Originally Posted by kanchudeep |
Have been interested in installing a Tyre Pressure Monitoring System (TPMS) in my Renault Duster from quite some while. Was contemplating it very seriously as a mid-life upgrade of my vehicle (completed 07 years recently & nearing 90,000Kms) and came to know of a very good
deal.
I had already been researching the system by TREEL (owned by JK Tyres) and as per the above thread was getting very good rates from a dealer as part of a limited time offer (valid till 03 Dec 2022)...
As per the offer the rates were:
- Set of 04 sensors: ₹2,550/-
- Set of 05 sensors: ₹3,150/-
- External display unit: ₹2,300/-
The post deal rates by the dealer are:
- Set of 04 sensors: ₹2,950/-
- Set of 05 sensors: ₹3,659/-
The dealer is based out of Sonipat, Haryana:
Mr Kunal Relan
+919999933644
Deal WhatsApp Group:
https://*******************/L0cd9SMLOF6DbOopsgnMR3
Set of 04 sensors are sold at ₹5,599/- by TREEL
on their website & at ₹4,999/- by them on
Amazon.in.
You can actually use the sensors (04 or 05) even without the external display unit on a smartphone - in fact even with the Display one needs to pair with the smartphone first. It is just that I prefer an independent system.
The sensors have a claimed battery life of 07 years (batteries are not user replaceable), with 05 year replacement under warranty and the system have very good review as per my research.
This is one thread (Treel (by JK Tyres) launches internal TPMS sensors with Bluetooth) on the TREEL system.
I will not thus go into more details of the system but rather add information relevant to others interested or what I have not come across about the System.
I placed the order on 30 Nov 2022 for a total of ₹5,450/-. Package with items was received on 03 Dec 2022 via DTDC. All items were in original packing with seals intact.
Received items:
01 sensor was of 30 Jun 2021 manufacture, 03 sensors of 27 Nov 2021 manufacture and 01 sensor of 20 Dec 2021 manufacture. Display is of 30 Mar 2022 manufacture.
Marked each sensor with tyre code: FL, FR, RL, RF, S, using a permanent marker for later identification.
The sensors are designed to be used with the ‘SmartTyre Car & Bike app’ (
Android App /
iOS App) by TREEL. One needs to create a user account to use the app and give basic information of vehicle.
After opening all items, paired the sensors with the app, by scanning the QR code and added as per planned position.
App's main screen after initial pairing - only temperature being displayed
Post pairing the sensors with the App I received an e-mail from TREEL with a product kit code with the Tag ID of the sensors and Display.
The sensor data displayed by the App takes some time to update the information, so one needs to be a little patient in the beginning. I suspect the sensors transmit at interval as also on sensing motion to maximise battery life. The App allows checking the battery level of each sensor which were all showing 100% even though some sensors have completed more than 01 year from manufacture.
Next, synced the Display using the app by scanning the QR code, after which the Display gets info uploaded from the App of the sensors, user/vehicle info and configuration (minimum/maximum pressure, temperature, display ON time etc). Was also prompted for firmware update of the Display and it was done without any issues (to version R3.1 dated 07 Nov 2022). This was a pleasant surprise that the firmware will easily receive updates.
The next day, headed to a local tyre shop to get the fitment of sensors and also wheel balancing. Installing sensors on 05 tyres and wheel balancing for 04 tyres (less the spare and including cost of balancing weights) came to a total of ₹960/-. There was no issue in fitting the sensor even on the spare wheel rim (non alloy).
Sensor installed on the wheel rim:
Valve of TREEL system on the wheel:
App's main screen displaying sensor data:
Detailed screen for individual sensor:
Sensor setting which also displays battery percentage:
Fitted the Display to the right of steering wheel column console. The Unit comes with a strip of 3M double side tape on the front half of the bottom. For better fit, added a strip on the rear half too. Placement was based on easy access to the three buttons on the Display’s right side with enough space on left for connecting charging cable if so required anytime. The Display does not stay switched ON all the time. What I have observed so far is that once the vehicle starts after some time (I think triggered by motion of the sensors which then transmit to the Display), the Display switches on and showing the status. Of course one can manually switch ON using the buttons to check at anytime.
Display fitment:
Details of device with firmware version:
Overall for a total cost of ~ ₹6,400/-, I feel it is a worthy upgrade.
