman. Ownership thread coming soon !
narayan is offline
Old 8th August 2013, 11:08   #1439
narayan's Avatar
Has anyone put sunfilm in the windshield ? Which brand/specs/cost pls- thanks
narayan is offline
Old 8th August 2013, 11:21   #1440
stormerider's Avatar
Thanked: 501 Times
Sun films are banned and cops are going after vehicles with the lightest of films. Hence I would suggest you refrain from installing those
If you need privacy or want to keep sun out, may I suggest roller curtains that roll with window glass. Many companies are making it, but I would suggest P8, probably is Korean, and set of four costs around 4200 in Jaipur.
stormerider is offline
